Leaderboard
Popular Content
Showing content with the highest reputation on 10/04/25 in all areas
  1. My photo album for the build is located here: https://photos.app.goo.gl/FEXaWgYEMedA2FJv9 My first project car is a 1973 Datsun 240Z. Like many cars, it was mostly stock with a lot of rust when I bought it around 5 years ago. I taught myself to weld and did all the rust repair. I replaced floorboards, frame rails, and many small patches in the fender wells. Then, I rebuilt the braking system and replaced numerous broken or rusted-out parts. Next, I re-gasketed the engine, drained the fuel tank, and cleaned the fuel system. I took the car down to bare metal and tried a DIY paint job. After that, I drove the car for about 3,000 miles around town and on a couple of road trips. I had my fair share of trouble. I had to replace a fuel pump, the alternator only puts out about 12.5 volts, and the wiring harness is starting to show its age, and the previous owners that created a rat's nest. Recently, I purchased another project car that came with a lot of parts and swapped them on. I added TTT coilovers all the way around, Arizona Z Car lower control arms front and rear, Arizona Z Car tie rods, upgraded front sway bar, new front valance, fender flares, and trimmed fenders for clearance, Watanabe wheels, and Toyo R888s (215 front and 235 rear.) I also cleaned up the interior a lot with new door cards and interior trim pieces. Recently, I replaced the billet diff mount with a new polyurethane one, fixed a lot of my early welding, did a full engine service, got the door handles working promptly, and modified the exhaust because it hung about four inches too low. After this, I put about another 2,000 miles on the car. All this work has the car in pretty good condition, but there are still a few things left to have a true daily driver quality car: 1.) Fix the exhaust. I got it tucked up nicely, but between my poor welding and previous owners, there are several leaks, and it sounds terrible. 2.) Rewire the car. I have the brake, reverse, and running lights working. However, I have never been able to get the turn signals to work, and the gauges work very seldomly. I have purchased a 21-circuit harness from EZ Wiring and will rewire the whole car in the next month or two. https://www.ezwiring.com/product-page/ez-wiring-21-standard-wiring-harness 3.) New gauges. EZ Wiring sells new gauage kits. I'm not sure if the 50-year-old gauges are broken or if the wiring harness is bad. So, I think I'm just going to replace the gauges with a set I know will work with the new harness. https://www.ezwiring.com/product-page/shark-mechanical-gauges 4.) Re-attach the skid plate. I had cut the plate off because the bolts were rusted and stuck in the car. I fixed the plate by welding some washers on the bolt holes, but I need to drill out all the old bolts and tap for new ones. I don't have the car lowered that much, so I'm not too concerned about it, but it would be a nice piece of mind. 5.) Alternator. Ever since I have owned the car, the alternator has not worked properly. Recently, I had the alternator rebuilt with quality parts and bench tested. I know it works, but the car is only putting out 12.5 volts when running. I have played with the wiring and got the alternator to put out 14 volts, but then you can smell the wires burning from too much juice. Like I said, there is a rat's nest from the previous owners. I am at least the fourth owner, but I don't have a full history of the car. I have an FSM, but the wiring guide no longer matches because of all the other owner's work. This is why I plan to replace the whole harness. I'm hoping the new harness with better relays with fix my charging issue. 6.) Alignment. After I put the new suspension on, I did a garage alignment, and it is pretty good, but I would like a professional to take a look. I have that scheduled for next week. 7.) New Dashboard. My current dashboard is pretty rough. It has several cracks and looks pretty bad. I have a newer, crackless dashboard. When I rewire the car, I'm hoping to swap the new one in and put some sound deadening behind the dash while I'm at it. I'll post my progress if anyone is interested, and I'm sure I will have a couple of questions. I know the last finishing touches take the most amount of time. I'll also answer any questions anyone has, but I'll warn you that I'm a hobbyist. My full-time job is as a lawyer, and I'm by no means the best mechanic in the world. My welding has also gotten a lot better, but it surely isn't that good. Thanks!
    2 points
  2. As to keep the technical stuff a bit separate I decided to post the next bit as a separate comment. Last Tuesday I temporarily insured the car and drove it over the highway to S2 Classic Cars in Hengelo (The Netherlands) as they are a highly rated classic car restauration shop in the area with a beautiful showroom to booth. There I had the car thoroughly inspected in preparation for the APK (something like state inspection, MOT or TÜV). This gave me some good and also very bad news. The good news, my work on the engine paid off as the car drove great with good AFR readings while driving and an CO emissions gas reading of 2,4% of the 4,5% allowed for this model year. The inspector also noted that judging by the other reading the engine was very healthy and in great condition. The bad news on the other hand reviled that the chassis of the car was is much less of a condition. Both left and right frame rails are rusted thru which they tried to cover up at some point with underseal. They where also both dented badly in the front by improper jack usage and the passenger side frame rail had a big rust hole in it. To add on top of that the inspector noticed the rear axle was crooked. This caused the drivers side rear wheel to stick out more with an toe out and the passenger rear wheel to have way more negative camber. The inspector couldn’t find anything at this time underneath and suspects the chassis might be slightly twisted or crooked. To know for sure I will need to find a shop that has the proper equipment and reference measurements to measure to chassis. I’m quit mad about both these things as they will cost me a lot to fix (at least they are fixable so thank god). More over the car was advertised and sold to me as “…without rust and free from structural damage.” by both the seller and the auction company. The auction company even inspected the car before it got accepted into the auction and wrote the advertisement texts for the car. Because of this fact, and the surprise bill for thousands of euro’s, I’ll be taking legal steps to try and claim at least some of the costs of the repairs on the seller and auction company.
    0 points
