Zmanco Posted January 18, 2012 Share Posted January 18, 2012 Quote How come no one is going in and out the same side? Rather than going across the front of the motor and fhe radiator. That approach uses the two holes to the left of the radiator - routing across the front of the engine allows one of those holes to be used for a cold air intake. Quote Link to comment Share on other sites More sharing options...
Fuzzydicerule Posted January 19, 2012 Share Posted January 19, 2012 I didnt have a same sided intercooler, and IMHO it looks cleaner this way Quote Link to comment Share on other sites More sharing options...
450HPZ Posted January 25, 2012 Share Posted January 25, 2012 BOV should be as close to the throttlebody as possible to relieve compressor pressure. Quote Link to comment Share on other sites More sharing options...
450HPZ Posted January 25, 2012 Share Posted January 25, 2012 I have one Quote Link to comment Share on other sites More sharing options...
Nigel Posted January 25, 2012 Share Posted January 25, 2012 On 1/25/2012 at 6:53 PM, 450HPZ said: BOV should be as close to the throttlebody as possible to relieve compressor pressure. Last I checked there was a lot of debate about that... Nigel Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 25, 2012 Share Posted January 25, 2012 On 1/25/2012 at 7:27 PM, Nigel said: Last I checked there was a lot of debate about that... Nigel ...And the end result in any of the debates has been, put it where it fits. I have yet to see any conclusive results of qny testing that shows one location to be better than another for a BOV. Quote Link to comment Share on other sites More sharing options...
450HPZ Posted January 27, 2012 Share Posted January 27, 2012 Just what the GURU`S tell me. In my opinion as long as its on the cold side of the intercooler, who cares. Quote Link to comment Share on other sites More sharing options...
Nigel Posted January 28, 2012 Share Posted January 28, 2012 On 1/27/2012 at 9:45 PM, 450HPZ said: Just what the GURU`S tell me. In my opinion as long as its on the cold side of the intercooler, who cares. Well, it depends on your "Guru" I guess. Some claim that the hot side is better. Why run hot air through the intercooler if you don't have to? But as Six_Shooter indicated, most of the opinions are based on conjecture, so just put it where ever it makes you happy. Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
450HPZ Posted January 28, 2012 Share Posted January 28, 2012 On 1/28/2012 at 1:28 AM, Nigel said: Well, it depends on your "Guru" I guess. Some claim that the hot side is better. Why run hot air through the intercooler if you don't have to? But as Six_Shooter indicated, most of the opinions are based on conjecture, so just put it where ever it makes you happy. Nigel '73 240ZT I agree Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted January 28, 2012 Share Posted January 28, 2012 (edited) On 1/28/2012 at 1:28 AM, Nigel said: Well, it depends on your "Guru" I guess. Some claim that the hot side is better. Why run hot air through the intercooler if you don't have to? But as Six_Shooter indicated, most of the opinions are based on conjecture, so just put it where ever it makes you happy. Nigel '73 240ZT While I tend to agree with Nigel......the S30 can house such a large efficient IC that the choice of placement may be a mute point for us. Guys that have little to no room might benefit in efficiency with mounted close to the compressor so not to tax the IC minutely even. Edited January 28, 2012 by Vintage-TechZ Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted January 28, 2012 Share Posted January 28, 2012 I think putting it wherever air can flow out the easiest is more important. I'm having issues with surging on throttle-off. Could be many things. But I did have this BOV and this engine working fine together. And that's about all that's stayed the same now. Quote Link to comment Share on other sites More sharing options...
