Dash mock up. Tell me what you think
motoman
what are you using for material?
So I'm in the middle of making a dash out of Al and i made one up out of cardboard to see what it would look like. This is what i have so far.
Looks good, a lot like most of the aluminium dashes others have made.
Are you going to use the passenger side for any switches/gauges/mounting?
If not, how about just making half a dash? Would be quite a bit cheaper and would fit all the gauges that you are mounting.
I'm not to sure if anyone is going to be flying to far forward as i'm going to have 5 points in my car. I more had the lip there to keep the sun off the gauge faces. If you guys don't think 5 points will keep someones face out of the dash then i will do something about it.
see if you cant get some counter sink rivets for it, it will make it look tons cleaner! atleast for the top where the screws are, pretty easy to install, looks like youll need a size 6-2 or 8-2 because the screws are so large. But just buck em in and then have the front part removable so you can still work on what ever is on the inside.
  • 10 months later...
