HybridZ: Fuel Cell & Fuel Plumbing install W/ pics - HybridZ
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
Fuel Cell & Fuel Plumbing install W/ pics Rate Topic: -----
#1 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
  • LocationGlendale, CA
Posted 08 April 2008 - 09:34 PM
In hopes of getting better fuel delivery, and making the car safer I replaced my old smelly fuel tank with an Aluminum 10 gallon fuel cell from Summit.
It was kind of tricky making a fuel cell frame for this aluminum cell because there are really no safe mounting points. I used 1x1 x 16 gauge square tubing and first built the bottom making sure that the weight of the tank was going to be supported by all 4 corners. With the cell bolted to the tabs I welded on the bottom I sized it up and realized I had to make the cell removable for maintanence or repair.
I came up with a way to remove the cell from the bottom by welding bolts inside of the square tube with the threads facing downwards. Then I welded 4 "L" brackets out of .125 onto the bottom cage and drilled holes for the bolts to slip into. For added strength I added one little gusset to each "L" bracket.
To finish it all off I covered the floor with 22 gauge sheet and tacked it all up following that with seam sealer.
I'm still considering if I should weld in some flat stock across the top of the cell even though the cell already fits super tight on top, and if I should cover the cage with some sheet.
Stay tuned for fuel plumbing.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
0
#2 User is offline   cockerstar
  • Member
  • PipPipPipPipPip
  • Group: Donating Members
  • LocationKennewick , WA
Posted 09 April 2008 - 12:13 AM
*claps*
That is amazingly clean :)
0
#3 User is offline   Six_Shooter
  • Member
  • PipPipPipPipPip
  • Group: Members
  • LocationOntario
Posted 09 April 2008 - 03:51 AM
Looks good.
0
#4 User is offline   gdv350ss
  • HybridZ Supporter
  • PipPipPip
  • LocationLancaster, PA
Posted 09 April 2008 - 08:45 AM
Wow! A new standard to shoot at for all fuel cell installs!
Keep the great info and pics coming!
0
#5 User is offline   BillZ260
  • Member
  • PipPipPipPipPipPip
  • Group: Members
  • LocationTulsa, OK
Posted 09 April 2008 - 09:00 AM
Nice work. Can you give us the dim's on that cell and a pic from the rear? How much is blow the valance?
0
#6 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
Posted 09 April 2008 - 09:15 PM
Thanks for the commments guys.
I made a correction, It's a 10 gallon cell not 12 and it's dimentions are 16.5 x 16.5 x 9.0. When it sits flush with the floor the bottom of the tank sits about 1'' below the roll pan and the frame about 2''.
Posted Image
Posted Image
0
#7 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
Posted 10 April 2008 - 07:38 PM
I finnished off the plumbing using 3/8 aluminum hardline and braided line. I got all my stuff from ANPLUMBING.COM which is local if your in the LA area. Huge selection of Earl's fittings, hoses, etc.
I ran the hardline through the firewall/footwell then using nylon clips ran the line along the trans tunnel inside the car. The 10' lines ended 1.5' short of the tank after exiting the inside of the car through the passenger side storage compartment.
From the hardlines i used compression fittings that then converted to AN stlye fittings.
I fired up the fuel sysyem today and everything works properly with out any leaks, Phew.
It was my first time using all the AN style stuff And I must say it's really easy to use and seals very nicely. However, This crap adds up FAST! so make sure you know what you need before you buy.
Heres the finished product:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
0
#8 User is offline   garvice
  • HybridZ Supporter
  • PipPipPipPipPip
  • LocationBrisbane, Au
Posted 11 April 2008 - 01:46 AM
I always like your work mate, you do a great job.
Just a quick question, is safe having the fuel lines run through the cabin?
0
#9 Guest_280ZForce_*
  • Group: Guests
Posted 11 April 2008 - 02:24 AM
looks real clean Myron, but I also question running the fuel lines inside, doesn't seem the safest option to me.
Also, where are your fuel filters... under the hood?
