How can i stop eating oil (cheap/easy)
rztmartini
As the title states, my temporary motor (L28 with P90) has developed a taste for engine oil rather than fuel. I would guess it is burning it at a rate of about 1 quart oil/3 gallons gas. It is so bad, it leaves a big black soot mark on the ground whenever I start it up and the smoke is killing me when I go off throttle at anything over 3000 rpm. My other engine (3.1) is awaiting pistons so I (hopefully) I won't be driving this motor for very much longer. I know its the rings, not the valve seals, and have tried that oil additive stuff, but I think its too far gone.
Does any one have some suggestions to make life bear-able until the other motor is done??? I could care less about the end result of the pistons/block if there is a temporary solution that will end up trashing all moving parts in the long run. My lungs (and other drivers) will thank you greatly!
-Smokescreen
Your local auto parts store should have additives that will help. Something along these lines:
http://www.autozone.com/autozone/accessories/Bardahl-16-oz-no-smoke-treatment/_/N-260b?counter=8&itemIdentifier=491825_0_0_
My car would go through about a gallon of oil every 1000 miles or so, and this stuff cleared up my problem for the most part. Your burning way more than that, but it might slow the flow a bit.
Good luck
-Smokescreen
Could always put it on a diet and stop feeding it oil? Itll stop consuming oil on its own sooner or later. Probably sooner. Sadly for toasted rings there isnt much you can do, short of tearing it down and replacing the rings, at least not in my humble experiences.
Whats a realistic time-frame to have your 3.1 together? If its that far off, replacing the rings might not be that bad of an idea after all. For starters rings are cheap- and ill tell you from first hand experience you can do it without taking the engine out of the car. I replaced all of my pistons with the motor still in the car, just undid the oil pan/head and had at it. Took me one night after work with a buddy to get it done.
OLD School Again: Drain you oil, and put in ATF as a flush, start the engine and let it idle for 30 minutes, do not drive the car . It helps if you put some cardboard if front of the radiator to get the engine on the warm side. Drain the ATF and put in 20-50 oil. ATF is high detergent and can get all of the sludge out of your engine.
Maybe you could run some straight 50w, It should slow it down a little. Maybe combine that with some of that engine honey. Sounds like your just after a temporary fix, that's what I would do. Only problem is on cold days it can be hard stuff to turn over.
Edited by goodoldjam
Do the Seafoam treatment. Put in 20w50 oil.
What is the compression on the cylinders?
Black is usually fuel. Bluish/white is oil.
At what point do you notice the smoke - just idling, on acceleration or decelleration?
Idling/acceleration = rings
Decelleration = valve guides
This is of course assuming that it IS burning oil, which the black smoke doesn't suggest.
Its not black smoke, it leaves black soot on the ground when I start it cold. The smoke is a white color, at least it looks white when it fills the cabin :P
It develops smoke most on off throttle deccelerattion when at high rpm (>3000). I have tried 2 different heads on there with the same problem: origional was N42, took it off because I was hoping it was valve seals. Put a P90 on from an engine that was not smoking.
Black soot on ground = RICH
White smoke is water vapor. What does it SMELL like (other than exhaust).
Slightly sweet = water w/antifreeze.
If so, you may have a crack in your head allowing water into combustion chamber.
Bluish smoke = oil and will smell like burnt oil.
If it IS bluish, then valve guides or seals.
You may have a crack in your head allowing water into combustion chamber.
