jimzdat
Everything posted by jimzdat
For mine (pics are at the website--click the link below) I used an engine hoist to pick up the entire shell (yes, it will work if you use the right straps and chains) then attached everything to the car, set up the end pieces, and was done
Keith, my puter nuked and I lost your snail mail address--send it to me again, and I'll shoot you a SASE so I can post your plans for you jimzdat@earthlink.net Jim
Keep an eye out on ebay--I got mine there a month or so ago. I'm going to be getting some pics of it pretty soon, so I can send them to John Washington--he is considering doing a mold if there is enough interest
Well, the carbs and trans are sold now, but I've still got the motors (on ebay, but no bids yet)
Yep--we got a little airport here (McCarran field or something like that)--mot sure of the layout though. Since you're essentially local--know anyone that's looking for some L6 stuff? I'm getting rid of some of my spare stuff (motors, trans, carbs, etc) and if there's anyone down there looking, it would save on shipping. Check the forsale forum--I posted the stuff last nite
I'm close at least--Jackson's only an hour away
The T fitting idea might work, as it will allow some of the pressure to bleed off and return to the tank. The idea of "get a bigger damn hammer" adjustments to carbs always makes me cringe, but I can see where the idea comes from--he is thinking that the float may have stuck, keeping the needle/seat from closing; which is possible, or you could have a float that has "sunk"--some Webers have brass floats (in which you can hear the fuel sloshing if they leak), others have one made of some other substance I can;t think of the name of right now, and they can soak up fuel over time, and cause the same problem. Combine that with too high a fuel pressure, and you end up flooding the carb out. (About the regulators--I may have been a little too opinionated in my other post--in a pinch, the cheapo ones will work, they just tend to have a higher failure rate, so if you can find one of those, go ahead and useit--just keep an eye on things, just in case) Jim
From my experience, (have run both the dual DGV setup and the triple DCOE setup) most Weber carbs are very unhappy with anything over ~4 psi fuel pressure--you definitely want a good quality reg in there to keep everything under control. Stay away from the 19.99 regs, they will usually crap out after a few months, then you're just spending more money on it--buy a good Holley or equivalent. If you can't find one locally, places like jegs or summit sell em. Another thing you can try is "Grose jets"--they replace the needle and seat assembly, using 2 little balls to shut off fuel flow--I've got them in my SU's, and they work great. At one time, Ztherapy used to sell the Grose jets for Webers, not sure if they still do or not. Good Luck, Jim
Thanks, guys--I was afraid of the durability of a paint--Lone, I think you may be right about a powdercoat--that stuff should last forever if done right. I picked up a set of old Mickey Thompson valve covers for my truck--just trying to think of the best way to refinish them. Now to try and find a decent powdercoating shop in West BFE Tennessee Thanks, Jim
Anybody know of a source for the "crinkle" finish that you see on valve covers and stuff like that? I've tried searching online, but all that comes up is wallpaper places I'm not even sure if this is a paint product or some sort of powdercoating type process, so anybody who knows more about it than me please chime in Thanks, Jim
There are a couple of places you can get replacement framerail/floorpan assemblies from, it all depends on how extensive the damage is. You may want to consider subframe connectors--check Pete Paraska's website for a good example of those. Some sort of stand would probably be best to keep everything aligned while you cut out sections of the car--it all depends on what you want to do--you could fab up some sort of jig to hold everything in place, or you caould go all out and build a rotisserie that would allow for easier access to the undercarriage. Search for "rotisserie" here in the forums, this has been brought up a couple times (a few by me) and there are a couple of posts with pics. Or you can check on my site, got a few more pics there Jim
Try www.waytekwire.com --they have a fairly good selection of wire, along with all the "weather-pak" connectors and stuff like that. Plus, they'll even send you a free catalog
Here's the diagram I used for doing my swap: The only things I had to change is where the diagram says "To +12v through fuse from lo/hi beam"--you run just one large wire (with fuse) from battery (or starter, whichever you prefer. Where the diagram says "Ground" (down at the bottom)--you actually want this to be +12v, when you trun on the light switch. And where it says "From OE lo/hi circuits"--use the wires that go back to the dimmer switch (not sure of all the colors, since my wiring is no longer in the car) HTH, Jim
Hey RXO, I used 30A relays with my lites (both 80/130 & 55/100) They should be able to handle the current load without a hitch. 40A relays are harder to find, which can be a bad thing if you have one burn out in the middle of nowhere--I know around here, I can get 30A relays anywhere they sell fog/driving lites (Autozone, Walmart, etc.) Jim
For those of us with urethane bushings...
jimzdat replied to BLKMGK's topic in Brakes, Wheels, Suspension and Chassis
Where are these part numbers from? To me, they look like they're from McMaster-Carr (http://www.mcmaster.com), but I figured I'd ask just in case. Thanks, Jim -
So, do we get bonus points for using the word "reiterate" more than once in this thread? Or do we have to throw in a "conundrum" or two to get the bonus?
Just a note on the H4 lights--I have a set of Hellas that were in my 76 before the teardown--you will find some sites selling extra bulbs in some high wattages--don't bother with it--I tried running the 80w lo/130w hi bulbs in mine, and they work great--awesome visibility, and you can fry the retinas of anyone who dares flash their lights at you--the problem is they have a very short lifespan (due to the heat level the filament experiences, the vibration of the car beats the heck out of em) I replaced my bulbs 3 times in 6 months, finally just went with the 55w lo/100w hi, they lasted another 6 months (then I took the car apart, so I don't know how much longer they may have lasted) But I'll re-iterate what BLKMGK had to say--USE RELAYS--they will be the best improvement you can make to your lights. Aside from the search function hree, check out the wiring diagrams at www.rallylights.com he puts it pretty simple for you Good Luck, Jim
Rick--I tried to send you an email, but it bounced back--send me your snail mail, and I'll try to get a decent copy made and send it to you. jimzdat@earthlink.net Jim
Terry, you might want to check out some of the info on www.grandprix.net or www.clubgp.com there are a lot of people doing mods to the series II motor (also used in Grand Prix GTP models)--they may have some info as far as how much you can get from PCM mods, etc BTW, if I recall, there is no plug-in chip for the PCM of those cars, you basically have to buy a complete reflashed unit Jim
and now, the 64 cent mystery question--got any pics of it?
Craig--have you tried places like McMaster-Carr www.mcmaster.com or Grainger www.grainger.com ? McMaster is a little easier to deal with, as you don't have to send them a copy of your business license, right arm and first born like Grainger, and they are fairly reasonable on shipping to (HQ is in Atlanta) Good luck finding 'em Jim
Congrats JT! The one I won should be here in a couple of days, I've gotta take some pics and send them to John Washington, then we'll determine what the next step is. Enjoy! Jim
Terry, I know there are a few minor changes in the timing covers (fuel pump mount, dipstick location, maybe others?) but I can't remember what years/applications had what. You might try looking at www.enginequest.com (go to their "online shopping" link) they sell rebuilt and new timing covers, and you might be able to check out some of the differences there. Jim
Well, the guy shipped it today (going from OK to TN--shouldn't take too long) When I get it, I'll see if I can figure out just how much clearance it gives. I'm not concerned with clearance myself, I just like it better than the vented hood my car came with. Jim
Honestly, I don't think there is much of a web presence for them. However, Courtesy Nissan has much of their catalog online-- www.courtesyparts.com There should be a link on the main page to get you to the catalog Jim
