hi guys,
well after few weeks of not working on the car because of my job, a friend of mine and me came up with an idea, we will install the SC behind the tranny and next to the engine so the SC pulls the fork toward the engine wich is the thing i need, we canceled the fix rod from the SC and put a 13mm screw, then we fabricated a piece of aluminum that is identical to the plastic piece on the ford stock cable wich goes into the bellhousin, it slips on the SC and attaches to the SC by 3 5mm screws, we'll install it and place a holding clip from the other side excatly like the stock cable, i had to lengthen the rod so it arrives to the fork and have enough space to adjust the clutch:
here are some photos, hope it will help people later,
here u see how i removed the fix rod and put the screw.
this is the aluminum piece were you can see the 5mm hole and the place to put the clip
this is the fix rod i removed and im going to connect it to the other moving rod by a (2.5cm long/8mm thread) nut.
this is the connecting nut
the new modified SC installed all together ( i know it looks like a freking weapon)
a colser look to show the screw that holds the aluminum piece to the SC
i'll install it tomorow on the car, bleed it and let you know how it works + more photos on the car.
