Cary (tube80z) has been mentioning this idea of the dual ball joint front end off and on for the last couple years. I hadn't really given it too much thought until I autoxed my car and was really lifting the inside rear tire, and Dan (74_5.0L_Z) suggested that the problem might be scrub radius and caster related. I guess the idea is that the outside wheelbase increases significantly enough due to scrub that the car leans over in that direction and the inside rear comes off the ground.
	Recently this thread popped up talking about swapping front suspensions and it quickly devolved into a pissing match for reasons beyond my comprehension, but it did get me thinking more seriously about the dual ball joint idea.
	Cary seems to think it's doable with the ball joints in the same plane, and had thought of a modified bumpsteer spacer as a possible way to do it. That got me thinking that it might be easier to just make a square tube knuckle and bumpsteer spacer combo, so that's where I'm at right now.  Thinking square tube with simple clevises welded to it for the ball joints, and then taper the front end and have it open and then use shims above and below the tie rod to adjust bumpsteer.
	I have absolutely no idea how to figure out the spacing on the clevises to minimize scrub and that sort of thing but I'm very interested to see if I can make it work, and to see if it would be as easy as I think it should be.
