hoov100 Posted February 8, 2010 Share Posted February 8, 2010 Alright, it started off as a noob question, but hopefully we can turn it into a giant info bomb for the vg33. Quote Link to comment Share on other sites More sharing options...
Tony D Posted February 8, 2010 Share Posted February 8, 2010 I've used HKS and Tomei CrMo one-piece flywheels for years. They are considerably lighter than that one, so I can only guess the weight is carried behind the pressure facing and in the area around the crank mating flange---would have to see it to confirm, but I would think it would work fine. I think I paid $215 for my Tomei sniped at the last second, they are normally 1.5X2X that price. The lighter weight would not be an issue in a Z so much as a Frontier that was rock-crawling. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 8, 2010 Share Posted February 8, 2010 My experience with light weight flywheels in traffic is that the transmission tends to shunt when using very light throttle ie car can jerk a bit. So a bit of extra weight will smooth things out a bit. That is a good price for what seems to be a decent product, may get one myself, let us know if you get one. Quote Link to comment Share on other sites More sharing options...
Jared Posted February 8, 2010 Share Posted February 8, 2010 Looks ok, but that listing is for a Z32, which uses an 8 bolt crank. I think the single cam VGs used the 6 bolt crank. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 Jared said: Looks ok, but that listing is for a Z32, which uses an 8 bolt crank. I think the single cam VGs used the 6 bolt crank. Yeah, I just realized that myself Still looking for a decent light flywheel that isn't made by fidanza. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 8, 2010 Share Posted February 8, 2010 Stick a Z32 crank into it, thats what I'm going to do. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 260DET said: Stick a Z32 crank into it, thats what I'm going to do. yeah, then I have to have the crank machined, then I would have to to get new bearings.etc trying to get the motor in as cheap as possible as fast as possible, doing the work myself. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 8, 2010 Share Posted February 8, 2010 What machining? Far as I know the Z32 crank drops straight into a VG33, will know for sure in a few days anyway. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 260DET said: What machining? Far as I know the Z32 crank drops straight into a VG33, will know for sure in a few days anyway. If the crank has any scoring or needs truing, wouldn't you need to have the crank turned? Quote Link to comment Share on other sites More sharing options...
260DET Posted February 8, 2010 Share Posted February 8, 2010 Oh I thought you were talking about getting the Z32 crank machined to fit. So your VG33 crank is good, I understand. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 Yeah, I'm buying a complete running long block with 20k miles from a 2001 xterra, but finding an aftermarket flywheel for a standard vg30e is hard, If the crank from a vg30de is the same as the TT crank, I might as well do it, as I have a good vg30de shortblock sitting in my parts car. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 Heres a thread with some usefull pics. http://images.google.com/imgres?imgurl=http://img.photobucket.com/albums/v652/rhdrift12345/DSC00395.jpg&imgrefurl=http://www.nissanoffroad.net/messageboard/index.php%3Ftopic%3D6539.msg81637&usg=__nv3g0R3dELAzNL7G9IiULPjA17E=&h=600&w=800&sz=89&hl=en&start=11&sig2=jPVMldOlhu4RDoYDJnpTyQ&um=1&itbs=1&tbnid=z-44yoRj6vCYtM:&tbnh=107&tbnw=143&prev=/images%3Fq%3Dvg33%2Boil%2Bpump%26hl%3Den%26safe%3Doff%26um%3D1&ei=YN5vS_ClC5-ktgOsoeCxDQ Another one I found. http://nissannut.com/maintenance/vg33e_upgrade/ According to the last link: Oil pump drive is 34 mm on VG30 and 41mm on VG33 \ said: I have built over 20 VG33 converted engines to fit 300ZX. I have also gone through comparison to use an vg30de crank. Bottom line vg30de Crank is longer about 5 mm All timing belt items would have to be moved forward about 5mm or vgde crank snout cut down The oil pump on an vg30de is deeper' date=' higher volume, can be modified to fit VG30 series block. Installed with an vgDe crank, oil pan length increases about 12mm The vg33 oil pump will not properly feed a Turbo engine, its pathetic even a new one. Lost several engines to lack of lubrication. The VG33 and any Front wheel drive block vg30 require oil check valve installation to use oil filter location that has block plate installed or debris can bypass into motor easier. We had machined and turned 10 VG33 crank shafts. Snouts machined to accept vg30 oil pump and W series crank pulley. Did keep, VG33 Timing belt which is superior due design of less drag and durability its doubled. Down side 33 crank is not forged, designed with larger counter weights more mass to match pistons. VG33 Rods piston oilers are smaller I would be willing to work with someone on the board to pass our knowledge on combined with nico website info. I support this site (nico had a raffle years ago for an skyline Turbo car, bought several tickets car was not raffled, dates changed, researched never found out who won the Skyline!) Lets do an addition or tech page FAQ for vg33 dannymuir@hotmail.com 850 565-0052 \ said: ZDaddy #2 is false Here's as much as I know and will back up. Please feel free to use what you want. \ said: [b']Knowledge is worthless when it is not shared [/b] I left performance aspects out of this for the sole purpose of spurring discussion. If you're considering a 3.3 please read the following before you ask questions' date=' you may find your answer! [b']The official unofficial VG33E information. This was created to solve the problem of little information and many myths regarding the SOHC VG33E. As many are still unaware of all the differences this motor has compared to other variations in the VG engine line up, this thread and following post will build on the growing knowledge of understanding differences and modifying the VG33E. The following is to my current knowledge, over time I hope the forum members and moderators can both add to, and help keep this in order while simple to read. To start lets cover the models and years this engine was avaliable in. In some vehicles the 3.3L was an option. In the USDM vehicles: '96-'00 Nissan Pathfinder '97-'00 infinity QX4 '99-'04 Nissan Frontier, '01-'04 supercharged avaliable '99-'02 Nissan Quest & Mercury villager '00-'04 Nissan Xterra, '01-'04 supercharged avaliable Visually the VG33E