0
#10 User is offline   1 tuff z
  • Member
  • PipPipPipPipPip
  • View gallery
  • LocationRochester, NY
Posted 11 April 2008 - 02:55 AM
awesome job. under hood pics?
0
#11 User is offline   deja
  • Member
  • View gallery
  • LocationSugar Hill, GA
Posted 11 April 2008 - 04:27 AM
I agree with 280Zforce, I wouldn't want fuel line running inside the car, especially aluminum line. Beautiful job none the less.
0
#12 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
Posted 11 April 2008 - 10:27 AM
Thanks for the comments. I'll take a shot of the engine bay where the filter is located.
I know running fuel beside you doesnt sound like the safest option but my reasoning is that the aluminum is much softer than the stock steel lines and can easily get more damge outside of the car from rocks and pebles.
If everything is secure in the car (which should be when I drive this car) there's nothing that should come in contact with it. if you take another look it's in a safe location IMO.
Additionally, iv'e seen plenty of race cars that have ran fuel lines inside. I think the question of safety arises if this car were driven as a daily street car, which it isn't.
I'm not tottaly stuck on the location. Any Tech inspectors or racers want to chime in?
0
#13 User is offline   1 tuff z
  • Member
  • PipPipPipPipPip
  • View gallery
Posted 11 April 2008 - 10:32 AM
myron, i'm running my fuel filter between the tank and pump. my thoughts were [and i'm no engineer] was to catch and filter any crap before it got to my pump. just a thought.
0
#14 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
Posted 11 April 2008 - 10:52 AM
I have my fuel filter before the engine, after the pump which is how most factory Nissans run them.
For the added protection it would be best to run 2 filters before and after the pump.
0
#15 User is offline   Scottie-GNZ
  • HybridZ Supporter
  • PipPipPipPipPipPipPip
  • LocationOrlando, FL
Posted 11 April 2008 - 12:13 PM
Nice clean install, but I have 2 comments.
- You already heard about the lines inside the cabin, and while not a tech inspector, I do not think that will pass tech in any form of racing.
- You have the pump too high. I recommend you drop it to about 1/3 the height of the cell.
0
#16 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
Posted 11 April 2008 - 01:02 PM
Is there a reason why I should run the pump lower? Should I be concerened about the lines and pump being that low?
Thanks
0
#17 User is offline   Slow_Old_Car
  • Member
  • PipPipPipPip
  • Group: Members
Posted 11 April 2008 - 04:10 PM
Thanks
pumps do not like to suck, they like to blow/push/force... by lowering the fuel pump position you will reduce the work load it encounters trying to get fuel through the pump.
*edit/addition*
just saw your fuel lines and question, i'm not up on the rules for all forms of racing, but i know in drag that you are required to have the fuel tank behind a bulkhead that seperates it from the passenger cabin (i do not know how strict they are about this rule, or if it changes when using a metal tank).
i also recall somthing about having any part of the fuel system mounted on the firewall was a giant no-no too, which i'm not exactly sure why unless they mean't the interior firewall, which would then definately make your fuel line placement a no no.
0
#18 User is offline   EMWHYR0HEN
  • Member
  • PipPipPipPipPip
  • Group: Members
Posted 11 April 2008 - 04:37 PM
I think i'm going to have to make some changes. I didn't realize how dangerous it could be to have the fuell ines through the firewall which could litterally cut the lines if the hole on the fire wall changed it's shape in a collision.
I think i'm just going to run it how it was stock..
0
#19 User is offline   zforce
  • Member
  • PipPip
  • Group: Members
Posted 11 April 2008 - 04:54 PM
I thought I read A post about running fuel lines inside car being safer and that some sanctioning bodies require it. Does anyone have a scca rule book handy?
One question why did you choose a 10 gallon fuel tank?I have thought about doing this conversion and would think 15 or 16 gallon would be better.
0
#20 Guest_280ZForce_*
  • Group: Guests
Posted 11 April 2008 - 04:57 PM
Smaller cell = less fuel = lighter weight.
His car is not a daily driver, so he's not worried about how far he can get on a single tank. He is building it for track purposes in mind.
0
Share this topic:
  • (2 Pages)
  • 1
  • 2
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
