gjc5500
Everything posted by gjc5500
  1. i forgot to ask, do u know of a good regulator, or pump w/ build in reg. that will work for this? i searched on holley and found nothing like this.
  2. so if i had a box that ran BOTH carbs, the best spot to pull a line to supply boost for the FP would be the box right? and thx ALOT for all your help. ive been trying to figure this out for aboutl 3 months now
  3. so... if i run 8 psi, i would want like 12psi of fuel? wont that be bad at idle??
  4. cf hood! and that light peice on the 240s. the silver part around the tail lights. thatd b sic in cf!
  5. i read that to run a blow thru on a carb requires you to equalize the fuel bowl and the intake pressure. i have duel weber dgv carbs on a 73 240z. i noticed today that from the top of the carb i can see straight to the fuel bowl. if i were to run a box ontop of the 2 carbs(like the aircleaner box, but covers both carb tops), would it pressureize the fuel bowls enuff to keep the air from running back?
  6. it is not needed. i recently did this swap. blues notes helps. google a swap for 280z to a 280zx alternator. theres one on there that tells how to do it
  7. i was wondering if the turbo exhaust manifold off of a p90 would bolt up to a e88 head. i know they both have square ports. thx in advance
  8. gjc5500
    V12
    there is a compleate form for the V8. i have seen v8s that r making 9~10 second Zs. check it out
  9. well wen i swaped to that tranny woudl be just b4 i move to germany. so id be doing 120+ ALOT. and i was jw
  10. i was thinking that after ive swapped the engine, id start saving to find a nice 6speed tranny that would fit. r there ne that fit?
  11. ok, i wanna keep my original tranny. will that work? if so, will my speedo still be the same. the guages aare OK and im gonna get a good boost guage. prolly ount where my cig lighter was(its dead and i dont use it) i like the guages that are in there and i dont really feel like pulling the dash(its already cracked and i dont want ot risk breaking it further) will this be fine?
  12. i dont have time for the shipping, or the cash to buy it. i was wondering if ne one knew if someone knew it off hand, or if someone knew where i could find it online
  13. i searched fruitlessly already i need the tune up specs for a 73 240z. i need the points gap, plug gap, ect. plz respond quick. thx in advance
  14. how very little? like woud i have to mess w/ the speedo/tach/ other gauges?
  15. hmmm. how much HP does the stock l28 put out. how much psi will it take. and what has to be changed inside the car
  16. ok. how hard is it to swap the l24 for the l28? ive never swapped an engine, and im sorta a nub wen it comes to cars. i no some stuff, but not a hole lot.
  17. should be fine. mine was like that for a while, it worked itself out. can i see pics of ur engine.
  18. i dont wanna do a full swap cuz all the vins match as of now, and to swap is gonna b a lil more pricey. seeing as how im still in high skool and cant get a full time job, im trying to go with the cheaper of the 2. also, will a L28 turbo exhaust fit on a L24?
  19. 3K is a lil out of my price range. and i know about chaning the CR. thats y im going w/ a low comp head, and low comp pistons. i mite still do draw thru, but i wanna no about that box. ive seen ti w/ and w/o.
  20. is there a pdf of it avalible? i dont have the ability to buy stuff off the net and have no ride as of now to the book store.
  21. ive seen people do blow thru with a box around the carbs, is this nesasary(sp?) and how do i lock out the mech advance?
  22. and i dont have SUs, i have weber DGVs.
