LS1 240Z
About LS1 240Z
  • Birthday 05/03/1983
  • Gender
    Not Telling
  • Location
    Near: La Grange, Kentucky
LS1 240Z's Achievements
Newbie
10
  1. finally another good alternative to the gay T56 the transmissions have always been able to bolt up, and the TCI flexplate has provisions for both early and later torque converters. guys have been putting th350s and th400s behind LSx motors for the past 9 years or so. the biggest part of that article was where they had the flywheel for manuals that works. that there is worth looking into more.
  2. jump on it. get it, put it in with the auto trans and have fun with it
  3. i wish i lived closer.. id come get a lot of parts off that z i wish it was illegal to cut sun roofs into cars.. they are so stupid. someone butchered my car too and its the thing i hate the most about my car.
  4. the piston slap is there on all LSx motors. its probaly a stock motor thats just boosted. thats a pretty good find for 5k if you get the harness and computer and what not..
  5. let me see the eaton blower that bolts on.. are you refering to the LS9 blower/intercooler set up? thats the only thing i would know of that would be a bolt on blower like that
  6. there are mixed opinons.. but it all depends on what you are doing. i favor the iron block motors, they are only about 60-70lbs heavier, and bunches cheaper. if you want something that has a bit of pep and you arent shooting for over 450rwhp get a 5.3 truck motor, you can get a cast iron block one for $600-1000 complete. aluminum blocked 5.3s are fairly common to because they were in all V8 trail blazer style suvs, but they will be more. if you are shooting for 450+ rwhp id go with a 6.0 LQ4 truck motor, you can find them for $800-2000 complete. with some $800 factory heads and a big cam through a stick will put down 550rwhp.. its all about what you want to do with your car.
  7. 5.3 Gen III truck motor. $800. cant beat it with a stick.
  8. well getting a true LS9 would be expensive and probably have a hard time finding one even if you wanted to pay 20k for the motor. now soon as someone wreckes a new CTS-V that has the same 6.2L motor with the same blower on it... youll be able to pick up that motor pretty cheap. another option is the northstar 4.4L that has the same blower on the top of it. that would be a road race screamer right there...
  9. the motors need varing fuel pressure to run unless you have return lines and a regulator. you have 3 things to make a motor run.. fuel, spark and compression. you verify that you have the RIGHT fuel presure at the rail, injectors firing? getting spark? is it on time? there are tons of things you need to check... first one is to put a MAP sensor in the car, thats probably the main reason why its not running, car will run without a MAF, but not without a MAP
  10. someone needs to figure this out, shortie headers choke these motors so much..
  11. you can use the truck accessories and the LS1 intake. you just have to dent the tube going out of the top of the water pump. alt may be to high though. i may just have to cut some exhaust manifolds for my swap now..
  12. ah the horrors of wiring haha glad you got it figured out.. i got so frustrated i just sent my LT1 swap away to get it running ha.
  13. to swap the pan apparently you have to have a LS1 windage tray. or massage it to get the pickuptube to work with it. or so ive heard. to get the intake to work you will have to dent the tube on the water pump but it will work