besides a few components is idential to a VG30E. There are mostly minor location differences of components, routing of lines, and electronic components that visually set the VG33E apart, though these minor differences can be worked around by using parts from other VG's. Basic information, intake manifold down to the heads: Getting a little more in depth lets talk about the intake and fuel related pieces, the VG33E uses the upper intake manifold found on earlier pathfinders and quest that used the VG30E. The lower intake manifold is similar to the VG30E's as well being able to use most of the 3.0's upper intake manifolds, the coolant neck found on the 3.3's lower intake houses two sensors though it is similar to some of the 3.0's does not function as a filling location like some 3.0 designs, but it shares the same flange design and bolt pattern so it is able to use many variations. The fuel system is similar to the later +'87 3.0's using side feed injectors, though the seals are of larger diameter and different design. The locations to bolt the fuel injectors down is much lower on the 3.3's lower intake manifold, other differences are the 3.3's intake manifold lacks a sensor and coolant tube on the rear passenger side some of the 3.0's used, the rear coolant tube has different routing than most 3.0's, again the flange and bolt pattern is similar to the 3.0's so swapping tubes is simple. Port diameters (~36mm) are similar as well as head to manifold coolant passages, and will line up with any VG30 head casting. The heads specific to the 3.3 are known by casting reference "OWO". Visually they are very similar to the 3.0's head using 13 head bolts, the main difference being the 10mm exhaust studs. The exhaust studs can easily be rearranged to suit your header choice using a TORX socket. Internally they share parts with the 3.0 specifically the rockers, lifters, lifter guide, valve and valve spring locks, retainers, valve stem diameter, height, and ultimately - layout. The 3.3's valves can be identified by their casting "EF-3" I have yet to find a source that list valve seat angles. Both the intake and exhaust ports have a much smoother casting than the 3.0's V52, 21V, and 85E heads. Head bolt locations, water passages, and oil galleys are similar though there are slight differences in the water passages they will not interfere with swapping 3.3/3.0 heads to ether block though I would advise against 85E or 21V heads onto a 3.3 block due to the water passage being close to the combustion chamber more so than the V52. A major difference is in the camshaft found in the 3.3, the 240/244 .354"/.354" cam is good for low end grunt but not that great for high RPM power. The 3.3's camshaft is commonly swapped out for 3.0's camshafts for better high RPM performance, aftermarket 3.0 cams will also work. Another difference that is very important to note is the camshaft sprockets, the 3.3's sprockets use a round tooth style compared to the 3.0's more squared tooth style, the matching crank gear must be used. Basic information, bottom end and rotating assembly: Lets start with the engine block. Again the 3.3's block can be identified by an "OWO" casting on the front driver side. Many of the locations to bolt up engine brackets, and accessory brackets are predrilled and tapped making the use of other 3.0 pieces an easy affair. The block to bell housing pattern is also the same as 3.0's making many transmissions available. What makes the 3.3 a 3.3 is the bore of 91.5mm, the stroke length is shared with the 3.0 at 83mm. The pistons are cast like other VG's having a compression ratio of 9:1 they also have the OWO imprint along with valve reliefs and a slight bowl to the center. The connecting rods, again stamped with "OWO" are similar to a 3.0's the difference being the notches at the bottom. The crankshaft is cast sharing the same main and connecting rod journal sizing system as the 3.0's, it also shares the six bolt flywheel pattern found on 3.0's. The major difference between the 3.3's and 3.0's crankshaft is the snout, the 3.3's has a larger diameter and must be used with the matching 3.3 oil pump and pulley. The 3.3's oil pump also is the mounting location for the oil filter and oil pressure sensor, the pumps pickup is also closer to the center line and has a taller mounting location than 3.0's pick up location this may require modifying the oil pan per-application. A common discussion is drilling the block for an oil feed location when adding a turbo, the motor I picked up from a '96 Pathfinder did not require any drilling as it only has a plug. Accessories: The 3.3's crankshaft pulley is delicate, and prone to chipping/cracking use caution when removing and handling. The 3.3's pulley is special, it has a 32mm center bore, and has variations in belt style and routing per-model. The easiest way to over come this issue is to get the associated brackets and accessories, though this may interfere with simple intake and intercooler pipe routing on those who choose to use turbochargers. There is also the option to swap in a 3.0 crank and use the 3.0 pulley and accessories this also involves using the 3.0 oil pump and using the Quest style 3.0's oil pump that side mounts the oil filter like the 3.3's, or simply using the 3.0's oil filter stud from other variations to relocate the filter. That's the most of my knowledge concerning this topic, personally I'm still unfamiliar with mix matching brackets and pulleys, as I'm still in process of locating the pieces. There is much more information and examples yet to be shared, the basic information posted is a start in the right direction to document the knowledge in an effort to centralize it. If you would like to add information your self please keep it organized and easy to read. If you're planning to swap a VG33E in place of a VG30E the swap is pretty straight forward as long as you keep an eye on the subtle differences and an open mind to solve simple problems. There are many others out there that know much more about this engine than myself, I am looking forward to any additional information, corrections, or pictures.[/b] I will be back to edit this I'm sure! :nanan?re Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 I'm going on a hunch here and think the vg30d crank and oil pump will bolt on, but you have to use the 33's lower crank sprocket, or switch them all out with the vg30d's timing sprockets. If anyone has an oil pump from a vg30d laying around, could you pull it apart and get us the dimensions? Quote Link to comment Share on other sites More sharing options...
Careless Posted February 8, 2010 Share Posted February 8, 2010 DET oil pumps do not have the oil holes matched up to the same place in the block. your only options are VG33E and VG30E pumps. That depends on which crank you decide to use. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 8, 2010 Author Share Posted February 8, 2010 I'm just not seeing where things are different, maybe I'm stubborn or something, but I'm just not seeing it, I've heard about their being two extra holes in the dett's oil pump, if thats the case you could most likely just have them welded close or plugged. I'm going to take a look at my z32's oil pump and compare it to a vg30 pump I have on the shelf. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 9, 2010 Share Posted February 9, 2010 If the pump has the wavey type gerotor guts like the Z32 pumps have, not the gear tooth type, then it should be OK. Providing it is a decent size of course, keeping in mind I've yet to see specific details of VG33 pump failure so the above is a bit of a guess. A Z32 needs a fair bit more lubrication capacity than a VG33, what with its four cams, VVT, oil squirters, etc. My VG30DET has a TT oil pump, after an oil and filter change it picks up oil pressure within two seconds of starting, they shift a lot of oil. The pump on my 33 is the V type, will see in a day or two what guts it has. EDIT Got the chance to look at my 33's oil pump and what a tiny POS, it has the wavey guts but the VG30DE pump is a lot bigger and looks like it has twice as much capacity, the VG30DETT's is bigger again. The original 33 wavey guts pump may be OK for a stock motor but my 33 will see 7000 RPM regularly. So, can a VG30DE pump be made to fit? The oil gallery lines up, all but two bolt holes line up, stay tuned Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 10, 2010 Author Share Posted February 10, 2010 260DET said: If the pump has the wavey type gerotor guts like the Z32 pumps have, not the gear tooth type, then it should be OK. Providing it is a decent size of course, keeping in mind I've yet to see specific details of VG33 pump failure so the above is a bit of a guess. A Z32 needs a fair bit more lubrication capacity than a VG33, what with its four cams, VVT, oil squirters, etc. My VG30DET has a TT oil pump, after an oil and filter change it picks up oil pressure within two seconds of starting, they shift a lot of oil. The pump on my 33 is the V type, will see in a day or two what guts it has. EDIT Got the chance to look at my 33's oil pump and what a tiny POS, it has the wavey guts but the VG30DE pump is a lot bigger and looks like it has twice as much capacity, the VG30DETT's is bigger again. The original 33 wavey guts pump may be OK for a stock motor but my 33 will see 7000 RPM regularly. So, can a VG30DE pump be made to fit? The oil gallery lines up, all but two bolt holes line up, stay tuned which two holes? maybe you can drill and tap the block for them and use studs? PICS MAN! It's killing me! Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 10, 2010 Author Share Posted February 10, 2010 Found some specific oil pump info on e vs. dett oil pumps including dimensions! http://74.125.155.132/search?q=cache:MFm2EhK28DMJ:www.epracing.net/images/Doc/NISSAN%2520Z31%2520%26%2520Z32%2520OIL%2520PUMP%2520DIFFERENCES.ppt+z32+oil+pump+gear&cd=2&hl=en&ct=clnk&gl=us And you can download the powerpoint WITH PICS! here. http://www.epracing.net/images/Doc/NISSAN%20Z31%20&%20Z32%20OIL%20PUMP%20DIFFERENCES.ppt Quote Link to comment Share on other sites More sharing options...
260DET Posted February 10, 2010 Share Posted February 10, 2010 Looks like the VG30DE/TT pumps will fit. I won't be attempting this for months because my 33 project is a long term build but drill and tap two 6mm holes in the block and fill in the gap where the block will not meet the pump flange with Devcon or similar should do it. There may be other things that need attention but at the moment it looks doable. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 10, 2010 Author Share Posted February 10, 2010 If I do end up getting the 33, I'll mount up a dett's oil pump and take lots of pics. 1 Quote Link to comment Share on other sites More sharing options...
