http://www.hi-flow.com/HPIC2.HTM
(Searching for 'Laminova' got me one result, and it wasn't even relevant to my idea.
Talking to my buddy Sam about intercooling stuff, he and I agreed that air-water intercoolers were pretty neat. But then he showed me the Laminova design.
Sam's lucky, in this case, because he's got a WRX swapped Impreza, and Subaru boxer manifolds can just use these as a passthrough on top of the engine, where the stock throttle body sits, and instead of the TMIC.
But what about the L6? You can't use these inline, and making some kind of box to hold them would defeat the purpose of air water.
So I figured... What if you just chucked out the stock throttlebody and intake manifold, and used ITBs? As soon as you're using ITBs, you've basically decided that intake runners just aren't for you, anyways, and now you've got all that space freed up.
Since there's now no throttle body there, there's no need for a J-pipe of any kind. Since there's no FMIC, you don't need to run any other weird piping. So why not just dump the turbo straight up into a custom manifold box containing four Laminovas?
I drew a quick sketch of what I'm proposing. I saw another thread where someone was using ITBs with a turbo, but it seems to me that most people just let well enough alone when it comes to the throttlebody (or swap out for a bigger unit)
So I guess what I'm wondering is... am I totally nuts, or is there some merit to this idea?
I wish I could find evidence of this being done on an inline, non crossflow engine, but so far everything I've seen has been for V engines or boxers.
http://www.nsxprime....ad.php?t=125681
http://forums.bimmer...=1259403&page=5
What do you guys think? Doable on an L6?
Help
View Garage
