trouble setting ignition timing
i bought a not-so-running 75 with an 81 ZXT swap and im having issues trying to set the timing to 20*BTDC.
i have brought the Crank sensor to its lowest point and turned the dizzy as counter clock-wise i could. Yet im still advanced at 22 1/2*.
The car does have an odd stumble at times and the rpms rise up for a bit every few minutes. When the rpms rise up my timing gun doesnt seem to get a signal.
heres an interesting note. It idles slightly better at the setting i found the car which was at 30* BTDC
please help a newbie out
thanks
thanks
Did you get this figured out yet?
Did you disconnect the vac advance while trying to reset the timing? Just a thought. If you have too much vaccuum at idle your timing will be off to start with.
i thought the 81's didn't have vac advance? where do i disconnect this and is it supposed to be set at 20* with it disconnected?
Well, good point. If you don't have a vac hose from your intake to your distributor then you don't have a vac advance.....my bad.
Look to see if you have a vac line going to your distributor. :) You should always set the timing with the vac advance disconnected. ;)
Phleb - Turbo Dizzys have Crank Angle Sensors, no vacuum advance.
  • 2 months later...
i forgot i had this thread open as its been a while since i worked on the car.
i took a few pics so i can show you all where things are ligned up. this is with the #1cyl at tdc compression stroke
and here is the dizzy set up in order to get the timing where its set.
and heres a pic of the TB...looks to me im missing of a few things such as the idle screw? unless the 81's didnt come with an idle adjustment screw
and because i really need this figured out asap here is a pic of the cam
