LT-1, JTR mounts, Sanderson headers
I dropped my '73 Z off tonight to have the exhaust built this weekend. I'll be going over the details with the guy doing the work tomorrow night. He runs his shop out of his garage. The LT-1 is in there with JTR mounts. The headers fit without any trouble.
I also have the JTR radiator mount kit with a Chevy radiator and an electric fan I pickup up out of a 90's Mercury at the salvage yard.
The drive shaft from the donor car ('95 Firebird) is at Northern Colorado Driveline in Greeley, CO to be shortened and balanced. They are also going to replace the rear yoke so that a standard u-joint can be used with the JTR mounting flange. I replaced the R180 with a 3.9 R200 and RT mount. The tranny is a T-56.
Next up is plumbing the fuel lines and a small fuel reservoir. Then wire up the PCM and hope it starts...
Kenny, the project looks great. Northern Colorado Driveline does nice work. Are you going single or dual on the exhaust? Looking forward to seeing the finished product and having another V8 hybrid in the area. If you ever need an extra hand, let me know.
Edited by John Scott
Take care with the wiring on the passenger side near the frame rail, I started to melt the convoluted tubing I used to put all the wires in, those headers get hot. I ended covering up all the convoluted tubing with heat wrap foil, I still may put an aluminum plate shield between the frame rail and the headers.
Greg
  • 4 weeks later...
Greg
Where would one get this heat foil wrap?
