jimzdat
Posts posted by jimzdat
Call Jeg's--they have a 10-pt kit available for the 2+2
I have one sitting in the basement waiting to be installed in my car--they run around $300 shipped
Ummm, if you try going to the URL associated with those pics, it wants you to log into the email server for a domain--might want to check that again
Welol, I tried emailing it to ya, but AOL kicked it back saying that you aren't allowing attachments; so I just put it up on my site for download instead:
http://www.jimzdat.com/images/turns.jpg
Jim
I've got the manual for the 76, and a scanner--would that be close enough for ya? I'm not sure what (if any) differences there are between the two
Jim
Well, I don't have any specific links, but one place to start looking is on the truck and mustang forums--my 91 Bronco has an 8.8, and I know there are people who wanna build em up some.
Maybe try http://www.fullsizebronco.com or http://www.ford-trucks.com or http://www.corral.net for a start--check out the links pages and ya might get lucky
OK, got it put up now:
http://hybridz.jimzdat.com/gtr_manual.pdf
For you IE guys: right-click, save as
For Mozilla/Netscape: right-click, save link target as
If you're using some other browser, you're on your own
I've got 10GB of bandwidth per month, if I get to the point where I get my "80% traffic alarm" email, I'll pull it until the next month--just so everyone knows
Jim
I'll get it put up around 7AM (eastern time)--gotta wait till I get home from work
I've got it on my home PC, and can burn it for you no problem.
email me your address and I'll get it sent out to you tomorrow morning
If anyone else needs it and it gets pulled offline, let me know--I've got plenty of webspace for it
Jim
Working good for me also (don't really need it, but can't resist a download like that)
I'd tend to agree with the above post--probably a memory problem on your PC--what's the specs on it?
And for those wishing to do a wiring harness upgrade, here's a basic diagram for that: (not my diagram)
I modified this diagram slightly so I could use the stock dimmer switch easier:
1-Where it shows the Ground connected to terminals 85 on the relays, run 12V instead, switched on by headlight switch
2-where it says "from OE circuit" hook up wires from dimmer switch--dimmer switch will now ground one relay or the other, making lights go on
The whole writeup can be found here:
http://catalog.com/susq/other/headlamp.htm
FWIW, this is the place I bought my Hella H4 conversion from--excellent service, and decent prices--would definitely recommend them.
OK, it's really basic (took me about 5 minutes in MS-Paint) but here's the basic circuit for the lites. Some components are not there (fusible links, ammeter, etc) but this might help.
Jim
The headlight switch provides 12v to the lights (via the fuse block-1 for each light)
The dimmer switch is what controls the ground--make sure you don't have a loose connection there, and that the ground wire is hooked up under the column.
I've also seen the solder joints on the dimmer switch break on occasion
HTH,
Jim
Guys--read the rest of the editorial, especially the last couple sentences--he says the "by the way, one of the above statements is not true" or something like that--I'm thinking he was just trying to see if people were paying attention or not
I think the seller has the year right, but not the model
If it's an 80, then it's a ZX, and I think they did have a little locking storage area back there
Guess we cant expect the seller to actually read ALL the letters on his car....
I've done this swap to 3 of the Z cars I've owned, so I'll try and remember what the heck I did.
I always used the 5 speed from a 77-78 model. There are different ratios available in the 79-83 models, but I can't remember exactly what is better (think it was the %th gear ratio)
Parts you will need:
Clutch slave cylinder
Clutch master cylinder
Metal line to connect the above 2
Flex line at slave cylinder
clutch and brake pedals from a manual car (most of the brackets are already under the dash, just need to switch the pedals around)
shifter
metal plate that goes between engine and trans
flywheel
clutch kit
On some 240's, you have to do some trimming of the shifter hole to get it to work right--can't remember the specifics though
I'm sure there are some little tidbits I've forgotten, but I'll try to update as I remember them.
Overall, it's not a hard job--the last one I did took me about 3 hours total, but in all honesty, I've been wrenching on cars for 20 years, so your results may vary slightly
Good luck,
Jim
If you want something fairly quiet, do NOT get the twice pipes system--I bought one (it was cheap) and did not like it--my dad described it as "a cessna flying 3 feet off the ground at full throttle"
I had a 2 1/2" pipe run to the rear (had a header, so it came right off the collector) and hung a 4" supertrapp on the end--that was about half as loud as the twicepipes system
Uh guys, it might just be me, but I would think that if you don't want people to respond to the posts, why not just lock them? IIRC, they can still be left as a "sticky", and it fixes the problem of people posting BS responses all the time
Don't get me wrong, I think the above-mentioned posts have been on some very good topics, and contain a lot of valuable info (and will hopefully help weed out the unwanted, especially Bob's latest post)
Just trying to help keep everything cleaned up and avoid a bunch of extra posts
Fire at a transformer that is part of a ConEd plant--since I work at a power plant, we heard about it about 2 minutes after the grid went down.
Basically, the region was just overloaded, and the surge caused by the loss of the transformer is enough to take the grid down.
On the plus side, the price we were selling power for doubled right about then too
The EZ Wiring kit is actually pretty good quality, and easy to use--all wires are marked every few inches, and the bundles coming off the fuseblock are well organized.
My buddy and I installed one of their kits in a 48 Chevy truck last year--took me a couple days to have it all laid out and routed the way we wanted it, and then it was just a matter of making all the terminations
definitely worth every penny, and probably just as damn good as the painless one
With a roof rack it MIGHT be able to, but I don't know if I'd want to risk it--the metal isn't all that thick, and depending on where the rack rests on the roof it may dent it.
I suppose a lot of it depends on the kayak also--whitewater or touring?
My wife and I have a couple of touring kayaks (Perception Carolina 16 and a Perception America 13.5)--combined weight is just over 100 lbs; not sure I'd want to put them on top of ANY car, much less a Z. I looked into getting a rack for my Bonneville, but that would have been close to $300, and no guarantee that it would have held up worth a damn.
So I just put em on a trailer behind the Bronco--dont have to lift em as high that way.
They route air into a duct along the underside of the fender, and into the passenger compartment--when you pull the vent knobs down by the kickpanels, you are allowing fresh air into the cabin thru these ducts
Jim
i'm too much of a nerd, i was expecting a post about RAM
Same here--I thought he just left off an "M" in the subject line....
The life of a geek
I bought a set of carbs from ZTherapy just before Scott sold it--I don't know what exactly MSA is selling, but the ZT carbs are not mere rebuilds--there are some mods done for reliability:
new throttle shafts
bearings for shaft
stuff like that--chances are the MSA ones still have the old bushings in them.
When I bought mine, I actually bought just the main carb bodies, and swapped over the rest of my parts--but they worked just great.
A friend of mine bought one of the early sets from ZT (set #12, to be exact) and we were able to bolt em on and start it as soon as the fuel bowls filled up--a few minor mixture tweaks and they were working great.
IMHO, buy the ZT carbs--don't think you can go wrong with 'em
Thanks Clint--maybe we should ask a moderator to put this up as a sticky or something, so people will see it?
JPEG downsizing?
in Non Tech Board
Posted
Joe, he did that for a reason--there are a bunch of idiots out there that use software to scan thru webpages and forums looking for email addresses so they can put em on spam lists. Writing the email address the way aux did keeps that software from finding it, therefore keeping him off one more spammer's list.
If you would, please edit your post (or have a mod do it) so he doesnt get screwed
Jim
