cd1105 Posted March 16, 2010 Share Posted March 16, 2010 So i was trying to install my arp head studs last week and I noticed that that the studs come in two different sizes I was wondering which ones go where. I've been trying to figure it out for a while since both of them can go into the same holes, just some are a little longer than the others. I know some one here has the quick answer or a picture. Thanks. Quote Link to comment Share on other sites More sharing options...
Noddle Posted March 16, 2010 Share Posted March 16, 2010 On 3/16/2010 at 11:25 PM, cd1105 said: So i was trying to install my arp head studs last week and I noticed that that the studs come in two different sizes I was wondering which ones go where. I've been trying to figure it out for a while since both of them can go into the same holes, just some are a little longer than the others. I know some one here has the quick answer or a picture. Thanks. I haven't installed mine yet, but I would say the longer one would be the ones that goes through the head, and the cam towers, and the shorther ones, would only go through the head Nigel Quote Link to comment Share on other sites More sharing options...
TimZ Posted March 17, 2010 Share Posted March 17, 2010 On 3/16/2010 at 11:35 PM, Noddle said: I haven't installed mine yet, but I would say the longer one would be the ones that goes through the head, and the cam towers, and the shorther ones, would only go through the head Nigel Yep. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 17, 2010 Share Posted March 17, 2010 Nigel, you are correct sir! Quote Link to comment Share on other sites More sharing options...
cd1105 Posted April 6, 2010 Author Share Posted April 6, 2010 (edited) So I figured out where the two sizes go and ran into a new problem now. The five longer studs go into the block no problem,but I'm having trouble getting the smaller ones to go all the way in the block. I chased the threads twice and used brake cleaner to clean out the block threads. They only go until about two threads are sticking out the block and won't turn anymore without excessive force. Also one of the threads I couldn't chase completely because it was getting stuck and i didn't know if I kept turning it if I would strip the block thread. Is there a certain way I should clean the threads????any body have this problem before.Maybe lube the end going into the block??? Edited April 6, 2010 by cd1105 Quote Link to comment Share on other sites More sharing options...
hughdogz Posted April 6, 2010 Share Posted April 6, 2010 Will the stock bolts go in all the way? Maybe the ARP ones have an incorrect thread pitch... Quote Link to comment Share on other sites More sharing options...
X64v Posted April 7, 2010 Share Posted April 7, 2010 That's how they are on mine, too. It's fine, don't force them. This pic is pretty dark in the stud area but you can see on those first two on the passenger side of the block where the threads are sticking up above the deck. Quote Link to comment Share on other sites More sharing options...
zbloke Posted April 7, 2010 Share Posted April 7, 2010 My ARP head studs showed a few, maybe 2, threads above the deck of the block when I fitted them, I got mine a little deeper by using a No.3 or bottoming tap on the threads in the block. Quote Link to comment Share on other sites More sharing options...
cd1105 Posted April 9, 2010 Author Share Posted April 9, 2010 Thanks for the pic. But you still want want all the smaller studs to be at the same height sitcking out the block even if they do show about 2 threads above the deck correct? I'm assuming the studs sticking out a little bit above the deck doesn't affect proper torquing? Quote Link to comment Share on other sites More sharing options...
TimZ Posted April 9, 2010 Share Posted April 9, 2010 On 4/9/2010 at 3:19 AM, cd1105 said: Thanks for the pic. But you still want want all the smaller studs to be at the same height sitcking out the block even if they do show about 2 threads above the deck correct? I'm assuming the studs sticking out a little bit above the deck doesn't affect proper torquing? When you clean the threads, use a "bottoming" tap - this type of tap is flat on the end, and will clean the threads all the way to the bottom of the hole. Quote Link to comment Share on other sites More sharing options...
