* * * * * 1 votes
Chris Rummel's easy follow RB into Z wireing guide
  • Please log in to reply
167 replies to this topic
#161 240zzzap
240zzzap
    Junior Member
  • Members
  • Pip
  • 4 posts
  • LocationAmsterdam - Netherlands
Posted 18 May 2013 - 09:04 AM
Is this wiring setup similar for the RB20?
There are a few similarities but wiring the 20 is supposedly a bit easier - http://forums.hybrid...-z/#entry860349. Links to ref. material are outdated tho'...
/bob
#162 rayaapp2
rayaapp2
    Member
  • Members
  • PipPipPipPipPip
  • 982 posts
  • LocationRoseville Ca 95661
Posted 17 December 2013 - 03:01 PM
RB25DET NEO WIRING!
Here goes
I have a 2000 RB25det.
I removed the ATTESA system. I cut it out and removed the wires going to the ECU. There are a small bundle of them and a relay. If your not keeping it and you probably wont for a Z, cut or tuck.
Pin 5    GRY/RED Start Signal
Pin 17  GRY?BLU MIL to 12V switched on a 10A fuse
Pin 20  GRN/ORG IGN Switch 12V
Pin 24  BLK/PNK FP Signal to 12V on the other side of the Relay(was not integrated into the EFI harness
PIN 31  WHT/BLUE IGN Switch 12V
ECM RELAY
Pin 6 WHT/GRN B+ 12V
Pin 1&3 WHT/BLK B+ 12V
They should all have 10A fuses to each power lead according to the FSM. The Start signal should have a 10A fuse as well!
I am running!
EDIT:
I missed 1 wire that is critical.
In the bundle of wires with the big white connector near the Relay packs there is a solid BROWN wire. This is the POWER wire for the IAC and the VCT! I was up and running without this and it took me until today(nearly a month later) to realize I had no VCT, but I also only drove it a handful of times. I then re-adjusted my idle and TPS and I am off and running.
Edited by rayaapp2, 28 January 2014 - 10:29 AM.
PROVE ME WRONG, I DARE YOU!! Then you're Teaching me for free!
Tony's Noble Truths :
Truth 1 "The more you learn, the more you realize you don't know."
Truth 2 "You don't know half the stuff you think you do, and the rest is questionable."
#163 ZT-R
ZT-R
    Totally Addicted
  • Members
  • PipPipPipPipPipPip
  • 1668 posts
  • LocationBeaufort, SC
Posted 29 December 2013 - 05:17 AM
I have a .4 amp draw on the alternator, does anyone else have this problem? I have tried 3 other alternators. I used the diode as mentioned in this thread, do i need a bigger one? I am using a Quest 125 amp, or whatever it is i cant remember.
<p>72 240z R.I.P.S. Forged RB30/26DET, BW 9174EFR, Series 2 AEM EMS , Endyn Pro Head, R.I.P.S. Intake Manifold & 90mm TB, R230 Rear End, T3 Suspension, ect...My Build Thread
#164 Crayzrb
Crayzrb
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationCincinnati
Posted 27 June 2015 - 08:01 PM
My rb harness only has 1 relay in it is this normal?
#165 mizle
mizle
    Newbie
  • Members
  • Pip
  • 10 posts
  • LocationOrlando, FL
Posted 29 December 2015 - 06:38 PM
I can't wait to swap an RB into my Z! Awesome right up
#166 Ba280z
Ba280z
    Newbie
  • Members
  • Pip
  • 9 posts
  • LocationTennessee
Posted 04 March 2016 - 01:54 PM
is this thread still going I need help with wiring. I have a rb20det swap, and harness and ecu are different then everyone elses ive seen. the pin out on ecu are different and so is the wiring. it has 4 separate plugs for the ecu instead of the block that bolts in. just trying to figure out the wiring I need. if anyone is familiar with this some help would be great!
#167 Wizzurp
Wizzurp
    Always Here
  • Members
  • PipPipPipPip
  • 112 posts
  • LocationTexas
Posted 04 March 2016 - 02:27 PM
You want this guide, it's much more helpful if youve got a 20
http://forums.hybrid...nto-a-datsun-z/
I used that as a mini guide (with some changes) for mine and it was quite good. I had mine wired in like 20 minutes.
#168 Ba280z
Ba280z
    Newbie
  • Members
  • Pip
  • 9 posts
  • LocationTennessee
Posted 02 April 2016 - 02:27 PM
Need help. I'm trying to locate the wires on the same loom as my afm. This is the only plug I have and not sure which need constant and switched power.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
