notheredave
Everything posted by notheredave
  1. PS I also changed my mind on the metalic blue to White and metalic gold stripe and rims with a metalic gold center and a polished lip. And I just got my illuminas. Here is a mocked up photoshop picture and I like it...What do you guys think?
  2. I just picked up a M122 GT500 supercharger (see pictures)$250 w/ only 1000miles and Harmonic dampener for $40 shipped. I also got a ECM to run either the 4.6L w/ the GT42 Turbocharger or the Supercharger and I plan on making a custom manifold to run an Air to Air intercooler.
  3. Here are some pictures of the latest progress... I got my powder coating done. In the picture of brake parts are some big brake candidates.
  4. Here are some cam specs (cut n paste): Mach 1, 03/04 Cobra, Aviator, Marauder, Navigator, Continental, and Mark8: Intake RH YF3E 6A270 BB LH YF3E 6A271 BB Exhaust RH YF3E 6A272 BB LH YF3E 6A273 BB Intake: 184 deg @ .050/.394 lift Exhaust: 196 deg @ .050/.397 lift 114 lobe center ------------------------------------------------------------------------ Mach 1: Intake RH YL 7E 8A271 AB LH YL 7E 8A270 AB Exhaust RH YF 3E 6A272 AB LH YF 3F 6A272 AB ------------------------------------------------------------------------- Intake Camshaft RH-(YF3E 6A270 BB) {Mustang Cobra} LH-(YF3E 6A271 BB) {Mustang Cobra} Intake Opens @ 6 Deg BTDC Intake Closes @ 70 Deg BTDC Intake Opening: 2.54mm Lift @ 30 Deg ATDC Intake Closing: 2.54mm Lift @ 30 Deg ABDC Max. Lobe Lift = 5.54064 mm @ 120 Deg ATDC {10mm at Valve} Exhaust Camshaft RH-(YF3E 6A272 BB) LH-(YF3E 6A273 BB) Exhaust Opens @ 54 Deg BBDC Exhaust Closes @ 16 Deg ATDC Valve Lift 2.54mm Lift @ 17 Deg BBDC for Exhaust Opening Valve Lift 2.54mm Lift @ 23 Deg BTDC for Exhaust Closing Max. Lobe Lift = 5.55152 mm @ 110 Deg BTDC {10mm at Valve} ------------------------------------------------------------------ Ford factory OEM Cam Specs. Camshaft Lift: 392â€/ 390†Duration at 50: 232â€/236†2C5Z-6049-DALH 2C5Z-6050-DARH ---------------------------------------------------------------- Ford factory OEM Cam Specs. Camshaft Lift: 392â€/ 390†Duration at 50: 232â€/236†Intake: LH: YL7Z6250BA RH: YL7Z6250AA For the Exhaust: LH: YF3Z6250DA RH: YF3Z6250AA ________________________________________________ 96-98 Cobra: Intake RH F6ZZ-6250-AA LH YF3E 6A271 AB Exhaust RH F3LY-6250-C (96 - 97) and YF3Z-6250-AA (98) LH F3LY-6250-D (96 - 97) and YF3Z-6250-DA (98) Intake: Primary Lobe, 204 duration @.050/ .390 lift Secondary Lobe, 204 duration @.050/ .390 lift Exhaust: 196 duration @.050/ .390 lift 114 lobe center ________________________________________________ 99/01 Cobra: XR3E-6A270-AD 464VRM1209N4 XR3E-6A271-AD 464VLM1209U3 F2LE-6A272-AG 464VRM1179E3 F2LE-6A273-AG 464VLM1199G2 Intake 200 deg @ .050 / 394 overlap Exhaust 196 deg @ .050 / 397 overlap -------------------------------------------------------------------- Intake: 200 duration @.050/.392 lift Exhaust: 196 duration @.050/.390 lift 114 lobe center _______________________________________________ FR500 (M-6550-T46) Cam specs: Intake duration 258° @.003, 212@.050 /.472 lift Exhaust duration 254° @.003, 208@.050 /.472 lift 109° center line 204/214 specification _______________________________________________ Cobra R specs: Intake: .515'' lift 212 degree duration @.050 Exhaust: .468'' lift 212 degree duration @.050 _______________________________________________ GT cams: 4G7V-6A270-AA Right Intake 4G7V-6A271-AA Left Intake 4G7V-6A272-AA Right Exhaust 4G7V-6A273-AA Left Exhaust Intake 189 @ .050" / .424" Lift Exhaust 190 @ .050 / .448 Lift Centerline is up for debate as the set tested at 122/118 Ford states they are 114/114. -------------------------------------------- Shelby GT500 Upgrade High Lift Cam Set: $475.00 - $519.00 •Original equipment camshafts for the Ford GT Supercar •Direct retrofit to the 2007-2009 Shelby GT500 •Increases lift from the stock 10mm to 11.14mm intake and 11.36mm exhaust -------------------------------------------- Here are the Ford GT cam specifications measured by J. Mihovetz: Intake: 197 duration .466 lift Exhaust: 197 duration .456 lift Another measurement of them GT Cams: (actual as tested numbers, not Ford specs) Intake: 189 @ .050"/.424 lift (measured duration) Exhaust: 190 @ .050"/.448" lift (measured duration) -------------------------------------------- Ford GT cam part #'s 4G7Z.6250.AA RH INTAKE 4G7Z.6250.BA LH INTAKE
  5. Hear are some pictures of the brakes. I found a company in Los Angeles that will drill the blanks for our wheel lugs.
  6. I wanted something exotic...Like the 60's Ford OHC 600hp big block that I read about when I was a teen. And I wish I could do headers also...Maybe in the future.
  7. The distributor is H.E.I. (Hi Energy Ignition) brakerless. Which I have the whole setup so I could fire up the engine while I'm figuring out the electronic ECM. Here are some links of setups that are way easier. The guy that sold me the stand alone and distributor setup went to. Ford 4.6 5.4 SOHC DOHC MSD 6-Mod Controller Carbureted EFI 6011 Mark 8 Mustang http://www.ebay.com/itm/Ford-4-6-5-4-SOHC-DOHC-MSD-6-Mod-Controller-Carbureted-EFI-6011-Mark-8-Mustang-/300607863399?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item45fd9ffa67 MSD Ignition 6011 Ford Modular Ignition Controller for 4.6L/5.4L http://www.ebay.com/itm/MSD-Ignition-6011-Ford-Modular-Ignition-Controller-4-6L-5-4L-/150692206308?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2315f496e4
  8. I just picked up a couple of options for ITB's, 4 ddl., distibutor, and stand alone ign. Here are some pictures
  9. attached is a picture of my front brakes and I am waiting for a custom rear rotor and adapter. Here are the specs: Brembo 4 piston fronts and 2 piston rears 355mm (13.98") Diameter 32mm (1.26") thick Fronts 336mm (13.23") Diameter 22mm (0.87") thick Rears PS the rim is an 18" and sent in all my suspension for powder coating (I'll post pictures soon).
  10. It's been awhile since I have read or posted...I don't have the Q45 V-8 but I do have Titan VK56.
  11. I have (6) of the 4.6L's and (4) 5.4L's and the 5.4L doesn't fit and the 4.6L fits and I had a Tremec 5 speed. All the other motors only come in Automatics...I got the automatic bellhousing for the motors that I will be adapting to a manual setup. PS I have (2) 0 mileage hyundai genesis coupe 2012 V8's and (3) 0 mileage hyundai genesis coupe 2012 V6's. 3.8L Lambda V6 engine producing 306 hp (228 kW; 310 PS) and 266 ft·lbf (361 N·m) torque. 4.6L Tau V8 producing 385 horsepower (287 kW) at 6,500 rpm and an identical 333 lb-ft of torque at 3,500 rpm More fun for the future
  12. After a few years of buying all kinds of engines (L28 turbo w/ jim wolf ecm, Nissan VK56DE, mercedes brabus inline 6 3.4L, AJ34S Jaguar XJS 400hp, Ford GT500 5.4L etc) and finally I got a wild hair to get something installed...The rest is history.
  13. Yes it looks cramped BUT remarkably everything has been designed to be accessible...ie waterneck to block I had to cut out ~2" out so that I would clear the frame, I used F150 solid rubber mounts (that had mount recievers bolted to the frame in place of the liquid filled round mounts. I used the battery tray area to tap into the passenger side vent for a fresh air solution...I also used a Expedition oil filter relocation setup (which I will tap into for an oil cooler. I am currently going down a rabbit hole and installing ABS and 98 Lincoln MK8 Air Conditioning with digital control. Lots of fun. Thanks for the reply PS I tried installing a 5.4L with twin turbos but the long block alone wouldn't clear the hood.
  14. I agree...that was the plan BUT I tried multiple times and when I removed the "tacked" mounts they came apart. Thanks though!
  15. If you paid that much...they should have givin you the file or diagrams? Let me know and I will check my machinest on cost...I also had similar thoughts on dual Z32 fronts..."If more is better then too much is just enough" a little over kill but I like it.
  16. Are you still interested? I have a couple of pairs of modified strut/spindle, steering arms and hubs for 4 lug...you'll need to source the 240sx z32 rotors on FleeBay. The cost without sectioning is $350 and if you want I can lower the spring perches. I can section them for an extra $100. They are a direct bolt on and look great. Are you going with coilovers? are you sectioning and 4 lug? I have a solution. PM me.
  17. I have seen stress cracks on rotors wo/ cross drilling, and another example that you will see these stress cracks are on flywheels and thay are not cross drilled also...Also it is very important to have properly chamfered holes other wise you will hear a loud buzzing noise and will be more likely to crack.
  18. I tried my hand at welding the motor and trans mounts...Horrible so I will be paying for a local mobile welder to come out and weld everything up at once. I am waiting on funds to finish the suspension ( powder coating ) and am currently putting in the Lincoln MK VIII heating and A/C system and the 300zx z32 ABS system...If I use the 15" Swastikas...I will have to use Q45 (in place of the z32 calipers) calipers for now. The rears are late Z31 turbo rear ventilated setup.
  19. I have been playing around with some online calculators and I have three types of rims/tires and three VLSD's. Stock 4.6L Ford DOHC motor in my 240z: 11.78 sec. 1/4 mile Top Speed 156 mph @ 290 hp (old 151 hp 2400 lbs. @ 125 mph) 1/4 mile based power to wt.: http://robrobinette.com/et.htm 11.78 sec. 1/4 mile (2400 lbs. and 290 hp) 10.58 sec. 1/4 mile (2400 lbs. and 400 hp) 09.00 sec. 1/4 mile (2400 lbs. and 650 hp) Needed HP for Top Speed: http://robrobinette.com/top_speed.htm 156 mph @ 290 hp 180 mph @ 400 hp 203 mph @ 650 hp top speed based on gears: (if you have the hp) http://www.catherine.../sti/tyres.html Gear RatiosTR-3650 used in the 2001-2004 Ford Mustang GT 1st: 3.380:1 2nd: 2.000:1 3rd: 1.320:1 4th: 1.000:1 5th: 0.670:1 VLSD's 190 mph 4.09:1 191 mph 3.90:1 201 mph 3.70:1 The diagrams of wheels below have figures at the bottom to compare to a set of Swastika's
  20. I have been playing around with some online calculators and I have three types of rims/tires and three VLSD's. Stock motor in my 240z: 11.78 sec. 1/4 mile Top Speed 156 mph @ 290 hp (old 151 hp 2400 lbs. @ 125 mph) 1/4 mile based power to wt.: http://robrobinette.com/et.htm 11.78 sec. 1/4 mile (2400 lbs. and 290 hp) 10.58 sec. 1/4 mile (2400 lbs. and 400 hp) 09.00 sec. 1/4 mile (2400 lbs. and 650 hp) Needed HP for Top Speed: http://robrobinette.com/top_speed.htm 156 mph @ 290 hp 180 mph @ 400 hp 203 mph @ 650 hp top speed based on gears: (if you have the hp) http://www.catherineandken.co.uk/sti/tyres.html Gear RatiosTR-3650 used in the 2001-2004 Ford Mustang GT 1st: 3.380:1 2nd: 2.000:1 3rd: 1.320:1 4th: 1.000:1 5th: 0.670:1 (used on 01-04 with 3.27:1 final drive) 190 mph 4.09:1 191 mph 3.90:1 201 mph 3.70:1
  21. Here is another option that I found on a Nissan Pathfinder and then found these pictures...
  22. I just put some info together...Hope it's helpful: Stock L28 complete with stock manifolds, SU's, and A/C compressor + 5 spd = 523 lbs. My 4.6 aluminum DOHC complete 425 lbs w/ tremec 3650 5 speed 120 lbs. = 545 lbs. Big brake kit estimated (compaired some items and estimated others) 13.6 lbs more than stock. (Z32 aluminum calipers) My 240Z wt. Front 52.4% (1200 lbs.) rear 47.6% (1090 lbs.) = 2290 lbs. 240z wt. Front 52% (1164 lbs.) rear 48% (1074 lbs.) = 2238 lbs. z32 wt. Front 51.65% (1960 lbs) Rear 48.35% (1835 lbs) = 3795 lbs. Q45 wt. Front 57.20% (2310 lbs) Rear 42.8% (1728 lbs) = 4039 lbs. r180 wt. Longnose r180 - weight 60 lbs r200 wt. Longnose R200 - weight 76 lbs r200 wt. Shortnose R200 - weight 72 lbs r230 wt. Shortnose R230 - weight 114 lbs 240z 151hp My 240 290hp (stock 4.6 dohc) 295 lb·ft Torque 300zx 222hp 300zxtt 300hp q45 278 hp Power to Weight: 240z = 14.82:1 My 240z = 7.9:1 300zx = 17.1:1 300zxt = 12.65:1 q45 = 14.53:1 Ferrari 458 = 7:1 Ferrari 458 Italia Specifications: (To keep things in perspective) Base engine size: 4.5 L Cam type: Double overhead cam (DOHC) Cylinders: V8 Valves: 32 Valve timing: Variable Direct injection Torque: 398 ft-lbs. @ 6000 rpm Horsepower: 562 hp @ 9000 rpm Gross weight: 3935 lbs. top speed is 202 mph 0 to 62 mph in less than 3.4 seconds 17.68 mpg (U.S.) EPA tested 10 mpg
  23. Thanks for the offer but I have a couple more...Also I don't know if I should post the brakes, suspension and more. Well here are some pictures...The brakes are my old setup that I never got to test I have moved to the Z32's on the fronts and vented rears.
