Leaderboard
Popular Content
Showing content with the highest reputation on 02/27/22 in all areas
  1. Thanks for your interest. I have spent the past several years trying to convince myself that I am not insane (though the project may be), and my move to the AME chassis was a big decision. It was a trade-off in spending money up front to save me time and ultimately get a car capable of handling the way I would expect after dumping tons of money into it regardless of which direction I choose. I have followed some of the other members' projects, and I see tons of work going into reinforcing the unibody which ultimately adds a lot of weight anyway. My goal with the AME chassis is that it, together with a minimally designed roll cage to meet NHRA / SCCA requirements, will provide all of the primary rigidity for the car, and the small remaining shell of the body I will use will just go along for the ride pretty much. I have struggled with coming to terms on a few aspects of the project. I don't like super wide wheels that protrude far outside the original body lines of the car. I wanted to keep that minimal, while recognizing that I would definitely need fender flares for what I have planned. Initially I wanted 17" wheels because I though 18" wheels looked strange on the Z car and was afraid they would just transmit too much road vibration to make it enjoyable to drive on the street. Plus, 17" tires now are relatively cheap. However, I also wanted to stick with a max tire diameter of about 25", so I came up with limitations on the 17" wheels and tire sizes. I finally decided on 18", and both front and back will be 25" diameter. OE Datsun tires were 24.6 I believe, and I felt it important to stay as close as possible to that. The narrowest track width (hub to hub mounting) that AME offers is 55.5 (OE Z car is 54.5), so I went with that on the front and rear, and am using 5.5" backspacing on the front wheels (18 x 9) and 6.5 backspacing on the rear (18 x 10.5) to keep the wheels tucked in as much as possible. I'll be picking up my wheels within the next 60-90 days and will post pics when I have them.
    1 point
  2. There was some conversation in other topic about blade type rollbar. So, i have one like this. 32x3mm cro-mo tube and 260mm blades. Blades are 35 to 25mm wide and 6mm thick, steel of course. Bar itself is more just a link between blades. This type rollbar works mainly with blades, i.e tube is stiff and blades are flexing (if they do) It depends how they are adjusted. If blade is vertical, it´s very stiff, horizontally they are pretty flexible. Any position between those, are something between, ofc. To adjust, just loose bolt (most left head of blade) and tur to desired position. Or attach cable and make remote control.
    1 point
