Ok I have so far purchased the following and I'm looking for any other ideas anyone might have.
TEC3 Distributorless Engine Management
Tripple Side Draft Throttle Body Fuel Injection Intake
45mm Throttle Bodies for Intake
550cc Injectors
Bosch Fuel Pump
Custom Fuel Rail
Rail End FPR
(The above is part of a kit from Top-End Performance)
Stainless Steel Intake and Exhaust Valves
4 Core Aluminum Radiator
Adjustable Cam Sprocket
Sectional Aluminum Oil Pan
(Above from ArizonaZCar.com)
ARP Main Studs
Stainless Steel Engine Bolt Set
LD28 Crank
L24 Rods
KA24E Pistons (Flat Top)
(Above from EBay)
ARP 8mm Rod Bolts
2.0mm Metal Head Gasket
Stage II Cam (Grind: 17033. Lift(In/Ex): .480/.480. Duration(In/Ex): 274/274)
Rocker Arm Kit
Performance Valve Spring Kit
.160" Lash Pad Kit (Matches Cam)
MSA Aerospace Coated 3 into 2 Header
(Above from ZCarParts.com)
I have body and suspension parts as well, but I'm looking at getting the motor right first. Anyone have any suggestions, ideas, experiences to relay? This is the first time I've rebuilt an engine, much less built a performance engine. I'm planning to have the head ported (N42), intake and exhaust and having the crank balanced. The car is going to be driven on the road, hence the 2mm head gasket so I can still run pump fuel.
