Leaderboard
Popular Content
Showing content with the highest reputation on 03/12/20 in all areas
  1. You could just call Wilwood, Stoptech, or Essex Parts (AP Racing distributor), tell them the weight of your car, how you will be using it, and what size wheels the brakes need to go under. Budget will be a huge consideration too. Of the three Wilwood will definitely be the most affordable. AP and Stoptech components range from somewhat reasonably priced to astronomically expensive. AP Racing parts go all the way up to F1 components...you can imagine what that costs. Anyway, they could recommend compatible front/rear disc and caliper combos suitable for your use and budget. They could also suggest pedal/master cylinder setups...or you could just shop around after you decide on discs/calipers. I really like Tilton pedals and master cylinders. Coleman racing can machine custom brake hats reasonably inexpensively once you know what you need. I personally would go with floating discs in front, not so important in back because the rears generally see far less heat.
    1 point
