which KA24E piston grade for strocker??
QC_MURDOC
Yesterday I went to Nissan to buy the pistons for KA24E my Strocker. the guy asked me what grade. 1-2 - or 3? I know it's very important for the original engine, but is there a better grade for 3.1?
Is there a stronger one?? What is the difference between them? or is it just to match the date of different parts of the engine?sorry for the noob question but I really want to make sure to have good pistons, and yes I searched.
ok, but they are exactly the same size. only different part #. I would prefer the forged, but I find no place to buy 6 without buying 2 set of 4. At the dealer it is possible to buy only one.
If you call the company that makes them, you should be able to buy 6.
QC,if you went to Nissan and "the guy" asked you what grade piston, then I would think "the guy" should have your answers for you.
He told me that if it was to put in a 240sx, I needed to give the VIN # of the block to know what grade to use. anyway tanks for your help
Like VW Pistons, they are made to a specific weight range, or bore diameter depending on production tolerances of the tooling (I forget which on the KA). 1, 2, & 3 will determine which grouping they have. Its most important when you buy one piston and need to match the existing one to what you have. Putting a heavier '3' in with a light group of three other slugs may cause an imbalance situation. Having a 1, a pair of 3's and a 2 would likely cause some vibration I'm thinking. If it was bore sizing it related to, then the obvious scuffing and noise issues rear their head from incompatible tolerances piston-to-wall. "They all should be the same, and bore accordingly." This is all in the KA FSM, guys...
If you are buying them one at a time, I'd buy two sets of four and have two spares of the correct matched grade in case something went wrong. It's like buying V8 pistons for the Z. You get two spares. So what? Eventually they will come in handy, as either detonation replacements, or ashtrays.
Ask anybody who built an engine and then WAAAAAAY down the road broke a piston and needed to get only ONE replaced. Ask them if they would think you buying 6 'and two spares' would be a bad idea... I bet I know what they would say!
That's what I thought, SECOND POST:
http://www.freshalloy.com/forums/archive/index.php/t-132864.html
Same as most Nissan Water-Cooleds. The VW was weight grouped. Damn Germans, they take tolerance to a new level. "Ze Diameter ist correct, ziss ist nat zubjekt doo debate! Zee veight is vat vee mus concentrate our efforts upon! Zee veight!"
The EXACT bore diameter specifications are found under 'pistons' on this post (imagine what a 30 second google search turns up, eh?):
http://www.240sxforums.com/forums/ka24de-t-ka24e/116466-anything-everything-you-want-know-about-your-ka24de.html
