gb20 Posted December 27, 2009 Share Posted December 27, 2009 This is for a 74 260. I have put in the AZC intake and 6-into-2 headers with the twice pipes exaust from MSA. After getting these parts installed I can't get the car to stay running. At first it would start and I could keep it running by messing with the throttle but it would take more & more throttle to keep it @ the same rpm. Now it comes close to starting but won't and backfires out of the exaust then blows gas out of the carb. Does anyone have any idea what could be causing this and how to fix it? Any help is more then appreciated. Thanks in advance, gb20 Quote Link to comment Share on other sites More sharing options...
jhm Posted December 27, 2009 Share Posted December 27, 2009 Sounds like the timing might be off. Did you adjust the timing when you were putting the new parts on.....or did the vacuum advance somehow get messed up with the new intake? Quote Link to comment Share on other sites More sharing options...
jasper Posted December 27, 2009 Share Posted December 27, 2009 Timing or most probably a VACUUM LEAK. Not vacuum advance. This is assuming all ran well before swap. I would expect you adjusted the float levels......etc... Quote Link to comment Share on other sites More sharing options...
gb20 Posted December 30, 2009 Author Share Posted December 30, 2009 My dad & I were just out there playing with the timing and checking the float levels. Also made sure we are getting spark to all the plugs. How would I go about checking for a vacuum leak? Thanks for the help & ideas guys. Quote Link to comment Share on other sites More sharing options...
Phlebmaster Posted December 30, 2009 Share Posted December 30, 2009 (edited) My dad & I were just out there playing with the timing and checking the float levels. Also made sure we are getting spark to all the plugs. How would I go about checking for a vacuum leak? Thanks for the help & ideas guys. Most people use starting fluid...but that only really works when you have it running. I am betting you have a vac leak based on the throttle symptoms you were describing. You didn't use any sealer on the gasket did you?? And you did use new gaskets, right? Edited December 30, 2009 by Phlebmaster Quote Link to comment Share on other sites More sharing options...
gb20 Posted December 30, 2009 Author Share Posted December 30, 2009 I used silicone gasket maker for it. Let it set up for 2 days before I tried it. It ran but it wasnt right. Then after a few days of starting it just stopped. Quote Link to comment Share on other sites More sharing options...
Phlebmaster Posted December 30, 2009 Share Posted December 30, 2009 I used silicone gasket maker for it. Let it set up for 2 days before I tried it. It ran but it wasnt right. Then after a few days of starting it just stopped. Ok...try picking up a new intake/exhaust manifold gasket at your local parts store. They are pretty cheap. Get the gasket maker off, I made that mistake once and had the same issues, that is why I asked. Make sure your carb gaskets are new as well. Quote Link to comment Share on other sites More sharing options...
