Leaderboard
Popular Content
Showing content with the highest reputation on 08/20/18 in all areas
  1. And yet another timing chain mockup series. I'm convinced when they design a motor the first thing they do is the timing chain. Talk about restrictive. SN005 is building a tall deck motor so I needed to work out what we were doing on the timing chain. I was hoping that my normal KA setup would work with a redesigned pivot for the tensioner arm. Actually worked out better than the normal setup. It looks like the extra height on the head will allow the arm to clear the timing cover without modifying the cover. It uses all the stuff from a KA24 timing chain kit except the bottom chain needs to be a 94 link instead of the 92. I was trying to get the arm closer to the tensioner but this is the best I'm going to get. Each full link you add or subtract shortens or lengthens the chain by 5/8” so the adjustment is pretty coarse. The guides are stock out of the box Nissan KA24. The jumper brackets on the tension side are temporary. I’ll design something a little better. I'm happy with the angle on the top tensioner. The upper brackets should start to become a standard item at this point. I changed the way the cam cores are being produced. I'm bringing the cams to length after heat treating and then shipping them to Schnieder for OD turning. This is giving me a lot more control. I know it probably seems like this project has stalled but far from it. I just decided to concentrate on getting my build, V2 and SN005 finished off. I realized after selling 005 that there are still a lot of little details to work out and I don't have enough free time to do my regular work and support any more builds. The next three heads will go a lot smoother now that I have all of this worked out. Derek
    1 point
