Everything posted by Ron240zxt
	hello all, Im changing the mounting of my radiator and was wondering what some of you have done? Its a griffen raditor with a single mount on the top, I personally dont like it this way. So i've received some Aluminum Z channel, To possible make my new mounts. The other way actually warped the radiator its no longer flat , any suggestions on straighting this thing out again? Thanks Ron [/img]
	Hello Jt, Im running the Je Pistons and actually really happy with the workmanship of these units I ended up getting mine from Rebello Racing in CA. They had a good turn around.. I ended up going 88mm and moving the pin height to allow my 240z rods to work. So far so go (knock on wood) Well if you need any numbers let me know Later Ron
	Well that picture didnt work . so figure ill try to explain whats going on. Im in the process of putting new .190 lash pads in my Datsun, and setting up my camshaft, question i have is this, whats a good place for a wipe pattern, right now its about 0.065" toward the tip and 0.114" toward the pivot point. I know its not centered, just by the measurements. but was wondering if this would work in this vehicle. Thanks for the input Ron
	http://photos.yahoo.com/bc/roncrown@sbcglobal.net/vwp?.dir=/My+Photos&.src=ph&.dnm=Camera+pic+173.jpg&.view=t&.done=http%3a//photos.yahoo.com/bc/roncrown@sbcglobal.net/lst%3f%26.dir=/My%2bPhotos%26.src=ph%26.view=t setting up my lashpads, any recommended tips out there on doing this, Im going through them individually one at a time... LEt me know how it looks so far? Thanks Ron
	Im running the sdsefi setup. I dont have the information in front of me right now but, its on there website at http://www.sdsefi.com http://www.sdsefi.com/f6manual.htm here the pictures of the install My magnets are mounted in my factory pulley right now. Would be interested in new pulley for the car ... Thanks Ron The 6F system uses 3 magnets spaced 120 degrees apart for triggering and 1 synch magnet spaced 40 degrees before the "A" trigger magnet. See figs 2 and 3.
	hello, was wondering if you have access to selling any of these parts you come across. Reason being Im in the market for a Nice JDM Blow of Valve, Or anything else that they use over there... Thanks Ron
	Hello all, I originally made a purchase on new valve train equipment, and now in the processes of assembly. Thats were I need you help, Here the Product that I have. Isky Camshaft Grind # L-480 ( cam lift .327 / valve lift .480 / dur 280* ) Springs part number 7005 (performance spring) Retainers 1624-st ( Steel retainers) Problem that Im running into is. The retainer itself is much deeper over its factory counterpart. What I mean by this is the cup that holds the lash pad is deeper & have a much higher side. I know I have to get larger lashpads for this set up sence the factory .120 disappears inside the retainer, Is this normal. for retainers having a deeper side wall? also were might I find lashpads at a good price? Thanks for the help Ron
	Tbuck, What did you do to connect that to on the fire wall, do you have any problem with flex on the firewall? Thanks Ron Rosamond CA
	Hello, I've posted originally about getting a ss exhaust valve with a larger stem from si valve. It looks like im going to order the Intake valves as well but oversize this time. Question concerns me is that i know the early heads ran a different valve stem hight. What was done to the other valve train parts to accept the longer stem. I would like to get this all done in a p90 head, for my turbo application. The pricing of the valves are 9.97 each so i figure i'll freshen up things while its torn apart. Any help in covering the valve train would be help full Thanks one again Ron 240zxt
	I have a question that maybe you can help me with, I noticed that the valve stems on the ones purchased are slightly longer then the factory valve stems, Is there a advantange on running a valve with a longer stem then the shorter ones? Also if my intake valves are shorter, then the exhaust valves would this hinder the performance of the vehicle. thanks Ron
	Hey Guys, dont normally hang out in the 5.0 forum, but my brother is thinking on getting a Z car, but has this idea about running a FI 5.0 With a AOD tranny and 3.55 rear gearing. Whats you make on this? Also What might this run in the quarter, In say a 73 240z? Thanks for the help Ron 240zxt
	Any tricks in using these gaskets, As for headstud(ARP) Torque whatcha recommended... Thanks all Ron What ever happen to the aftermarket water pump jeffp was working on through i think moroso?
	Hello All, Was wondering if Anyone out there knows the largest diam. of a valve that can be used, with out causing complications down the line, Also what will have a better benefit. Larger Exhaust Valves or intake Valves. Any why would one be better then the other... Thanks for the information in advance Ron 240zxt
	Hello, As for what to do for the rods, I'll have to say, Polished,shot peen, magnaflexed (for cracks) Balanced, And Arp Studs. Good luck Ron
	Hello, Looking for a gasket that will work with a Bore size of 88mm for a 1982 Datsun 280zxt Engine. What might the size be of the fel-pro gasket? Thanks for the help Ron Decided to keep the car and fix it
	Hello all, Need rocker arms for my Z car 1982 Turbo Engine Non Hydro, style. $30.00 dollars is ruff per rocker As per courtesy Nissan.. Want quality but also would like to save alittle money so I can also afford Other things like Camshaft,Springs,Lash pads, Retainers. Ect.... Any Advice Were to get them at a better price. Please Type away... Also Camshaft, any speciality grings out there for turbo models, that is liked... LAter All Happy Thanksgiving ROn
	Hey all, Was wondering has anyone did this install yet? Was told tht writting reads normal. Reason why asking this puts closer springs on top and wider apart springs on bottom is this correct, If so any one know why its the opposite in the rear? Is this a eibach error? thanks Ron 73 240z
	Im running a 60-1 hifi with stage 5 exhaust wheel, does take a little to spool that puppy up, I felt going to a 82ar with stage 5 wheel was a easy alternative to a full t4 combo and still aloud me to run the factory POS manifold.
	Next question is with 88mm bore am I stuck with only one brand of gasket?
	Hello all, Need to get rid of the SCE gasket, Leaks like a old tolet. Figure this to be the problem of my pressure build up in the raditor and the nice white smoke blowing out of exhaust if I free rev it. Question is i have 88mm over bore Forged pistons With factory P90 head,ARP Headstuds What Gasket do you recommend? Looking at running upto 20psi. Planning for the future state that is. Thanks for the replys Ron
	Negative, No problems, I actually used a mustang dyno, with a clamp on number one cyl plug wire (simular to timing gun light) it worked fine. No problems even thought I went up to 5500rpm level Later Ron
	James, Wow, When I dyno my car, i was spinning the wheels as little 3200rpm. It took two guys to sit in the hatch, to distribute the weight over the car. With them in my car picked up another 37hp to the wheels. Must be the cheap tires (225x14" rims) im running. Could you've been doing the same? The Dyno i ran on is a Mustang Dyno dual rollers. later Good luck on friday Ron
	In comment to I was under the impression at idle or closed throttle, in gauge mode the TPS sensor, should be reading <0> this way the vehicle doesnt inject extra fuel into to the cyl. I know mine is seating at <0> with no problems. As for setting the sec section. you have to have 1's in 3-4 sections 500-750-1000-1250 Good Luck Ron Try the forum for SDS at www.sdsefi.com
	I ended placing a cover on it, Not thinking of the play, and so far 1.5 yrs later havent actually ran into any problems.. Ill take some pictures for you tommorow.. Ron
