Leaderboard
Popular Content
Showing content with the highest reputation on 06/30/18 in all areas
  1. Finished fabricating the mount for my Woodward steering rack. The new rack is significantly quicker than stock, with a 2.36 ratio, and also simply serves as a replacement as my stock rack was pretty tired and loose. I was unable to find most of the parts to rebuild it, so I figured this was another area where going aftermarket was a good long term strategy. The crossmember is the one from Apex Engineered, and all I did was cut off the stock rack mounts it comes with and make my own for the Woodward rack. The crossmember has some useful features, like multiple control arm pivot point locations and bracing attachments to the rear control arm mounts. It was also much easier to modify for the Woodward rack than the stock crossmember would have been. As shown, the rack is mounted in the stock location relative to the crossmember mounting surface, but it can easily be moved up or down as need be down the road, simply by removing the two bolts and changing the spacers. I am banking a lot that the electric power steering will work as I hope, because with this quicker rack and the 275 tires I plan to use in front....I doubt I would even be able to turn the wheel at parking lot speeds.
    1 point