Leon Posted January 28, 2012 Share Posted January 28, 2012 On 1/28/2012 at 2:54 AM, Vintage-TechZ said: ...may a mute point for us. Sorry, what was that? I had to do it! Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 28, 2012 Share Posted January 28, 2012 (edited) I thought I posted pictures of mine in this thread already, but I just went back through and didn't see any pictures of mine, so here it is: Another Brown and Boosted S30... This is when I first installed my turbo and EFI, technically, this isn't an intercooled set-up in these first pictures, since I was simply running a bypass pipe across the front of the rad, since I hadn't got a change to make my IC at that point. I did have my BOV attached to it, at the front left corner of the car, just in front of the rad support. Just a couple pictures of the IC (BOV?) piping running under and around the engine, yes I need to weld some of the tubes together and get rid of some of those couplers... Move along a couple years (I really slacked on making the IC, even though I had most of the material for a long while): Mitsu BOV: I've changed the plumbing a bit at the IC/rad support. I was really trying to keep the IC tubing going through the lower holes in the rad support, but it just wasn't a nice as I'd have liked, so I moved to using both the upper holes, where the vent pieces were. I also have an IC from Mishmoto, that I'm going to try, It's a cross flow, but with the fitment I did on another S30, it looks like I can change the IC piping to be more like how I want it to be. Edited January 28, 2012 by Six_Shooter Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted January 28, 2012 Share Posted January 28, 2012 (edited) This is my old set-up and is pretty typical I've found.Flowed off throttle very smooth and never had anything but very cool intake temps under long duty cycles. BOV was mounted below one of the elbows prior to the IC. One thing to note.....when I had the same configuration in Aluminum pipe it heat soaked temps quite a bit higher....but when in Stainless, it all but went away. I made an air tight seal all the way around the space between the radiator and IC due to having dual fans pulling through the IC and pushing back through the radiator. Edited January 30, 2012 by Vintage-TechZ Quote Link to comment Share on other sites More sharing options...
roger280zx Posted January 30, 2012 Share Posted January 30, 2012 Bloz up, any reason you spaced the intercooler soooooooo far from your radiator? You are generating alot of turbulance in between them and that hurts the efficiency of BOTH systems. I bet if the intercooler was placed properly you would not need that push fan in there. Just my .02 Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted January 30, 2012 Share Posted January 30, 2012 So the piping would fit. The intercooler is a little too wide. I didn't need that pusher--it's not longer on the car. Plus that fan was worthless in a push configuration. Right now I have one 12" puller cooling off the car just fine at low speed. Otherwise airflow seems sufficient and my datalogs confirm that the intercooler works well also. Quote Link to comment Share on other sites More sharing options...
kaito Posted March 19, 2012 Share Posted March 19, 2012 (edited) The reason I didnt go with a same side inlet outlet is because I didnt want to cut a hole in the core support, and the reason I went under the motor vice across the front of the engine bay was so I could retain the stock fan. (for now!)This is what I have so far. I havent made mounts for the intercooler or hooked up the piping by the starter yet. I also have to pull it all back off to clean the metal shavings. This is a pre mock up to say the least but it should be ready for the maiden voyage soon. Edited March 19, 2012 by kaito Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted March 22, 2012 Share Posted March 22, 2012 (edited) I have a "zero budget" M30 build I had to press into service as a "minimum budget daily driver" that needed intercooling to keep the F54/P90 with flattops safe so I scrounged my stash for a supra intercooler and a way to plumb it without violating my project guidline of not cutting the body in any way.At the junkyards, I bought a bunch of random saab and volvo intercooler piping, soft hoses, and a blow off valve and was able to weave them through the body and cut the soft hoses to length and ended up with an intercooler/boost control/blow off valve system that cost around $80 dollars in parts for everything...(including intercooler)I'm using the stock "vacuum control valve" which is a very small recirculation valve and added a much larger recirculation valve which is plumbed in right before the throttle body and is routed to the turbocharger inlet elbow.It is dead silent like the rest of the car because of the usage of mostly factory stuff designed to deaden sound.If I remove the air cleaner box top, it will give off "Pssstt" sounds like most of the turbo cars that the sideways baseball cap wearin' beings prefer.VintagetechZ using stainless on the piping behind the radiator is definately doing it right.It's amazing how little engine bay heat the charge picks up from the piping when you use stainless......which is all I would consider if my project had a budget. Edited December 12, 2013 by HowlerMonkey Quote Link to comment Share on other sites More sharing options...
jacob80 Posted April 4, 2012 Share Posted April 4, 2012 (edited) I'm noticing a lot of you guys run your intercooler return piping across the radiator after it has been cooled rather than the way mine is installed. Is there advantage to doing this? It seems obvious that there would be significant heat soak since the air is already cool and you're now running it across a hot radiator, therefor decreasing your efficiency. Edited April 4, 2012 by jacob80 Quote Link to comment Share on other sites More sharing options...
roger280zx Posted April 4, 2012 Share Posted April 4, 2012 It might be that they don't want the charge pipe heating radiatior. I know honda's and evo's that heat soak the rad with the turbo, but I don't think a charge pipe would do it much. If you use stainless it should keep the radiator heat out of the cold pipe running opposite routing to your example. I say cough up the extra bucks for stainless piping wich ever way you rout it. Quote Link to comment Share on other sites More sharing options...
