brianZortiz
Donating Members-
Everything posted by brianZortiz
72 or 73 240z Japanese / Euro Tail light wiring
brianZortiz replied to brianZortiz's topic in S30 Series - 240z, 260z, 280z
Oh, I think I figured it out. I do need a 3 wire bulb on the inner upper bulb to make the top two lights as brake lights. Per my first picture the 3rd wire on inner upper would be G which is shared with outer upper and outer lower, this is how early 240z's are. I need to snip top two G wires and run that to the brake output wire which I changed to GY on the picture which is Green / Yellow the color of brake switch output wire. Should look like this to make it work: -
Hi All, I am close to finishing up my 72 240z and doing finishing touches, the last being JDM/Euro spec amber tail lights. Since the car is not going to use many functions going to the rear of the car I decided to wire it myself just for tail lights, rear side markers, and license plate light. The issue I am running into is how to wire a 72 or 73 4 pin 2.8mm spade connector tail light sub harness? A lot of the information online seems to be for early z cars with a 4 pin 6.3mm spade that has 3 wires on each of the upper bulbs. I know that I need to run an independent wire from the brake switch output wire that goes into the turn signal switch. The wire is Green / Yellow; all good there, but not sure how to modify the tail light sub harness. A post on ClassicZ by Arne: https://www.classiczcars.com/forums/topic/32228-modify-us-240z-rear-turn-signal-wiring-jdm-style/ is helpful, but the first reply from OniZ mentions to make the lights work I need the early 240z 3 wire bulb socket on the inner upper bulb... Is that correct? Picture attached is my 72 240z sub harness and as you can see the inner upper bulb is 2 wires only. I know Green / White is running lights, but not sure if it's brake light too. Also, Green wire on the sub harness is Green / Red or Green / Black on the main harness which are the turn signals, but also not sure if they are brake lights also. Can anyone help? Do I need 3 wire upper inner bulb or can I make my current sub harness work? Looks like I need to snip G from upper right bulb so only 1 wire goes to turn signal for Amber which is bottom right, but not sure about anything else. Goal is to have running lights and brake lights for 2 upper bulbs and just turn signal light on bottom right.
@ZT-Rwhat are you doing for oiling?
Removing door with engine installed..Ok to do?
brianZortiz replied to brianZortiz's topic in Body Kits & Paint
Thanks all for the input. Feel a lot more comfortable removing the doors now thank you, brian -
Hi All, I drove my 432 inspired z for a few months, and now want to restore the car. Is it ok to remove the doors with the engine and transmission still inside the car? It’s an rb26 so a bit heavier than L series. I’ve heard someone mention body sag a long time back, but not sure. I want to send out doors and panels to my body guy while I have the car sand blasted
Thanks all for suggestion. I will go with cutting the potted rust and putting fresh metal. Plan on having this car for a long time. I’m in Datsun parts and needs. Thanks for the link, but it seems they don’t advertise the bottom side of slam panel which is pictured. The top I got from MSA
Hello All, fixing rust on my 72 240z and found a good amount of pitting under the rear slam lid after removing spot welds. There was a hole which my welder fixed (third picture) but not sure if I should fix whole pitted areas or just prep and Por-15 it.
Please delete post wrong section
RB26dett transmission HELP! & 32 vs 33 engine
brianZortiz replied to brianZortiz's topic in Nissan RB Forum
Yah I saw this video and the part 2. Still have many unanswered questions. -
Hello All, I am ready to Order an RB26DETT, but am having a hold up on transmission. I have read the forums and searched, but most of my answers come in the form of pictures, but I am not able to see since the Photobucket account thing. The RB25DET is 5 speed is at $1,800. I know I can use a Z32 NA/ Turbo or a Z31 87-89 Turbo transmission for the swap, I just need the Rb26dett bellhousing. It seems from my research the Z32 will need the shifter bracket modified to line up with the shifter hole, I really would not like to cut to enlarge the hole. My question are: Will a Z31 turbo (87-89) 5 speed work with the CXracing or McKinney Motorsport transmission mount for the s30z? Will the transmission shifter line up correctly to the Z's shifter hole? Same questions for Z32, will mounts work? Where can I buy a modified bracket to fit Z's shifter hole? What about the Rb25det transmission? Will the shifter line up to the Z shifter hole? I just want to prevent from cutting trans tunnel. Lastly, Should I buy an R32 Rb26dett or an RB33 Rb26dett?? I know the 33 has a bit more torque and a few minor changes. The difference is $600 more for the R33 than the R32. Is worth dishing out the extra $600? Thank You, Brian
Ktm, how did your car turn out?
Thanks for your input guys. I am happy it isn't anything major. I will try to look for a shop, i'm sure I'll find one in Los Angeles. Bo, do you which shop you ultimately went to? I met you at a korean bbq z meeting.
Chrome is the best thing I've done for my computer's.
Hi everyone, My friends Z got into an accident. It was a minor accident where it was rear ended without having his rear bumper. The crash was fixed, but was still left with this unaligned door to rear panel when the body man said the frame was pulled. The body man said he is going to try a bit more but does not want to "overpull" the frame. It seem like he fixed the dents with wire weld slide hammer. Is there still hope with frame pulling after the creased dents have been fixed? What is the best method to try to fix gap on door to rear quarter panel. The door is in its place, the only thing is rear quarter was moved some forward by hit. Thank You.
my new 16x10 Rs Watanabes. Custom
brianZortiz replied to brianZortiz's topic in Brakes, Wheels, Suspension and Chassis
Whats the difference between f8 and RS models? -
JDizzy. We talked before. Alex showed me these. Looks great man. I might have to do that later on. But now I'm in love with what I have. -
Nice, hard to find skilled people to widen wheels. Eric cut the wheel and got another half and heat sunk the wheel onto the wat. He insured that it would be strong. He said he welded it to make sure no air leaks. He cut a groove on original wat lip so wheel can sit properly and heat sink. -
Thanks s30z aficionados. I will be using 245 45 16 fuzion zr1 in the rear and 225 45 dunlop direzza up front. The 225 will be replaced after some driving to 245 45 all around. It's true 16" tire options are not good. I will be using bridgestone potenza re-11 or Toyo Proxes T1R. Both come in 245 45/16. I think a big push from porsche guys has increased the demand for 245 45. A lot easier to find than before. Polishing cost $30 per wheel Widening cost $220 per wheel. BADLER, They mirror polish at the factory? -
Hey hybridz. I just picked up my 16x10 rs watanbes from Eric Vaughn machine out here in SoCal. I had him widen my 16x9 -13 and add 1" more lip. I will be using 16x9.5(stock) in the front and 16x10(custom wide) in the rear. I then had the lips mirror polished. Removing the previous machined lip. If you guys have any questions, feel free to shot them at me. As many of you know, Watanabe only goes up to 9.5 in their 16" wheels. I needed more lip and aggressive style to my wheels so I decide to invest some more. First Pic is stock 16x9.5 and the rear is custom 16x10. The second pic is after they were polished.
Badler, I am not selling 16x9. The 16x9 just got widened to 16x10 by adding 1" of bigger lip. They came out insanely nice. Will share with later.
Buy from Kiyo, he is the watanabe distributor. I met him in person and is a great guy. In live in LA where he is from and paid half at front and the other half at delivery. Didn't hurt me financially, but he did this with me since I met him and paid cash.. I got 16x9(will be going 16x10, custom) and 16x9.5. I paid $2440 cash. His number is (626)627-3555. He is not the middle man, he is the source in US. It's a 3 month wait.
AZC vs Datsun parts LLC big brake kit
brianZortiz replied to ECUAdam's topic in Brakes, Wheels, Suspension and Chassis
The AZC are a bit larger than the TTT front BBK if i'm not mistaken. Can you get drilled cross rotor with AZC? -
Hi, I have 2 pictures that I need in order to finish a little side project I am working on. I pulled these 2 pictures from the internet and want to get rid of the backgrounds and have a consistent color on the paint, i.e no reflections. If any one who is good at adobe illustrator or photoshop can help me out, I can flow over some small cash via paypal. Hope some one can help me out. No reflections and no backgrounds with a solid red and solid black color for both cars, respectively. All while retaining body lines. Thnaks!
