Everything posted by tamo3
Looking for working condition rear LEFT caliper from '82 - '83 280ZX. ~'81 is different shape. If you have spare one let me know. Thanks, tamo
10 years after hybernation - '75 280z
tamo3 replied to tamo3's topic in S30 Series - 240z, 260z, 280z
Got reverse idle gear from Cobra Transmission. https://cobratransmission.com/nissan-fs5w71c-4-cylinder-reverse-idler-gear-50042098-1?zenid=4f4f23951c83514dfa3835a423065d0f i was told i don't need to replace it with current condition, but I did- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
From the album: 71C Reverse Idle Gear
Does 4speed tranny (F4W71B) has Gear Drive?
Luckily, I had spare 71b junk tranny in my grave yard. I don't know what car it came out from. Maybe truck? Anyway, I secure smaller diameter Gear Drive! -
I should've get less than 3.9 final gear ration 71C in the first place.... http://czot.org/forum/showthread.php?1760-Speed-Pinion-Gear-and-Housing-Combinations-(-70-78-240-260-280Z) -
Thanks for your input. I got my 71C tranny from 1990 240SX. I just got home and remove Speedometer pinion to see inside of tranny of F4W71B. The Gear Drive on 4 speed tranny is actually drive shaft itself. It does not have separate nylon cog. I need to look for it... -
Hi, I'm middle of 240SX F5W71C tranny conversion to 280Z. This tranny's speedometer pinion is red(4.1 final gear ratio) which is wider diameter comparing with lower final gear ration from 280Z(Black one). https://www.youtube.com/watch?v=esW9tjb6Loo&feature=youtu.be Therefore, just plugin 280Z speedo pinion won't touch gear drive. I have 4 speed tranny from '75 280z. F4W71B. When I check FSM, I cannot figure out whether it comes with white nylon cog gear drive or not. Does anyone know whether 4 speed tranny has it? reference: http://czot.org/forum/showthread.php?1760-Speed-Pinion-Gear-and-Housing-Combinations-%28-70-78-240-260-280Z%29
30mm to move back. http://zhome.com/ZCMnL/tech/240SX5spd/transmission.htm http://www.motortopia.com/cars/1973-datsun-240z-11118/car-pictures/240sx-transmission-swap-14041/transmountmodjpg_Thumbnail1.jpg-269047 http://forums.hybridz.org/topic/113452-240sx-trans-swap-into-280z-measurements-and-install-pix/?hl=240sx http://atlanticz.ca/zclub/techtips/240sxtransmissioninstall/index.html- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Tranny mount welding is done. with cheap welder... as long as it strong enough, it's ok. For tranny mount, which way is the correct way?? it touching edge of the mount. I need to grind it.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
From the album: tamo3's album
