Leaderboard
Popular Content
Showing content with the highest reputation on 01/02/25 in all areas
  1. Well, it took FAR longer than I hoped but the car is running again. Things that got finished -Rear seals done. -Oil pan got the OEM seal I forgot I had. Straightened the flange braces a lot. If it leaks again I'll go full RT -Replaced oil drain plug -Cleaned up some glazing on the flywheel and pressure plate. Clutch seems to be working well -Replaced throw out bearing while I was at it -Removed transmission dust cover on the back that made removing the driveshaft difficult. -Wiped down all oily surfaces including the exhaust, engine/trans plate, oil pan, trans crossmember, diff crossmember... -Engine oil got Valvoline VR1 20w/50 for upcoming summer weather next time I drive -Transmission fluid replaced with Ford Motorcraft XT-M5-QS manual trans fluid aka "unicorn tears" and very well liked in the Miata crowd. Supposed to be better than the redline MT90 I had before) In progress or needing extra work -Retorqued front crank bolt for now, but I think I'll have to replace that seal as well but it's only available online. I'll replace if necessary when I wire and properly do the electric fans -New coolant overflow tank hasn't arrived but will install as soon as it arrives to get things tidier -Waiting on a big C clip and wave washer so I can use the Nismo solid shifter. ISR shifter went back on with very light rtv for now. I plan on on somehow adapting the stock 240sx lower shift boot to the stock S40 lower shift boot bezel. Might require more printing or at least cutting from a sheet of aluminum or steel. -Driver window either got misaligned or off the track when I was rolling it up today 😢 doesn't seem to go down without way too much force. Little or no progress -Haven't installed the AC bulkhead plate, but I think I'll have enough time to at least do the interior lines and install the plate. Will cover the openings for now. -Still no radio/digital media receiver. We'll see if I can get something at least fitted to the console before I leave
    1 point
