Delasangre4231 Posted March 16, 2010 Share Posted March 16, 2010 I found a company who makes nice "crate" engines for the 300zx z31. Its basically the longblock with the heads and timing setup all put together ready for the rest of the engine to be installed. Anyways, is this setup the same for turbo or non-turbo or would there be different specs/parts installed? I could just bolt on my turbo manifolds and the turbo and my old oil pan and drop it in right? Quote Link to comment Share on other sites More sharing options...
jasper Posted March 16, 2010 Share Posted March 16, 2010 (edited) No,different, http://www.howstuffworks.com/turbo.htm Edited March 16, 2010 by jasper Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted March 16, 2010 Author Share Posted March 16, 2010 This doesn't help at all. I know how a turbo works. I'm asking if a crate engine that is the assembled block, heads, and timing components, will accept either NA or turbo components. So If I buy one engine can I crate a NA or Turbo out of it? Or does a rebuilt engine need to be assembled different at the core for turbo or NA? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted March 16, 2010 Share Posted March 16, 2010 The only thing different long block wise is the pistons. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted March 16, 2010 Author Share Posted March 16, 2010 (edited) Whats the difference in pistons? Anything in the heads? I take it that I had better get one thats built for a turbo then? Edited March 16, 2010 by Delasangre4231 Quote Link to comment Share on other sites More sharing options...
jasper Posted March 16, 2010 Share Posted March 16, 2010 Compression ratio is of the utmost importance. The correct/ideal ratio is achieved by the selection of the pistons, and cylinder heads, head gaskets, etc......(combustion chamber cc's). So no...one size does not fit all. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted March 16, 2010 Author Share Posted March 16, 2010 That's what I was looking for, thanks. Quote Link to comment Share on other sites More sharing options...
RedBeauty84ZX Posted March 16, 2010 Share Posted March 16, 2010 On 3/16/2010 at 3:08 AM, Delasangre4231 said: That's what I was looking for, thanks. NAs are rated at 9:1 compression. Turbo engine are rated at 7.8:1 or 8.3:1 compression depending on year. All of them are acceptable for boost, many people turbo the factory NA long blocks with great success. 9:1 compression isnt considered high anymore as long as you have a good tune... Quote Link to comment Share on other sites More sharing options...
Gregmatic Posted March 17, 2010 Share Posted March 17, 2010 As these guys have said, the compression ratio is the only internal difference. Only other thing to keep in mind is that you may have to change the placement of the exhaust studs as htey are differnt for turbo/non-turbo. That is, of course, if it even come with studs. Also od minor importance is if it is a "W" or "A/B" series block as these will have some crank pulley differences. Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 17, 2010 Share Posted March 17, 2010 you'll be fine running a turbo on an NA motor. You will get more power gain per pound of boost through the turbo since the compression of the motor is higher, but you will be able to run less boost overall, again since the compression is higher. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted March 17, 2010 Author Share Posted March 17, 2010 What I found out is that the crate engine is non-turbo and they won't make the turbo version. Quote Link to comment Share on other sites More sharing options...
RedBeauty84ZX Posted March 18, 2010 Share Posted March 18, 2010 On 3/17/2010 at 5:39 PM, Delasangre4231 said: What I found out is that the crate engine is non-turbo and they won't make the turbo version. You can swap the turbo components to the non-turbo blocks just fine....9:1 compression isnt high. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted March 18, 2010 Author Share Posted March 18, 2010 My engine is real strong so I think I'll just get the heads rebuilt. Quote Link to comment Share on other sites More sharing options...
