  • Replies 125
  • Created
  • Last Reply
Top Posters In This Topic
Have a set of 15X8.25 with Toyo R888 225/50-15 When balanced they put weights on outer inside edge. Tie rod end caught weight and scarred inside edge. After taking wheels and getting rebalanced with weights more toward inside. Car has strut spacers about 1" which I think is causing clearance issues, Will take some pictures and post. Just a heads up for anyone interested inthis set-up
  On 10/2/2012 at 3:44 PM, rjracin240 said:
Removed bump steer spacers last night now all kinds of room!
Continuing on with some amplifying info, just completed a track day @ Barber Motorsport running my 15X7 with 0 offset rims and 225/50-15 tires. Experienced some tire rub on outside of tread shoulder rear tires, inner fender lips have been knocked in with a 5lb sledge hammer so they are virtually flat. Thinking that if I had put the 15x8" XXR's on would definitely have gotten bunches of rub. Anyone have any advice?
