Kash
About Kash
  • Birthday 04/21/1967
  • Gender
    Male
  • Location
    Round Lake Beach, IL
  • Interests
    Z cars and porsche...
Recent Profile Visitors
12513 profile views
Kash's Achievements
Newbie
10
  1. hey do you still have all the brakes stuff for sale?
    do you have more info on what the rear set up is? dont know what disc conversion it is as there are a few....
    hoping its all still for sale!
    also a shipping estimate to 07078 (NJ) would be super appreciated!
    Thank you for your time!
  2. Sorry for the delay but no longer have the car.. Ken
  3. Herb
    Do you have the turbo distributor still?
    1. Kash
      Kash
      Sorry for the delay but it has been sold.
      Ken
  4. All shipped for $36.45 via FedEx! Ken
  5. All PM's responded to.
  6. Hi, I will get you a quote ASAP. Ken
  7. Status updates added below: Headlight cover $40.00: Sold, Zetsaz/Ca 280z console lamp set w/ bulbs $15.00: Rear Tail lights w/ Reverse lights $75.00 280z marker light set $15.00 280zx marker light set $15.00 280zx turbo boost sensor $5.00 280zx turbo distributer $50.00: Sold, Jeff/ Fa 280zx intake manifold cooling fan timer $5.00 280zx lightweight AC Compressor (direct replacement for 280z) $50.00 280z AC Compressor $25.00: Sold, Andrew, Tn 240z side emblems (a few broken tabs but will come with 2 sided tape to affix) $15.00: Sold, Solidrock 240z Wood Steering Wheel in great shape (no horn pad) $75.00: SOld, Alex Complete like new 280z Steering wheel (great for resto project or to keep as spare) $100.00: SOLD 280z ignition lock and key (misc. door/ truck locks w/ keys as extras) $50.00: Sold, Solidrock Relay box with relays $10.00 OEM Air Tank for your resto project $10.00 OEM Spare for your resto project $40.00 Hybrid 3 speed Honda Wiper motor with Arms $40.00: Sold, Chris/WA On car adjustable aluminum camper (F & R) and tension rod Set with tool $75.00 All four shock tubes $100.00: Sold, Kevin/Canada Rear Control Arms (L & R) $60.00: Sold, Jsteg Diff mount cross member and Support (modified to prevent clunk) $10.00 280z differential mustache bar w/ polly bushings $40.00: SOLD Complete N47 Cylinder Head taken from running engine $75.00 Disassembled p90a head $75.00: SOLD 280z solenoid vacuum valves and Bottle $5.00 Horn Pad $5.00 Radiator $40.00: SOLD Front Toyota Monoblock 4 piston Disk Brake System w/ braded lines (cross drilled rotors) $125.00: Miata Seats w/ Z tracks (direct bolt on and looks great) $200.00 Walbro fuel pump $50.00 Power Antennae $40.00: Full E-Brake System $50.00 Interior panels and leather(et) trimmings $100.00: SOLD Door Panels Cards (great conditions) $125.00 Full 280z 3 in exhaust system (from downpipe to Magnaflow muffler) $125.00: 15x7 Aluminum Mesh Rims w/ center caps $150.00 280z steering column $25.00: SOLD Full set or 280 gages (no clock but includes boost gage) $100.00: Sold, Kevin/Canada Full set of OEM 280z shock mounts (F & R) $50.00 ABS Steering Coupler (new), unit 1 $20.00: Sold, Alex ABS Steering Coupler (new), unit 2 $20.00: 1 Sold Headlight combination Switch, unit 1 $40.00: Headlight Combination Switch, unit 2 $40.00 Headlight Combination Switch with High/Low beams dim switch $60: Sold, Dan/Fa 280z gas tank cover $10.00: Sold, Solidrock 280z Hood $50.00: Sold, Solidrock 280z Facial Mask/ Bra (new in box) $75.00 Inspection Lamp $10.00: Sold, Zetsaz OEM Jack Kit $40.00 Speedometer cable $20.00 Brake & Clutch booster/master cylinder heat Shield (w// manual boost gage adjuster) $20.00: Sold, Zetsaz 280z Engine under tray $75: Sold, Zetsaz 280z Washer Bottle $15: Sold, Zetsaz 280zx Turbo intake boot $40: Sold, Jeff/Fa Power Steering Tensioner $15: On car adjustable aluminum camber (F&R) and tension rod set $75.00: Sold, Jsteg Light weight A/C Aluminum bracket with belt tensioner $35.00 280z front Control Arms w/ ball joints, steering knuckles, aluminum bump steer spacers, tension rods with polly bushings $50.00: Sold, Jsteg 280zx Turbo coil and igniter $30.00 280zx Turbo igniter $15.00 300zx Coil $20.00 1987 300zx Turbo ECU $50.00 Please let me know if got any update wrong or if I missed anyone. Ken
  8. Working on shipping for brakes and Antenna
  9. Yes, both are: Engine Under Tray: $75 Washer Water Bottle: $15 Ken
  10. Misc. Z Parts for Sale. Assume all parts are from my 1978 280z unless started otherwise. All parts are used (except for a few as stated) and priced well below cost to me but open to BO or package deals…can provide more pictures of specific parts if an email address is provided. See link for available pic’s…will be loading up the remainder by this weekend. https://postimg.org/gallery/1kr7vy04s/ https://postimg.org/gallery/3dypy0ap8/ Headlight cover $40.00 280z console lamp set w/ bulbs $15.00 Rear Tail lights w/ Reverse lights $75.00 280z marker light set $15.00 280zx marker light set $15.00 280zx turbo boost sensor $5.00 280zx turbo distributer $50.00 280zx intake manifold cooling fan timer $5.00 280zx lightweight AC Compressor (direct replacement for 280z) $50.00 280z AC Compressor $25.00 240z side emblems (a few broken tabs but will come with 2 sided tape to affix) $15.00 240z Wood Steering Wheel in great shape (no horn pad) $75.00 Complete like new 280z Steering wheel (great for resto project or to keep as spare) $100.00 280z ignition lock and key (misc. door/ truck locks w/ keys as extras) $50.00 Relay box with relays $10.00 OEM Air Tank for your resto project $10.00 OEM Spare for your resto project $40.00 Hybrid 3 speed Honda Wiper motor with Arms $40.00 On car adjustable aluminum camper (F & R) and tension rod Set with tool $75.00 All four shock tubes $100.00 Rear Control Arms (L & R) $60.00 Diff mount cross member and Support (modified to prevent clunk) $10.00 280z differential mustache bar w/ polly bushings $40.00 Complete N47 Cylinder Head taken from running engine $75.00 Disassembled p90a head $75.00 280z solenoid vacuum valves and Bottle $5.00 Horn Pad $5.00 Radiator $40.00 Front Toyota Monoblock 4 piston Disk Brake System w/ braded lines (cross drilled rotors) $125.00 Miata Seats w/ Z tracks (direct bolt on and looks great) $200.00 Walbro fuel pump $50.00 Power Antennae $40.00 Full E-Brake System $50.00 Interior panels and leather(et) trimmings $100.00 Door Panels Cards (great conditions) $125.00 Full 280z 3 in exhaust system (from downpipe to Magnaflow muffler) $125.00 15x7 Aluminum Mesh Rims w/ center caps $150.00 280z steering column $25.00 Full set or 280 gages (no clock but includes boost gage) $100.00 Full set of OEM 280z shock mounts (F & R) $50.00 ABS Steering Coupler (new), unit 1 $20.00 ABS Steering Coupler (new), unit 2 $20.00 Headlight combination Switch, unit 1 $40.00 Headlight Combination Switch, unit 2 $40.00 280z gas tank cover $10.00 280z Hood $50.00 280z Facial Mask/ Bra (new in box) $75.00 Inspection Lamp $10.00 OEM Jack Kit $40.00 Speedometer cable $20.00 Brake & Clutch booster/master cylinder heat Shield (w// manual boost gage adjuster) $20.00 Do not hesitate to contact me via cell or PM. Ken (847) 345-1215
  11. Link to most parts: https://postimg.org/gallery/37lxxnzfw/
  12. Quick update on parts availability: Engine: 2.5 to 3” mandrel bent downpipe - $75 3-Inch Exhaust w/ Magnaflow Muffler - $75 Aftermarket Oil Cooler w/ adapter and hoses - $50 - Michael Electric Fan with shroud - $50 - Michael Water Injection System - $75 Drivetrain: Spec II Clutch w/ Fidanza Flywheel - $ 250 - Michael Front Disc Brake System (Toyota 4 piston mono-block 4 piston calipers, cross drilled rotos and braided lines) - $175 Rear Disc Brake System (brackets w/cross drilled rotos and braided lines) - $175 Suspension: Urethane Bushings all around Motorsport Performance Sway Bars - $200 - Michael Front and rear high strength Stress Tower Bars - $150 - Michael Tokico illumine 5 way Adjustable Shocks w/Eibach Springs - $350 - Michael Hydraulic Power Steering System w/Subaru rack and Toyota ends (operates flawlessly) - $ 400 - Michael Interior: Mazda Miata Leather Seats (fully adjustable on OEM tracks, bolts right in – looks great) - $250 Black Interior panels and leather raps - $100 Black Door panels in great condition - $150 Like new OEM steering Wheel, perfect for your restoration $100 Center console w/ padded aftermarket harm rest - $50 - Michael Other OEM parts: Complete emergency brake system (handle, linkages and cables) - $50 Fairly new Radiator form AutoZone - $50 All gages (clock replaced with matching boost) - $100 Headlight covers – Sale Pending (Kevin) Both Taillights – Sale Pending (Kevin) All 4 shock tubes (perfect for your coil overs) – Sale Pending (Kevin)
  13. Hi all, I apologized for the delay as I have been travelling for the last 4 weeks. I have responded to all PM's, please touch bases directly if you are still in need of other parts. The complete engine w/ EFI system, trans w/ adapter, lsd and drive axels w/adpters have been sold but the front and rear brakes are back up for sale along everyting else listed. The only body part I have is the hood...the car is gone, I needed the space. I will post here as parts are spoken for. Ken 847 345-1215
  14. All - I'm traveling for business and will be out of the country for 2 weeks returning 12/18...will respond to all when I get back. I apologize for any inconvenience. Ken
