DRFTEM Posted November 3, 2009 Share Posted November 3, 2009 Ok basically I have some apexi N1 EXV coilovers left over from my miata and well I was wundering could I use these on my z. I know id need a threaded sleeve for them to thread into but were can I find one of these? I was thinking I could just chop the miata ones when then I realized the sleeves are aluminum. and those wouldnt weld verry well to the oe shock inserts sleeves which I believe are steel. Does anyone know were I could find the correct sized sleeves that i could weld on so I can install these?The coilovers are 8/6 spring rates and im not certain what most of you run but I also have some 11/9 if those are to soft.Please only help wanted. I dont want to hear about just buy whats for sale . I want to do something a bit different and only looking for actual help. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted November 4, 2009 Administrators Share Posted November 4, 2009 DRFTEM said: I know id need a threaded sleeve for them to thread into but were can I find one of these? Try Beta Motorsports, Ground Control, Speedway, Lefthander Chassis, etc. DRFTEM said: I was thinking I could just chop the miata ones when then I realized the sleeves are aluminum. and those wouldnt weld verry well to the oe shock inserts sleeves which I believe are steel. I'm not familiar with the Miata stuff you speak of, but most vendors provide aluminum threads/nuts. They aren't normally welded in. DRFTEM said: Does anyone know were I could find the correct sized sleeves that i could weld on so I can install these? Keep in mind the strut tube diameter is different between early and late 260Z. Make sure you get the threaded tubes that fit your strut tubes (measuring them would be the safest bet). Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted November 4, 2009 Author Share Posted November 4, 2009 Ok no thats not the kind of stuff im looking for. Im thinking more of the things called ADAPTER SLEEVES on arizona z car . so basically I have everything except those to make my miata coilovers work. these are what Im looking for Quote Link to comment Share on other sites More sharing options...
johnc Posted November 4, 2009 Share Posted November 4, 2009 Buy them from Arizona Z car. Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted November 4, 2009 Author Share Posted November 4, 2009 I e-mailed them to see if I can just purchase those from them.no response yet Quote Link to comment Share on other sites More sharing options...
NZeder Posted November 4, 2009 Share Posted November 4, 2009 DRFTEM said: I e-mailed them to see if I can just purchase those from them.no response yetDave will reply - I purchased a set of just the threaded parts for my setup as I sold my 240z and kept the coilovers then I wanted to install these on my 260z (your 280z shell/suspension setup we never got the S30 with L28 here) so I needed some new weld on's so I could put these in the correct location for the taller rear struts. Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted November 4, 2009 Share Posted November 4, 2009 dc2 intergra coils have been adapted to z strut housings... Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted November 8, 2009 Author Share Posted November 8, 2009 Ok arizona z said there adaptors will not work with my miata coilovers so I guess i will keep on looking. Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted November 9, 2009 Share Posted November 9, 2009 serialnine or meganracing or weld them on yourself or. get proper coils Quote Link to comment Share on other sites More sharing options...
Porterhausen Posted November 16, 2009 Share Posted November 16, 2009 What I have done with other applications is simply going to a local machine shop and having them turn the threads in a length of tube, and cut that tube into the correct length for your application. Not usually toooo expensive. Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted November 17, 2009 Author Share Posted November 17, 2009 we shall see. right now the coilovers are on the back burner. Quote Link to comment Share on other sites More sharing options...
s!lvias30 Posted November 18, 2009 Share Posted November 18, 2009 can i get alot more info on the dc interga coilover instructions , or something like that ?? thanks Quote Link to comment Share on other sites More sharing options...
cd1105 Posted November 18, 2009 Share Posted November 18, 2009 I've been look in this japanese Z magazine and it looks like over their they have more coilover options, too bad i don't read japanese since they have numbers to contact the vendors, but i will looking into it. Quote Link to comment Share on other sites More sharing options...
