Everything posted by tamo3
Hi @SPT260 What piston do you get for N42 89 bore bottom? I'm thinking about building engine. I have N42 or P90 head, N42 bottom, Diesel clank, 72 240z conrod. I'm looking for K24E pistons 12010-40F10 but it's discontinued....
HybridZ Apparel Order Thread - 100% of Profits Will Be Donated, round 4
tamo3 replied to cockerstar's topic in Vendor's Forum
Me too. I want One - Large Gray short sleeve T-Shirt. -
10 years after hybernation - '75 280z
tamo3 replied to tamo3's topic in S30 Series - 240z, 260z, 280z
It's nice weather drive a bit.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Working on radiator hose. The Big GM alternator is hitting radiator hose and coolant get leaking. Entire engine bay was splash with coolant This is the problem. purchased eBay radiator hose. https://www.ebay.com/itm/Silicone-Radiator-Coolant-Hose-For-NISSAN-DATSUN-280Z-Z-S130-L28-1975-1978-Blue/253940447076?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 The lower hose shape is different from OEM one. Before and After. The new hose is not touching alternator at all ! Looks good on blue also, I build ramp with some spare woods. Now I can jack up my car.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Happy New Year, Leon. Glad you have a time working on Z. Hope to get together this year
30mm to move back. http://zhome.com/ZCMnL/tech/240SX5spd/transmission.htm http://www.motortopia.com/cars/1973-datsun-240z-11118/car-pictures/240sx-transmission-swap-14041/transmountmodjpg_Thumbnail1.jpg-269047 http://forums.hybridz.org/topic/113452-240sx-trans-swap-into-280z-measurements-and-install-pix/?hl=240sx http://atlanticz.ca/zclub/techtips/240sxtransmissioninstall/index.html You can find the answer in this forum.
For my memo, Nissan Quest long bolt is Dorman 610-404. M12-1.25, 4.5cm length. https://www.dormanproducts.com/p-2578-610-403.aspx https://www.oreillyauto.com/detail/b/dorman-autograde-3358/tire---wheel-16779/lug-nuts-and-studs-25062/wheel-lug-stud-12672/fb26df11d790/dorman-autograde-m12-1-25-thread-wheel-stud/610404/4181308
While waiting for the key, working on towing hook. I lost original towing hook somewhere. I purchased this one. https://www.ebay.com/itm/Datsun-240z-tow-hook-kit-front-and-rear-s30-SCCA-and-track-day-legal-early-260z/271274853112?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Since it's designed for 240z, I need modify a bit hole location in front. Paint it with leftover paint for caliper to prevent from rusting. Fit nicely now. For the rear, seller sent me 2 holes version, which is different from the photos on the eBay. I explained to seller, he sent me 4 holes version. Since the holes are too big, I need put thick washer to bolt on. It fit perfect now.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Thanks guys. I ordered blank key through eBay. https://www.ebay.com/itm/2X-DATSUN-KEY-BLANK-BLUEBIRD-1600-410-411-510-620-720-810-910-240Z-260Z-280ZX/141707348148?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Once I get it, I will try Nissan Dealer. What I heard that Nissan dealer can cut the key by the code with few dollars in Japan. It could be same in the States.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Working on towing hook. Since I replace bumper to 240z style, I lost somewhere 280z towing hook. So, purchase this one. https://www.ebay.com/itm/Datsun-240z-tow-hook-kit-front-and-rear-s30-SCCA-and-track-day-legal-early-260z/271274853112?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 But actual products has less holes for the rear mount. It won't fit to my 280z. For the front, since i installed Type 1 spoiler, I cannot just bold on it. I need make a hole in order to mount the towing hook on the front.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Found some document about Datsun key code. http://www.hpcworld.com/Print/36041_000_00.pdf But I have no clue from this tech doc....- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Thanks @Zhoob2004 I don't know any reliable locksmith around my home. It's easy to find it online You might be right. The key cylinder itself might be worn out. But I'd like to try the key at first.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
My key is worn out. I can take it out while running the engine. My previous 240z had the same issue. Hmm... Photoshop Mosaic filter effect is not good idea to apply here... It looks like a #$%^@. I'd like to make a new key to cut based on the key code. I found online site that help me to cut the key based on the code. http://keysforclassics.com/form/ Waiting for their reply.... I also look for blank key for the same shape of this key, but I can't find on eBay...- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Thanks Leon! Look forward to driving Z cars together!- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
After 6 years of working on rebuilding this car, finally, she went outside of the garage for test drive.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
@Zhoob2004, I don't remember whether I can access from trunk area on my 75. I already closed interior panels ☹️- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
@Neverdone, Thanks for your advice. Since there is inner sheet metal, I cannot use weld nuts. I will check nutserts.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
HI @Neverdone, I don't know how I can treat that. Even though make a hole How can i bolt on it?- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Installing glass fiber bumper. I purchased this bumper long time ago through local Craigslist. For the body side bracket, I purchased from EuroDat @ Classic Z community. It's very strong and fit really well to the body. I welded the bolts to the bracket and put glass fiber sheets. Add a couple more glass fiber sheets to make it durable. Test fitting is great. But I need to think about what I should do for the side of the bumper. I don't have holes to bolt on to the body...- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
New music video with S30 Hiroji Miyamoto's "Fuyu no Hana" WInter Flower
found a leak from front right side of brake caliper. It leaks from the bottom of the caliper. Went to pick and Pull and get another caliper from 4Runner. It was pretty clean and looks like rebuild recently. Use wire brush to remove surface rust and use PRO15 metal prep to clean up. Then, paint Red using DupliColor. Need to wait a couple of days to completely dry.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Hey 75280z, You can purchase Door Upper Molding Rubber Seal from here: https://zcarsource.com/door-upper-molding-rubber-seal-240z-260z-280z-70-78-new- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
