showa Posted September 27, 2009 Author Share Posted September 27, 2009 Put gas and spark to it today and it started just like it was parked yesterday...... Smoked some but was getting better... Everything came up to temp and stabilized... Now on to rear disc brakes and renewing the clutch hydro system... Kurt Quote Link to comment Share on other sites More sharing options...
Rimal310 Posted September 28, 2009 Share Posted September 28, 2009 Put gas and spark to it today and it started just like it was parked yesterday...... Smoked some but was getting better... Everything came up to temp and stabilized... Now on to rear disc brakes and renewing the clutch hydro system... Kurt congrats!! i wish i had luck like that with my first 240. Quote Link to comment Share on other sites More sharing options...
datsphilly Posted September 28, 2009 Share Posted September 28, 2009 bad ass... pics of the old cartech setup? Quote Link to comment Share on other sites More sharing options...
showa Posted October 3, 2009 Author Share Posted October 3, 2009 This is when I first got it.....(hasn't changed much yet).... Kurt Quote Link to comment Share on other sites More sharing options...
softopz Posted October 3, 2009 Share Posted October 3, 2009 Nice man! Iam happy for you I love the old school turbo setups. I too wish I had that kind of luck with my first car. It looks really clean just look at the radiator fins for sure it was stored inside ! It looks like its got a external wastegate under the turbo hot side. VIDEOS VIDEOS Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted October 3, 2009 Share Posted October 3, 2009 I didnt know they made one like that i thought the only one they made was to fit triple webers like what i have but i guess im wrong Quote Link to comment Share on other sites More sharing options...
showa Posted October 4, 2009 Author Share Posted October 4, 2009 CAR tech responded "we don't make that product anymore" to an email with questions about this setup..... I was looking for tips/areas of concern etc with this turbo so I don't do anything stupid and hurt it right away.... Like, does the carbs secondaries open up under boost ??? (They're vacume secondaries) How does the brake booster work/ it looks like it's under pressure..... Stuff like that would be nice to know, this is my first turbo and not sure about this stuff..... Kurt Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted October 4, 2009 Share Posted October 4, 2009 On that set up there is vacuum between the carb and turbo. The carb is up steam of the turbo and the brake booster should be between the carb and turbo so everything on the carb works just like on a normal Z. On engines that have been sitting for a long time I always use to add a couple quarts of ATF to the oil and let the car idle for around 45 minutes or so and then drain the oil as soon as I could while it was still hot. The ATF will clean out all of the sludge and get the varnish out of the rings. But this is an OLD SCHOOL method. Quote Link to comment Share on other sites More sharing options...
ozconnection Posted October 4, 2009 Share Posted October 4, 2009 CAR tech responded "we don't make that product anymore" to an email with questions about this setup..... I was looking for tips/areas of concern etc with this turbo so I don't do anything stupid and hurt it right away.... Like, does the carbs secondaries open up under boost ??? (They're vacume secondaries) How does the brake booster work/ it looks like it's under pressure..... Stuff like that would be nice to know, this is my first turbo and not sure about this stuff..... Kurt The situation with the brake booster is this. There should be a valve in the brake vacuum hose line between the manifold and booster. This is a one way valve, that way your brake booster never sees boost, only engine vacuum. It's assumed that when you've got ya foot on the brake, you've got ya foot off the gas (no boost). Cheers. Quote Link to comment Share on other sites More sharing options...
