toolman
15
Everything posted by toolman
Heavy Duty frame rails and connectors
toolman replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
Managed to get in three hours to work on the Z. I installed the dog leg panel from ZDepot. Photo of underside of the dog leg panel. -
I almost made a mistake. When I was watching a video of 240z replacement of its rocker panel, I realized that my rocker panel had to be longer. So I constructed a new longer rocker panel section. This is a photo of what I can up with. Basically it is just longer than the old one. But the new rocker also had to be "capped" at the rear. Interior view of the new rocker panel. This pics shows the rocker panel welded in place. Now, templates were made to construct front upper and side step for the dog leg. This required three separate metal pieces to make this complex shape. Used a oxygen/acetylene torch with 1/16" steel rod as the metal was so thin. The finished front upper section of the door leg( three separate pieces of sheet metal welded together). The welded section was then welded to original dog leg and then painted with welding primer. -
After waiting for my replacement dog leg panel for a month, I canceled my order with them. I then ordered the panel from Z Depot instead. It came in one week. Now I can finished up the corrosion repair. I welded in the inner reinforcement panel and painted with welding primer. Now to fabricating the upper portion of the dog leg. First , a template must be made . Using a metal shrinker , the upper dog leg portion is created. With the upper portion mocked in, the next lower stepped area can made. The picture below shows the dog leg and this stepped area together. Next, the gap between the rocker panel and the dog leg must be filled. Another template for this gap is made. There is six separate bends that required. Even with a template, mistakes can happen. Just straighten it out and rebend it. Sometimes even with metal brake, you have to use "red neck" technology to get the job done. Almost finished, the patch and dog leg ready to be welded. The wheel opening end won't be welded yet as the new flare size has yet to be determined. -
After rotating the car to the horizontal position, I attached the two caster cross members. Pushing the car around was fine but I noticed that the rotisserie was wobbly when moved. So I decided to add a 1 1/4" galvanized conduit between the two ends of rotisserie to solve the problem. Two mounts were made to hold the 15 feet of 1 1/4" conduit. Two 5/16" x 1" lag screws held the mount to the cross member.A 3/8" bolt with welded nut holds the conduit in place.
The quarter panel dog leg section is still on back order from the manufacturer so I just do other body work for now. Next, the old metal reat fender flares must be cut out with acutoff wheel and air saw. Additional flaring work must wait till the new wheel and tire configuration is determined. Inside view of cut out fender flare The left rear quarter panel was stripped of previous paint jobs (about three) plus the original primer and color. To aid in paint stripping, the addition paint layers( besides factory ones) can be removed with a single edge razor. In this case, the top 3 paint layers came off in one' thick piece leaving only factory color and primer left behind. Since I had some extra time, I decided to add additional lights to my garage area. Two 4000 lumens Led Shop Lights on Amazon for only $30 each were installed. As you can see the two LED lights really brightened up the garage. I will probably add a couple more to light the sides of the car when I am painting. -
Returning to Low Cost Rotisserie topic after almost a year. Preparing my Z for media blasting. I decided to work on the rotisserie. As the car will probably be in the normal upright position for the most of the rest of the restoration, casters must be added to provide easy movement. Utilizing two 2" x 2" x 1/8" right angle shelving brackets formed into "U" shaped channel support between the two vertical supports of the rotisserie. Two 4" metal casters were added to bottom of the channel. Support channel is about 88" in length. Each side of the channel us attaches to the rotisserie with six-5/16" x 1" lag screws on both sides. Back view of front caster support channel. Each 4" caster has a load rating of 250 lbs. Pic of rear caster support channel These caster channels will be slid in position/ bolted down after car is in the horiziontal postion and jacked off the ground. These 4 swivel casters will allow the vehicle to be turned completely around with ease. Cost of casters was $10 each-Home Depot and shelving brackets were free(dumpster diving) A 2" X 4" board was cut down to fit in the center of the support bar and bolted to frame with four 5/16" x 2" lag screws. This was to provide additional strength when floor jacking on the bar. ' Overall view of addition to support bar
Returned Sunday from a convention in Las Vegas but managed squeeze three hours of Z work time in. As I was waiting for the front lower quarter panel leg, I decided to pull out two dents on the same rocker panel. To do this, a 110vt stud gun was utilized. The gun spot welds copper studs to the damaged area then the sliding grabs and pulls the dent out. Pic of crease on rocker panel. Another angle of stud pulling. If the repaired becomes "high" , there is also a shrinking tip that can be used. This flat tip will heat a small area "red hot" then tap this area with a body hammer down. Next, "quench" the area with a wet rag. This will create the shrinking action to occur and lower the area. Repaired area after grinding with#24 grit paper Pic of the other dent repaired with stud gun -
Back to rust repair-on Left Rear Rocker Panel. First pic shows all the dirt and rusted metal that was cut out. Pic of area that was worked on. What made this job harder was the rustproofing inside the panel. Scrapping took most of off then removed the rest with lacquer thinner. Then the area was sandblasted clean. My new curtains helped as they kept the media spreading even further. Rear view of repaired area. Also, found additional rust on wheel housing. Note-raised area above seat belt anchor bracket After sandblasting the area. Made temp[ate for panel patch. Note: the raised area had to be hammered formed. This was necessary so the patch would not touch the seat belt reinforcement plate. The factory plate has similar raised area. I also made the wheel housing side one piece to prevent future leakage. Patched the wheel housing area, I drilled a 1" hole near the seat belt bracket so I can rustproof this area after painting the car. 240Z usually had corrosion problems on front and rear of left/right rocker panels. I think more though rustproofing and urethane seam sealing will do a better job against corrosion. -
Richard Oben LS1 series 1 240Z build
toolman replied to Richard Oben's topic in Gen III & IV Chevy V8Z Tech Board
Camaro IRS swap Richard, Thanks for the Rapid Answer. Before I heard about some guys using Ford 8.8, I was thinking about putting in the whole rear suspension from a late model Camaro and basically narrow it to fit. That way you get a beefier wheel hub( although 5 lug). Also, it would limit machine work to shortening both axles. Most of late model cars use an independent rear with four bolt mounting system so it could be possible. I was looking for a wrecked Camaro so I could take measurements to even see if this swap was possible. But I got diverted to the paint booth build and still got more rust work to do. Anyway, somebody might already done the swap already. Toolman factory Camaro IRS suspension -
Richard, Looks like a nice installation! Roughly how much did it cost you? I am considering it for my car. What rear gear ratio are you going to run? I would guess about 3.90 with a T-56 trans. Is there a lot of these swaps out there? Toolman -
Picked up four intake filters 20" x 20" and four exhaust filters 20" x 20". Fabricated a metal frame out of some right angle 1/8" vertical shelve poles. I hung a 10" strip of sheeting about 3" in front of the curtain cable by stapling to the ceiling. The gap was necessary to allow curtain movement but be close enough to seal the curtain to the ceiling. With the fan running, you can see the fan pressure is sufficient to seal the curtains. Outside view -The garage door was lowered to the #1 exhaust filter frame and #2 block off frame. Inside view of exhaust filters The booth airflow test consisted of hanging thin strips of plastic sheeting in the air to observe its movement. As you can see, the test strip near inside exhaust filter is being drawn against the filter-indicates sufficient airflow leaving the booth. . The outside test strip indicates outward airflow also. After more testing, I found one of the exhaust filters had pushed out of the frame. So I added some metal screen on the inside to stiffen the exhaust filters. That seem to solve that problem. I spent a little more than $200 of materials to build to this booth( mostly from Home Depot). This booth suits my needs and requirements. I hope you guys found its construction interesting. Added screen wire to stiffen the filters. -
The photo shows the fan duct folded up and held in place with 3" wide strap. The strap is duct taped to fan body and the other end is velco attached to opposite side of fan. Extra grommets were added the area above the fan for more support. When the curtain is open and aligned with the fan, it looks like this. Once the fan is switched "on" , the incoming air pressure basically seals itself in the curtain wall. It works like those inflatable bounce houses for kids. When finished using everything folds up nice and neat. -
Decided to enlarge the booth size from 1 1/2 car to 2 car size for various reasons: more room to paint, left side curtain closer to fan and easier to use. Also, now the garage door does not have to be closed to utilize the curtains. The following photos show the improved booth design. After trial fit, 24" was removed from the bottom of the curtains. 4" was allowed on the bottom to be held by a 2 X 4. Made a duct out of scrap sheeting to connect fan to curtain. No sure how to attach duct to curtain. Might try putting the duct hose into another hose section attached to the curtain. Left curtain must also be modified for fan to blow through but still allow to be folded up. -
Sorry about the inconvenience, I deleted the Garage Booth-continued post and am reposting it here. Closeup of the right corner of garage booth It uses a 2 1/2" lag screw to fasten two 3/ 32" curtain cables in garage roof rafters. The turnbuckle provides cable tension adjustment. A 1" PVC pipe is used to be booth corner vertical support. It is slotted with a cutoff tool to fit tightly into the corner cable arrangement. The slotted PVC provides a stable vertical brace. Next a bottom mount of this PVC pipe must constructed. -
Right front side of booth Right curtain closed up. When the bottom of curtain is trimmed. the curtain close up into a much smaller bundle. -
I wanted my spray booth to be easy to utilize and store away. After searching the Internet for ideas, I decided to just build the booth that would be the best fit my situation. The booth would consists of basically four 5/16' x 4" lag screws inserted into the garage rafters. One reason being that this method will completely clear the garage door when it is closed. Also another advantage of this design is its versatility. The booth dimensions can be changer just by moving these four bolts and 3/32" cables. I used plastic sheeting 25' long x 9' high and 6 mil thick. I think the thicker sheeting is superior unless the booth was going to be used only once. The top edge of the sheeting was folded over 2" and glued to add strength. General Tool 3/8" brass grommets were installed into this edge area. They were spread apart 24". More grommets can added if necessary for support. A 5/16" x 4" lag screw is installed in the garage rafter. All four 3/32" cables has one 5/16" turnbuckle to adjust tension to prevent sagging.The rear and right side booth walls assembled. Note that final trimming of the bottom edge of the sheeting has not been done yet. Still waiting for sheeting top hooks to determine final height. -
Sorry for not posting in awhile. Had rewire my Honda ATV, paint patio railings and my wife hit a parked car. Then we went to Hokaido Snow festival in Japan. Nismo Festival had all sorts of Nissan car-street to race carsDrifting is very popular in Japan. Probably because it does not require a large race track. Also, the locals can participate in drifting as it is not as costly as road racing and use basically flat and empty parking lot. Now back to the Z project. I decided to make a temporary paint spray booth in my garage. It will be only for epoxy priming for my Z. Not sure how radical that I will go with this booth. Might use 1 1/4" PCV pipe to build the booth frame. It will have intake and exhaust filters and lights probably LED ones. As you can see,it will be a positive pressure booth. The main reason for the booth is to prevent epoxy primer from going on everything in my garage. That stuff is impossible to clean off. My Man Cave is getting more elaborate quickly. inside view of booth fan Outside view of fan with louvers open -
Doing some of the small welding stuff before wet media blasting. Stabilizer mounting holes Two 8mmx 1.25 nuts welded to 1/8 x 6" steel plate This mounting was taped to 3/16 tubing to install in frame tubing. The two bolts are loosely installed. the tape is scrapped off to remove braket off tubing, Both bolts are tightened down. Then each bolt is removed and checked individually for hole alignment. With alignment done, the mounting plate is plug welded to frame rail. I hope this additional details were helpful to someone. -
Finally got some time to work on the Z again. This is after a trip to Japan, Holiday stuff, get the scooter running and fixing the house drain pipe, Used couple of days to remove the rest of the undercoating and paint on the bottom side of the left rear wheel well and quarter panel area.Looking up from the ground to left/rear quarter panel These areas were covered with thicker than factory underseal so made it more difficult to remove. In case, you are wondering about the brazing in the upper portion of the r/wheel well- this is old( 40 years) sheetmetal extension from wheel tube to the added metal fender flares. This area might have to be altered as the new tires might be 245/40 x 17 with 12" wide wheels and new flares might have to be set higher. -
As if the Holidays wasn't keeping me busy already, I had a plumbing leak in the house to repair. But I managed to work on my car. I wanted to "box in" the tension rod support area. I painted the inside of the box with black paint. I used 16 gauge metal for the inner and outer sides of the box. The interior of these pieces were painted with weld through primer. Then they were tack welded in place.Then it was covered by self etching primer to prevent corrosion. I can across a deal that I couldn't pass up. A 2013 Chinese 50CC 4 stroke Moped for only $200. It has only 10 miles on the odometer!! It wasn't running but had compression. Probably carb or ignition problem. Merry Christmas, everyone!! -
Richard, Love to see more information and pictures of your beautiful project car when you have the time. Sunny -
The car was p[aced on its side to remove rear undercoating. This area is really tight to remove the undercoating. Mostly the undercoating had to heated with the heat gun then hand scraped off. The air scraper was used only on large open areas. After scrapping was done, the 4 1/2 grinder with wire wheel removed most of the remaining underseal.Then the area was media blasted with Number #60 grit abrasive. This media is one step rougher to remove heavy underseal in tight areas. Even so, I had media blast this area several times to do a decent job. -
I needed more room to better job sandblasting so blocked off the front hatch area.Put a large plywood to hold up the blue tarp covering the open hatch area.Richard, the spare tire area was cleaned. Saved for now. After blasting, all seams were clean out and spot welded. This area will be primed with self etching primer to prevent corrosion. -
Hatch section was masked off carboard,plastic sheets. duct tape and plywood to control sandblasting. Used a plywood sheet to lay down on to do the sandblasting. It was tight and hard to move around and blast. After blasting, still more cleaning necessary. I haven't decided about the tire well yet. But am leaning to remove it and replace it with a fuel cell. -
Decided to beef up the seat mounts and keep them off the floor to prevent corrosion. I utilized 1" square box tubing with reinforcing plates on each end. Even if I go to different seats, these mounts should be a good base to start with. driver's side mounts passenger's mounts. Thanks Richard, most people don't realize how much work is actually involved in this type of build.
