Crank Damper (with 2 pulleys) from 75-78 280Z with A/C
darkzebra
WTB A crank damper with 2 pulleys from a 75 - 78 280Z; one that had A/C. Want to use it with Derek's mounting kit to install EDIS on a 1982 280ZXT.
Also need a water pump pulley from a 1981 -1983 280ZX.
Edited by darkzebra
Worked for me befor I just unscrew the bolts holding the third pully(from 280ZX) and insatled it in one of our members 78 280Z,worked fine.
Jamal
Hi Jamal
He needs the early style because that's the only one that will work with my EDIS adapter kit.
Derek
To Derek (sticky280zx): As PM'd after your 1st post, I have already bookmarked you should I not get one by the time I am ready.
In the meantime, I am still on the look-out for one that would cost me less (being in the unemployment line for 1 1/2 years and spending on a Z does require a little juggling act).
Rickey
Edited by darkzebra
  • 9 months later...
