tamo3
Everything posted by tamo3
  1. You can use same bolt from original 4 speed tranny.
  2. I'm thinking about getting easy drain plug. Is the size M12-1.25?
  3. I'm thinking about getting easy drain plug. Is the size M12-1.25?
  4. I'm thinking about getting easy drain plug. Is the size M12-1.25?
  5. I'm thinking about getting easy drain plug. Is the size M12-1.25?
  6. Congratulations with your new family!!! I'm pretty sure you might want to get McLaren for Oliver's stroller, don't you? hehe
  7. Thanks Leon. How have you been? busy with S2000 lately? I hope I can drive around April. Depends on how much electrical update I can do... I try to figure out how I can delete SHUNT, and add ignition relay, fusible link MSD-6AL....
  8. Thanks spitz17! Almost finish... Found appropriate size adaptor and adjust the length. Weld at midnight at backyard
  9. Working on exhaust. My original muffler has a big hole at the bottom. I need to replace it. I got fat muffler from junkyard I can use it until I got good header and re-do entire exhaust system. Chop off pipes. While cleaning OBX muffler, I discovered it comes with silencer. Wash off with Simplegreen as usual. I don't know how much I can re-use gasket. Copper sprayed. Fixed the small hole with this. I'm not sure how durable it is...
  10. http://www.nissanpartszone.com/parts-list/1979-nissan-280zx/transmission-gear.html
  11. Kuni san more frequently update his blog at Minkara. http://minkara.carview.co.jp/smart/userid/357364/blog/
  12. I thought 280zx and 280z are different. http://www.zcarsource.com/oil-pan-plugs-240z-260z-280z-280zx-300zx_8_55208.html
  13. Looks like 240z, but you should check FSM first. http://www.xenons30.com/reference.html
  14. http://sfbay.craigslist.org/sby/pts/4867333244.html http://winchester.craigslist.org/cto/4869968892.html
  15. It looks like short nose. Not from 300zx.
  16. Thanks Leon, ok... I thought there is some easy way around since replacing V-velt is common maintenance.... Regards, Takashi
  17. Working on Power Antenna modernization. Watch Youtube video how 3rd party power antenna works. Since my power Antenna did not comes with any instruction(maybe I lost?) Original power antenna is controlled up/down switch. I want to control power antenna via modern car stereo with just one wire using existing cable. Here is my schematic. While Green wire connect to red with 12V, power antenna is extended. Once green cable is disconnected with red with 12V, the power antenna is go back to housing. Power Antenna is installed. Test with battery. Works! Need to connect Blue/Red to 12V constant.
  18. To replace timing belt, I need to unmount cooling fan. I'm having hard time to unscrew nuts to remove the cooling fan. How I try to put it back, it's so hard. Therefore, I unbolt the plastic fan blade from the metal part, clutch. I can manage screw in the nuts with the metal parts. and now, I can't put the plastic blade back in Lol Is there any easy way to put back the cooling fan? Thanks, tamo3
  19. I saw engine the @ Pick-N-Pull. http://www.picknpull.com/check_inventory.aspx?Address=95110&Lat=37.354611&Lng=-121.918866&Make=Datsun&Model=280&Distance=50 Grab it before it's gone
  20. Yes, you need. It's written in AntanticZ hidden Q&A section http://www.atlanticz.ca/forums/index.php?topic=1077.0;wap2
  21. This might be helpful for you for swapping ZX internal voltage regulator Alternator swapping. http://www.classiczcars.com/topic/50336-upgrade-electric-system-alternator-fusible-links-remove-external-voltage-regulator/
  22. not yet. I need to work on front suspension installation. Meanwhile, I was working on interior. Modernize tachometer. Autometer Tachometer to build into original tachometer housinghttp://forums.hybridz.org/topic/121021-autometer-tachometer-to-build-into-original-tachometer-housing/
