Boy from Oz Posted February 15, 2010 Share Posted February 15, 2010 I would like to use billet machined valve covers and relocate the coils out-of-sight. Does anyone have photos of such an installation on a S30? Possibly something like this: http://forums.corvetteforum.com/c5-tech/2212538-how-to-relocate-your-coil-packs-many-pics.html Should fit okay but what are the implications of using very long leads? Thanks Quote Link to comment Share on other sites More sharing options...
Cable Posted February 15, 2010 Share Posted February 15, 2010 ....what are the implications of using very long leads? Thanks With an n/a LSx motor, I am sure you'd be fine with long leads since each coil is pushing quite a bit of juice (50k or so). I've seen guys mount them on the firewall too, not in S30's, but other custom apps.... Something to consider. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 15, 2010 Share Posted February 15, 2010 I would consider sealing them and putting them in the cowl, before I would put them behind the front fenders. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted February 15, 2010 Share Posted February 15, 2010 After some looking, I'd probably mount them inside the cowl. Like the "firewall" area. Plenty of room in there, and just snake the wires down and out. Just a thought. Quote Link to comment Share on other sites More sharing options...
Boy from Oz Posted February 15, 2010 Author Share Posted February 15, 2010 I thought about the cowl but was worried about clearance with the wiper mechanism. I think I might try to mount them in a square configuration on the inside of the inner guard, i.e behind the battery and on the opposite side - I have a RHD. A perforated shield (to allow cooling) painted the same colour as the car should hide them sufficiently without exposure to road grime. These are just my preliminary concepts so any other suggestion would be appreciated. Quote Link to comment Share on other sites More sharing options...
myplasticegg Posted February 15, 2010 Share Posted February 15, 2010 Don't you have 8 of them to deal with? Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted February 15, 2010 Share Posted February 15, 2010 Here's another idea. It's from this thread: http://forums.hybridz.org/showthread.php?t=153092&page=3 Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted February 15, 2010 Share Posted February 15, 2010 Are you running A/C? I wasn't going to on mine when I cared about my LS1, and was going to mount them on the transmission hump right next to the firewall on the inside of the cab. They'd be dry and protected and pretty easy to access. Additionally you shouldn't have to modify the harness too much to get the length into that area. Quote Link to comment Share on other sites More sharing options...
Boy from Oz Posted February 15, 2010 Author Share Posted February 15, 2010 Don't you have 8 of them to deal with? Yes, but luckily the cars down here have both a left and right inner guards! Blown77Z - Thanks, the 'toast rack' configuration gives rise to other possible locations. tfreer85 - I though of having them inside the cabin but I was concerned about how much heat they would generate and the summers down here make A/C a must have. Someone was making a two-tier valve cover which enclosed the coils but there were comments about the coils overheating. Quote Link to comment Share on other sites More sharing options...
sq_creations Posted February 15, 2010 Share Posted February 15, 2010 ha ha someone beat me too it and posted my picture. I used caprice wires. Here is the other side mounted under my front facing header. the coils are mounted to an aluminum strap that is attached to the block. I saw a really nice kit that bolted the coils to the back of the heads on ls1 tech. I have to much stuff tucked back there already though. Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted February 17, 2010 Share Posted February 17, 2010 How about move them to the right some more and under that metal piece in the second picture? The 280Z has these 2 pockets on both sides. But running the coil wires could be challenging. Seriously if you want a clean look the place to put them is behind the firewall. Run all your coil wires thru the fire wall just like how you run the EFI wires but seperate them out. Otherwise you might get interference. GL Quote Link to comment Share on other sites More sharing options...
sq_creations Posted February 25, 2010 Share Posted February 25, 2010 I found the head mounting bracket I mentioned earlier. http://www.mastmotorsports.com/page.php?Category=Engineered%20Accessories&Section=Coil%20Relocation&id=120 Quote Link to comment Share on other sites More sharing options...
sq_creations Posted March 11, 2010 Share Posted March 11, 2010 Found another cool bracket. http://www.automotivedesigneng.com/products/coil_pack.html Quote Link to comment Share on other sites More sharing options...
RB30X Posted August 31, 2010 Share Posted August 31, 2010 You get the dimensions of those brackets Peter and I'll fabricate them Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted January 29, 2011 Share Posted January 29, 2011 I like these coil relocation brackets in the post above, but how do you organize and route the wires so that they clear the JTR headers? The stock coil location is awesome for plug wire organization. I've seen the coil brackets, but does anyone have a lead on some nice looms for routing the wires? I don't want to burn my wires up! Quote Link to comment Share on other sites More sharing options...
Boy from Oz Posted January 30, 2011 Author Share Posted January 30, 2011 (edited) It would depend on the valve covers you use. If you are just using the standard covers minus the coils then you could use a couple of clamps on two of the post on the covers, (see photo). Edited January 30, 2011 by Boy from Oz Quote Link to comment Share on other sites More sharing options...
