83 L28ET with P79 head
ArchetypeDatsun
I been searching for a while now and can't seem to find anyone that's installed a P79 on a 83 L28ET, unless of course I missed it? So my goal is just to run this head temporarily until I can get my P90 rebuild. I have a loud ticking coming from my P90a head for sometime so I haven't driven my car much. I'm low on cash and unemployed which really sucks but I need to be on the look for jobs and this is holding me up. I know so far the compression will go up and so I would have to run low boost but the problem is I don't have a good boost controller. Would it be safe to run it on stock boost, my set up now is 83 L28ET with AiResearch T3/TO4E, turbo 87 Z31 ECU, MAF, stock exhaust, stock injectors & non intercooled. Any help as always will be greatly appreciated!
Edited by 280zx@541
Compression ratio won't change as the P79 and P90 have the same chamber. The only thing that would be of concern if one or more of the exhaust liners came out from the heat. If you kept the boost reasonable and didn't flog it too much, I would run it temporarily. If you didnt want to change the head, you could remove the hydraulic pivots from the P90a and see if you can clean them or Overhaul them. There is a post on here somewhere that addresses that.That is the route I would take as there would be less work and money spent on gaskets and such for a head swap.
Take you lifters out and soak them in carb cleaner or run a can of engine flush. Old school is to add 2 qts of ATF and let the engine ilde for about 30 minutes to flush an engine. I have seen this work on V8 lifters in the past. It sure will not hurt and it could save changing a head out.
So I took my spare n/a L28 that I have for sale looking at the head before taking it off it would seam to be more work needed just to clean it up and have a compression check for leaks than my P90 would. I now decided to just take my P90 to a machine shop less of a hassle for me, only thing holding back is the freezing weather.
One more thing you could consider is to just convert the pivots to solid with Timeserts. I think 12 of them cost about $30. You could take the pivots and cam,etc. from the N/A engine. Watch BigPhil's video. It's pretty damn easy to do, and doable with the engine in the car.
