Everything posted by awd92gsx
I must not've seen that post...I'll go back and check... Technically, on a 1G SBC the EGR is routed through a port in the cylinder head into a chamber into the intake manifold and then rerouted to the intake charge. The vaccum port is routed from the carburetor, to the thermoswitch back to the EGR. The standard 1G SBC setup is mounted solely ON the intake manifold, rather than some of the later setups being mounted between the exhaust manifold and the intake In any case, it's blocked off at the moment until I get it running right...but, my Dart heads don't have the exhaust port going to the intake for the EGR anyway, so, it's not functional anyway...but, I need it for visual.
Yeah...it sounds like a vaccuum leak to me as well...I just can't seem to figure out where it's coming from... I bought one more set of intake manifold gaskets (good thing Chevy parts are cheap!!) and some different sealant. I don't know why I would be having so many troubles getting the intake sealed up right...but...I seem to be having them.
OK...I'm out of ideas... After putting on my new heads and intake whenever I put the car in Drive it simply wants to stall out and die. Also, if I give it more than about 1/2 throttle, it backfires through the carb and wants to stall out unless I let off of it. I tried a new carb, I just tried resealing my intake manifold, ignition advance is good (set at about 12 BTDC - changing this doesn't really make alot of difference.) Checked and changed the throttle body gaskets, doesn't appear to be any leaking around the carb. When in park/neutral it seems to idle "ok" and seems to rev up just fine...but, as soon as it's put in park it wants to die. I'm completely and utterly out of ideas.
Damn SpdSk8r...how much advance are you running? That was an AWESOME idea you have there!
I'm ok with how mine turned out.
So, who wants a nice 50mpg beater that runs low 11s?
awd92gsx replied to auxilary's topic in Non Tech Board
Sure they do...if you are on the freeway and aren't doing 120+ mph all the time I get 42 in town all day long...of course, I don't ride aggressively unless up in the canyons or mountains. -
Heh...I'd rather have a 50mpg beater that runs high 9's Oh wait...I already have one. Silly me. -
Is it possible? I like the way my carb runs...and...I'm thinking of going a little different than most people... I'm "thinking" of getting my carb powdercoated black...
A few upgrades...EGR issues...Help!
awd92gsx replied to awd92gsx's topic in Gen I & II Chevy V8 Tech Board
I didn't get it finished today like I was supposed to... But, I'm fairly close. -
For what it's worth...I think the JTR manual says somewhere that a stock 350 in a 1G Z will run around a 13.4 or so...with the exception of my edelbrock intake and headers, my 280Z with a fairly tired '350 "feels" like a 13 second car. 280Zone had an even more tired 350 with carb issues in his and WITH A PASSENGER and a slipping tranny ran consistent low 14's.
Ahh...you got the wrong style Ebay headers Those are the ones made by Hotzone...the other style fit just as perfect as any other name brands I've seen. Let me know and I can show you which ones you need to get (and I've been running for about 4-5 months without any problems)
Well...about 45 seconds with my die grinder and it clears just fine -
BTW...that pic makes an awesome desktop background
Damn impressive if you ask me. That car looks mean.
I've googled it...and the only thing I found was this... http://hotrod.com/howto/42338/index2.html They say you need a '78-82 EGR valve...so, I'm thinking they are a smaller diameter than the '77 I bought... I'll head back down to autozone tomorrow in hopes of finding what I need. Thanks for the compliments on the hood I really like it. It definitely changes the car. -
OK...I'm in the process of a few upgrades...dart aluminum pro1 heads, summit roller rockers, and a new weiand intake (EGR compatible for emissions) But...I've kind of run into a snag... Since I live in an emission state (and my emissions are actually due) I'm forced to run an EGR...so, I went down to get an EGR for a '77 El Camino and while I was putting it on the manifold I noticed that there's no way in hell it's going to clear my valve covers (which will, of course, have to be tall to clear the rockers) Any ideas? Suggestions? Is there a smaller EGR valve out there that I have to run from a different application or something?
I dunno...this was my first V8Z swap...From the time I pulled my running Z into the garage...it took me about a month and a half, maybe two months of working on it every couple of nights for about an hour or so, more on the weekends. Of course, it all depends on if you get caught up in the "while I'm in there" bit... I spent a total of about $1700 on my swap...and that included a bunch of things I didn't necessarily "need" but, wanted (like a new water pump, new alternator, etc...) The biggest time consumer was going back down to the store to buy more bolts...it was never ending. I should put together a bolt kit for the V8Z swap someday...I'd make millions.
I thought about just the taillight panel...but, from the side of the car, you see black in the front (because of the headlight covers and the cowl section of the hood) but, nothing towards the rear of the car... http://www.kpclan.com/pics/zside2.jpg
Sadly, has put his V8 swap on indefinite hold.
Well...I attempted to paint it myself, at first...but, in the end I ended up having dmsv8 paint it for me, after he explained everything I was doing wrong. Initially, I'd considered doing it the same red as my car...but, like you said, matching it would be difficult since I didn't know the exact paint color that was used on my car...so, that's why I decided to go black. The more I thought about it, the more going black on the hood appealed to me...but, I didn't want to just stop there, otherwise it would look like I had just forgotten to repaint the hood...so, that's where I got the ideas of getting the headlight covers. Now that I have some black on the front, though, I need to splash the back of the car with some black to even it out a little bit. I also painted my engine red/black when I installed it, so, I've tried to keep the red/black theme going throughout the car....I've also been looking at some red/black steering wheels.
Yep...I saw one at the shop I gotta figure out how to con Robert into building one
Thanks guys. I ran it for awhile without the headlight covers (about a week anyway), but, I like the more "sinister" look the headlight covers give it. Hmm...what's next... Well, Now that I have a some black in the front of the car, I think I need to have a splash of black in the back also...I think I'm going to paint my spoiler black. I thought about racing stripes, but, I'll wait until the next paint job for the car before I do that. We're doing great RacerX! Thanks!! The hood (full supported version) costs $435 from 280Zone. He also produces a full pin on version for cheaper, but, I'd go for the supported version (which I did)
Most tinted headlight covers are too dark to really effectively produce enough light to see anyway...besides, they're easy enough to remove for the rare times I drive at night.
TY! TY! The headlight covers are actually from Victoria British (MSA is on backorder). I got the clear headlight covers and painted them solid black on the inside (to match the hood)
280Zone builds and sells them. The construction is top notch!!
