Leaderboard
Popular Content
Showing content with the highest reputation on 05/26/20 in all areas
  1. Depends on the suspension. If it has basically stock suspension you can install them lower, but when you start moving to shorter coilovers or sectioned strut housings, you start running out of room for the wheel to move up into the wheel well real fast. Camber plates make it a lot worse, especially on a 280 because the strut isolators are 3" tall vs 2" for 240Z. I cut my fenders and then put the suspension together with no spring and compressed and realized that my tire was hitting metal. Had to cut again much higher to prevent that from happening . In my case I cut the fenderwells so that they were flat from the top of the arch in the well to the outside of the quarter. Basically couldn't have cut any higher and made more room for the tire unless I had removed the whole wheel tub and rebuilt it. When the strut hits the bumpstop, there is about 1/2" space from the top of the tire to the fenderwell. I think the bumpstop is more than 1/2" long but I have super stiff springs so hopefully I won't have any issues. It's a pet peeve of mine to see ZG flares mounted way too low in the rear with really wide tires. Just obvious that nobody took the time to see if there was clearance for the tire, they just held the flare up to the body and marked and cut it there with no thought as to functionality. The other one that really bugs me is the tire and wheel being 1" from the inside curve of the flare, hellaflush style. You know that tire will hit the inside of the flare almost instantly, but still people do it all the time...
    1 point
