KAZU
Everything posted by KAZU
  1. Remote oil filter is FRAM HP6. I didn't think I can put this huge into S30 engine compartment. Here I found some space. Filter replacement job can be done without mess. My stock of -12 hose limits the oil cooler location. I hate Earl's. Assembly of -12 hose ends needs arm wrestler. My favorite Russell nylon braided hose
  2. Intercooler is from BNR34. Lower brackets were welded at the tow holes and upper brackets were made to be bolted with bumper by its brackets. Left side. Some welding was needed. I don't have any tube beader but I thought a bead roller for flat sheet metal may be used if the tube is large enough. After some practice, it worked. Tubes are assorted mandrel bent and 3 bent cast pieces. This is the only one had to be welded. Left side. Right side. Single air filter should be located around there.
  3. Engine shifted to the driver's side by 1" with Z31 engine mounts. So I ended up cutting castleman's RB30 mount. Left mount was cut to clear the front turbine oil outlet tube. Both sides of 240z mount rubber were replaced by RB rubber. Engine bay got painted. I chose plain gray for my 240z. I really hate painting. Exterior will be covered by 3M film. Brake rotor is 13-1.25" heavy duty directional vane from Coleman. Rotor hat is Wilwood for De Tomaso Pantera and caliper is from 1st gen Viper. Hub from Z31 turbo. Strut upper mounts are modified to gain caster angle. Brake tube and clutch hose is routed behind the front member.
  4. KAZU
    hoodridge painted
    Some rust was sanded out and painted with lacquer spray can.
  5. Castleman engine mount and stock rubber insulator were replaced with PZ31 mount and rubber. The holes at the engine crossmember do not match well and entire engine sits driver's side. Also, engine is located higher than I thought. So I modified the left side mount and rechecked the placement. Engine still aparently sits on the left side. Next weekend I'll measure chassis dimension at first and find the right way to solve the problem.
  6. Wheel trial fit. Stock size ZG flare does not cover the 18"-10" +38 for track use. Mustang Bullitt, 17"-8" +30 for street with stock size ZG flare. Wide thin ply ZG flare from Marugen, Japan. Traced the outline and cut line. Stock fender was cut. Pieces of sheet metal were trimmed and welded to fill the gap between inner and outer. Result. Wide flare with 17"-8"
  7. KAZU
    p6
  8. KAZU
    p4
  9. KAZU
    p3
  10. KAZU
    p2
  11. Dash is from 1st-gen Mercedes C-class. EPS steering column, wiper motor and HVAC system are from Suzuki. Column combination SWs are from Toyota RAV4. Brake pedal is modified Tilton. Clutch pedal is Howe. Red knob next to the column is brake bias adjuster. Trans is S14 Silvia. 71C trans is known to be weak for RB26 but I can live with it for a while, no drag start or drifting. Dog gear with beafy mainshaft may be the next. Red lever behind the shift is proportioning valve. All hand brake mechanism from R33. All brake hardline is redone by 37 dgree single flare. Seats for street driving are from 996 GT3 (optional reclining leather). Master cylinders fit tightly between the frama rails. Aim MXL dash logger. A boost gauge may be added behind the clear acrylic panel (hardly seen in the pic).
  12. For a 50/50% street/track car, I chose an aluminium tank for street rod, instead of fuel cell. Tank, remote fuel filler is from Summit racing. Carter low pressure pump was too laud to be placed above the floor. Relocated there. For high-presseure pump, I picked a Bosch 044.
  13. The car has been repaired improperly and twisted a bit. Floor rust was not the problem. I cut floor and sidesil out, welded a set of thinwall rectangular tube (1" x 3") at the framerail and sidesil inner. Outer sidesil skin is the only one remained stock parts. Additional DOM tube is located above the rectangular bar for reinforcement.
  14. Diff (R200LSD), halfshafts, hub carreer, arms and parking brake system are from R33 GT-R. Brake disk is from JDM Skyline (Infinity in the US) V36 type S sedan. caliper is from R32. shock is Bilstein. Underbody must be deformed (cut and weld) I simply ordered the stock subframe rear hanger for Skyline R34. trimmed and welded. For front mounting, I gutted and welded the R32 hanger. I reinforced around the mounting point when floor and sidesil replacement was done.
  15. Last week I put RB26 in my 240z. Mount is currently Castleman's. It locate too low and far back. Z31 oil pan sits on the U-bolt of the rack. I found that Z31 mount was way to go for me. Estimated movement with Z31 mount is roughly 1" up and 1" forward.
  16. KAZU
    P1110445
    Modified Z31 oilpan sit on the U-bolt thing. The bolt in right-hand driven car is located another side. Castleman mount is originally designed for RHD.
  17. KAZU
    P1110453
    Current status. Castleman mounting was not good for me. It locate too low and rearward. will be replaced with stock Z31 mounts.
  18. KAZU
    PC130417
    master cylinders fit tightly between framerail and froor frame
  19. KAZU
    PC300430
    I'm scared of needles
  20. KAZU
    PC130418
    believe or not, this car is 240z
  21. KAZU
    PC060410
    I chose Bosch 044 for high pressure pump
  22. KAZU
    PC300428
    carter low pressure pump was relocate here because it was too laud to mount above the froor
