inmocean Posted November 1, 2009 Share Posted November 1, 2009 thank god for the factory service manual...recently rebuilt my l28, using "how to rebuild your nissan/datsun ohc engine" book by tom monroe as a resource...anyone else notice the misprints on pages 12 and 110/111? page 12 gives the correct firing order but illustrates it wrong on the cap, and the valve clearance specs are all mixed-up in the text on 110 and then to the photo caption on 111... Quote Link to comment Share on other sites More sharing options...
blue72 Posted November 2, 2009 Share Posted November 2, 2009 I had noticed those discrepancies before. It's a good thing there are other reference books and this forum. Quote Link to comment Share on other sites More sharing options...
X64v Posted November 2, 2009 Share Posted November 2, 2009 The factory service manual has typos, too. Unless you think torquing your main caps to 3-4ft.lbs. is a good idea... Quote Link to comment Share on other sites More sharing options...
theghosttanker Posted November 2, 2009 Share Posted November 2, 2009 your book also gives the wrong torque for cam tower bolts. Quote Link to comment Share on other sites More sharing options...
Challenger Posted November 2, 2009 Share Posted November 2, 2009 The factory service manual has typos, too. Unless you think torquing your main caps to 3-4ft.lbs. is a good idea... Sound about right, fingertight. Quote Link to comment Share on other sites More sharing options...
josh817 Posted November 5, 2009 Share Posted November 5, 2009 Sound about right, fingertight. Hey, its better then me sticking in the rear main cap backwards at first. Wasn't paying attention at all. Luckily I only torqued them down 3-4 ftlbs. Had to use the little inlbs torque wrench so that would be 12x3 = 36inlbs. Don't forget to torque the front cover bolts to 10 ftlbs too. Thats a true statement, don't strip the aluminum. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted November 10, 2009 Share Posted November 10, 2009 I did notice the firing order thing...you would think these things wouldn't be overlooked, especially in this case. Quote Link to comment Share on other sites More sharing options...
josh817 Posted November 10, 2009 Share Posted November 10, 2009 Firing order matters, but the prong on the dizzy doesn't. :] Thats my major preach... It doesn't matter if wire #1 is at 12 o'clock or at 5 o'clock, as long as the firing order is correct, you're fine. I've seen too many souls freak out because the rotor isn't facing in the right position. Quote Link to comment Share on other sites More sharing options...
inmocean Posted November 22, 2009 Author Share Posted November 22, 2009 here's another misprint, different book though...datsun z, fairlady to 280z, by brian long...page 136, black and white of datsun restoration, can anyone tell me what's going on with that engine? it's backwards, oil filter on wrong side...exhaust manifold shown appears normal...someone out there must have seen this too! Quote Link to comment Share on other sites More sharing options...
Heathhh Posted January 31, 2010 Share Posted January 31, 2010 Other than these misprints, was the rebuild quite successful with the book, "How to rebuild your datsun/nissan engine OHC" ? just curious, cause i am reaching towards the day when im going to rebuild my engine. And i had just purchased this book on amazon Quote Link to comment Share on other sites More sharing options...
waddiejohn Posted February 1, 2010 Share Posted February 1, 2010 Tom Monroe used to tie his plane down next to mine at Ryan Field in Tucson. He wrote for HP Books then and having been a Ford engineer he wrote the "How to rebuild" books for Ford engines. He left Tucson to go to one of the Carolinas to work for a NASCAR team. He was a pretty sharp guy. I wonder if the errors are his or the editors. Waddie Quote Link to comment Share on other sites More sharing options...
