Leaderboard
Popular Content
Showing content with the highest reputation on 02/27/20 in all areas
  1. started knocking out the driver side front wheel well. I wanted to try this peice as one entire sheet of steel I quickly learned Im a jabroni when it comes to sheet metal shaping 😅. I ended up dividing the peice into four smaller squares and shaping them like that. Everything was started as a paper template, I typically use ram board. It can be sourced locally and is affordable for the amount of material you get. From there everything was transfered over to sheet metal and was snipped with hand shears to its rough shape. I cut off more than I required when cutting the sheet metal and then I did final trimming as I required it. Everything was rolled out on a cheap english wheel (princess auto special) than planished by hand.
    1 point
