Its been an exhausting month of hard work getting the chassis in Epoxy to move it back home before the end of the month.
Here is the process.
1.) strip all factory sound deadening/undercoating with a scraper, heat gun, wire brush.
2.) clean any residue with paint stripper and after-wash solvent.
3.) strip original paint from body with Citri-Strip paint stripper - again clean with after-wash
4.) remove interior tar paper with dry ice and liquid nitrogen.
5.) wash and clean entire body with Mastercoat metal prep - phosphoric acid rust neutralizer https://nomorerust.com/collections/metal-prep-rust-remover-products
6.) sandblast all seams and overlop joints.
7.) brush Mastercoat rust sealer primer into all seams and nooks https://nomorerust.com/products/mastercoat-ultimate-permanent-rust-sealer-silver-primer-original-sprayable-slim-quart
8.) lightly blast the floor pans with white aluminum oxide until white metal
9) brush 3 coats of Mastercoat rust sealer primer on to floors
10) blast the internal frame chambers clean and blow out any sand
11) spray the internal cavities ( rocker panels, rear fenders, rear internal quarter, and front internal cowl area with Matercoat using a 18 inch long extended tip spray gun https://paascheairbrush.com/collections/extension-spray-guns?shop_consented_scopes=email%3Averified+openid+pay%3Asession_token+profile+shop%3Aaccount_uuid&shop_sign_in=true using a 360 degree spray tip to coat all surfaces
12) sand the entire body removing any Mastercoat not reaming in pits or detents
13) sand the entire external body shell and underside with 180 grit and clean with wax and grease remover
14) lightly blast entire body inside and out until perfectly clean and lightly textured to promote adheision - holding the blast nozzle 12 to 15 inches away at 60psi with white aluminum oxide
15) hours blowing out the remaining grit
16) again using 360 degree long extension spray gun, paint all internal cavities and under sides with DPLV Epoxy Primer
17) Spray entire body inside, outside, underside with 2 coats of Epoxy
Ridiculous amount of hours
https://www.youtube.com/watch?v=y-kogRrJYJU
