Which of these 2 Turbo's would you choose
MikeBZ
I'm looking at these 2 turbo's for my 240z build.
The motor is an F54 Flat top piston NA block with a P90 head, stock cam, stock turbo injectors, and stock ECM. I will be using an intercooler, and 2.5 inch down pipe and exhaust with a straight through magnaflow muffler. I'm looking at 8-9 psi max
Here are the turbo's I am considering
#1
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180471774388&viewitem=&sspagename=STRK%3AMEWAX%3AIT
T3 TURBO INTERNAL WASTE GATE TURBO CHARGER .63ar
T3 internal wastegate turbo
Intake: 3 inch
Inlet: 2 inch
Compressor trim:
Compressor Wheel diameter: 54.28 /71.32
Turbine Wheel diameter: 55.79 /63.36 Exhaust Trim: .63ar
Turbine flange type: T3 flange
Down pipe flange type: 2.5 v band
Actuator setting : 8 psi
Cooling type: oil cool only
And Door number 2
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290400802988&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Intel 3"
Outlet 2"
Bearing Wet Floating Bearings
Oil Inlet 1/8 NPT Oil Inlet
Flange Standard T3/T4 Flange
Swaps 350 WHP
Working Pressure 5~20 PSI
Compressor .60 A/R Compressor
Turbine .63 A/R Turbine
Compressor Wheel Exducer: 3"
Inducer: 2"
Turbine Wheel Exducer: 2.2"
Inducer: 2.58"
Hot Side 2.5" v-band
They look to be the same, just seeing if anyone has any advice or has purchased these turbos and what their opinions are.
Thanks
First one doesn't seem much different than the stock unit, and the work to plumb the exhaust would not be worth it.
The second one looks like a bit of an upgrade from stock, and the same work to plumb.
If you are looking for a mild factory upgrade, a regular T3/TO4B with a V trim is good, or T3/TO4E with minor tweeks to the intake plumbing. Just get a unit that bolts to a standard downpipe.
For much more than 350hp, get a full TO4 or a GT series turbo and external wastegate.
I would question the quality of the eBay turbos. Check feedback and try to get more information. Maybe lurk on the Honda technical sites and see if anyone complains or has issues -- I'm sure that's the target market for these.
Edited by SleeperZ
I would use a T3/TO4E 50 Trim compressor and a .63 A/R Turbine section with your choice of turbine trim depending on how much power you want and at what rpm.
Gabe has switched to the .50 trim compressor from one or two bigger ones and is really happy now - spool and boost onset are much better.
If you DO want to spend at least twice as much, go for a GT3076 - but you will need to get the .82 A/R to have the same flow as the .63 A/R on the GT35.
The GT35 isa bit big for a 2.8 - fine for a 3.0.
Thanks for everyone's advice
I've been looking at different T3/TO4E turbo's but am on somewhat of a limited budget.
GT35's and the GT3076 are for sure out of my price range.
I have bought 2 used stock turbo's that turned out to be junk.....
Most of the info I've found about the ebay turbos seems to be hit or miss, which is why I asked about these 2. Most of the reviews on them or feedback is done when the person opens the box and see's their shiny new part.... Godspeed had their turbo's reviewed by honda tuning magazine and they came out ok, but some claim the company cherry picked the good ones for the review...
Cheap
Fast
Reliable
They say you can choose 2 but not all three...
