chasm8 Posted April 9, 2010 Share Posted April 9, 2010 I have a 82280zxt 2+2 5 speed.Its doesnt idle right after it gets to normal runing temp.It goes between 800 and 200 rpms.it almosts shuts off ,but deosnt.Ive check timing,compression,fuel pressure,all reads like the fsm said.plugs and wires are new.I also couldnt find any vac leaks any were. any other ides would help.thanks Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 9, 2010 Share Posted April 9, 2010 Test the cylinder head temp sensor (just left and up from the knock sensor) Could be a lot of things if you still have a 100% factory intake manifold with everything on it. Why do you think so many of us delete all that crap? My L28ET warms up just fine in the "brisk" 30 degree mornings on the coldest days here in the bay area. If the head temp sensor checks out ok, then I'd start checking everything in the cold start system. Quote Link to comment Share on other sites More sharing options...
Steveoen Posted April 14, 2010 Share Posted April 14, 2010 On 4/9/2010 at 6:52 AM, Gollum said: Test the cylinder head temp sensor (just left and up from the knock sensor) Could be a lot of things if you still have a 100% factory intake manifold with everything on it. Why do you think so many of us delete all that crap? My L28ET warms up just fine in the "brisk" 30 degree mornings on the coldest days here in the bay area. If the head temp sensor checks out ok, then I'd start checking everything in the cold start system. mine tends to start rough to most of the time i have a 78 but it has the zx motor what is involved in deleting all the "crap" Quote Link to comment Share on other sites More sharing options...
scorpio516 Posted April 14, 2010 Share Posted April 14, 2010 Take a look at the air mix screw on the TB too. That was the cause of my looping idle (auto though). I've got to keep all the crap if I want to pass smog . Which I did easily 3 months ago Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 14, 2010 Share Posted April 14, 2010 Stock manifold... My edited Turbo manifold... Basically disconnect everything and make block off plates/bolts for all but Brake booster vacuum Boost/Vacuum Gauge Fuel Pressure Regulator Ground wires That's all you really need. My car in the coldest of mornings needs a little motivation from the right foot to idle above 1000rpm for the first 60 seconds or so because I have no fast idle control..... oh no. But I don't have to worry about diagnosing all those little gremlins that come back to haunt you constantly. Just remember, this would never pass a smog inspection. Quote Link to comment Share on other sites More sharing options...
chasm8 Posted April 16, 2010 Author Share Posted April 16, 2010 On 4/14/2010 at 7:01 PM, Gollum said: Stock manifold... My edited Turbo manifold... Basically disconnect everything and make block off plates/bolts for all but Brake booster vacuum Boost/Vacuum Gauge Fuel Pressure Regulator Ground wires That's all you really need. My car in the coldest of mornings needs a little motivation from the right foot to idle above 1000rpm for the first 60 seconds or so because I have no fast idle control..... oh no. But I don't have to worry about diagnosing all those little gremlins that come back to haunt you constantly. Just remember, this would never pass a smog inspection. Quote Link to comment Share on other sites More sharing options...
chasm8 Posted April 16, 2010 Author Share Posted April 16, 2010 (edited) were do you find th block off plates?your intake looks clean... Edited April 16, 2010 by chasm8 Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 16, 2010 Share Posted April 16, 2010 I made my block off plates out of my scrap hood I had lying around. If you want to see REALLY clean intakes, there are much better examples around. If you want it to look really nice you need to grind off all that you're not using, and weld it in, then sand it to a mirror finish. Mine's just empty. Quote Link to comment Share on other sites More sharing options...
chasm8 Posted April 16, 2010 Author Share Posted April 16, 2010 On 4/16/2010 at 6:23 AM, Gollum said: I made my block off plates out of my scrap hood I had lying around. If you want to see REALLY clean intakes, there are much better examples around. If you want it to look really nice you need to grind off all that you're not using, and weld it in, then sand it to a mirror finish. Mine's just empty. Quote Link to comment Share on other sites More sharing options...
chasm8 Posted April 16, 2010 Author Share Posted April 16, 2010 thanks.Ill start this weekend on the intake and see how it works. Quote Link to comment Share on other sites More sharing options...
PurePontiacKid Posted April 22, 2010 Share Posted April 22, 2010 This is how my intake looks after I shaved/filled it (N42 intake on a NA '79 with stock EFI) sometimes my car will do the same thing when I'm coming up to a stop and I let the revs drop. I can usually mostly fix it by either adjusting the TB a tiny bit more open (higher idle) and/or leaning out the AFM a bit (but messing with the AFM is a PITA and I don't recommend it for a novice lol) Quote Link to comment Share on other sites More sharing options...
stretchnuts Posted July 1, 2010 Share Posted July 1, 2010 I know this is kind of an old thread, but I too am currently in the process of cleaning 82 L28ET intake. Gollum, where did you get that huge plug/bolt for the factory pop off valve? Quote Link to comment Share on other sites More sharing options...
PurePontiacKid Posted July 1, 2010 Share Posted July 1, 2010 idk what he used, but a friend of mine used the plug from an NA Z31 intake manifold (where the popoff would go on the turbo cars) for his. Quote Link to comment Share on other sites More sharing options...
Gollum Posted July 1, 2010 Share Posted July 1, 2010 Sorry I never saw this!!! My bad. I actually USED the pop-off valve. I took a grinder with a cut off wheel and cut the top off. Then I took a large bolt that was able to fit inside and not fall through, and ground it down so it fit snugly inside. I used it as a stop/filler for the jbweld I then filled the pop-off valve. I'm not one to say jb weld can do anything, but this is a good application as it never gets insanely hot, and the vacuum and boost are well within the range of this stuff's bonding ability. Quote Link to comment Share on other sites More sharing options...
chasm8 Posted July 6, 2010 Author Share Posted July 6, 2010 On 4/9/2010 at 2:57 AM, chasm8 said: I have a 82280zxt 2+2 5 speed.Its doesnt idle right after it gets to normal runing temp.It goes between 800 and 200 rpms.it almosts shuts off ,but deosnt.Ive check timing,compression,fuel pressure,all reads like the fsm said.plugs and wires are new.I also couldnt find any vac leaks any were. any other ides would help.thanks all fixed.IT ended up being the new dizzy was bad. Quote Link to comment Share on other sites More sharing options...
