Last bit of body work was the hatch slam. I did not replace it entirely. After getting a Tabco replacement and then a classic fab replacement, I decided mine was not bad enough to justify changing the entire part out and reducing the originality as the replacement parts are not a 100%
The original paint
Drilling out the tack welds
After drilling out the spot welds and cutting part of it away, I blasted the undelay of framing. There was some corrosion deepen than I liked so I cut it out and patched it. Then ground it back and sprayed it with a weld through primer
Next I removed the rest of the panel, blasted it and replaced the little bit of rusted metal. Tig welded it and ground it flat along with some dolly work to make it flat after welding
I then tig welded the old spot weld location and ground them flat so it looked like a new panel again.
All the underserface of the rebuilt hatch slam got coated in weldthrough primer. I then applied a weld through seam sealer.
I used the old pc of metal to mark the exact location of the original tack welds
Final to tack weld it in. Looks great and factory original in my opinion
