Fairlady240Z
Everything posted by Fairlady240Z
Building an R34 RB26DETT with an NEO R34 Transmission to put in my 1972 Nissan Fairlady 240Z. I am not a car guru or anything like that, I just trust the technical information in this forum. Can some one suggest what EMS system to use. I've been considering buying the APEXI Power FC, it has a corded controller to program engine performance. Haltech and others need a computer hookup and software to program. I don't know what information I need to supply about the engine upgrades to make this determination. New Tomei Turbos 8260's, Okeida Plasma coil Packs, 800cc injectors, 1mm oversized valves, Nismo N1 crankshaft, Tomei exhaust manifolds and dump pipes, 90mm throttle body, New Intake, Fuel rails, Bosch high flow fuel pumps X2, looking to get between 5-600 horsepower. Any help would be greatly appreciated. Thanks in advance.
I have 1 I am not using $200.00 OBO
Try your local junkyard try and find a 300ZX turbo 84-88 you will also need to get the mustache bar cause the R180 bar won't fit
Bad Dog parts frame rails, Zedd Finding floor pans, R200 out of 300ZX turbo CLSD or VLSD , search ebay for interior, seats and such., Hope this gets you started http://zhome.com/ZCMnL/tech/R200.htm http://www.baddogparts.com/ http://www.datsunzparts.com/NewParts/summary.htm http://www.classiczcars.com/forums/wheels-tires-brakes-s30/34762-new-4-piston-calipers%3D-lotsa-fun.html
R34 RB26DETT ignition immobilizer bypass
Fairlady240Z replied to Fairlady240Z's topic in Nissan RB Forum
http://www.skylinesaustralia.com/forums/topic/124811-disabling-r34-factory-immobiliser/ -
http://www.skylinesaustralia.com/forums/index.php?showtopic=123136 -
I purchased an R34 RB26DETT to put in my 1972 Nissan Fairlady 240Z RHD. While reading up on the R34 it seems to have an ignition immobilizer on it. Was wondering if anyone else has done this swap and what was their solution to bypass the ignition immobilizer. Is it just locating the pin(s) on the ECU and bypassing them or is there another solution for this problem? Thanks in advance for all who help on this issue
Rips RB Custom Oil Pan Arrived Today
Fairlady240Z replied to RB26powered74zcar's topic in Nissan RB Forum
I have been searching to find a rubber oil pan gasket, to no avail. Looks like you have one there on your oil pan wondering where you located that gasket. Thanks -
?PDK? don't know what that is. WOW my problem is that I have a 1972 RHD Fairlady 240Z in the process of restoring just ordered a new restored dash from japan @ easyauctionjapan.com paid less than $400.00 + SHIPPING they have fiber glass and carbon fiber door panels would love a RHD carbon fiber dash. What is PDK?
Are the ss gas straps still available? if so interested
Hello HybridZ forums: I have been collecting parts for my 1972 Fairlady 240Z RHD build for the past year or so. Wanted to amass majority of the parts before undertaking this build. I have acquired an R34 RB26DETT engine with an R34 RB25DET NEO 5 speed transmission. I want to go with a twin 2 1/2" exhaust system, searched the exhaust forums and could not find out if catalytic converters and O2 sensors are needed or required. Please understand I am not a mechanic I am just trying to gather info to complete my HybridZ. Any insight would greatly be appreciated thank to all for your input in advanced.
I purchased the Tomei arms 8260 turbo kit. the kit provides all the water and oil cooling lines, gaskets complete direct bolt on replacement. The turbo's are rated @ 650 hp. Cost about $2800.00 shipping included.
modern-motorsports.com (MMS) is still i business you need the hyphen in the name to access the website. I'm running the R200 clsd out of a 87 300zxt with the cv axels, using MMS Z31 companion flanges with the 5 lug set-up also from MMS. Looked @ the sites you referenced and MMS prices are a bit cheaper but Ross the owner of MMS is a bit slow on processing orders not taking orders but processing them for shipment. Hope this gives you another option.
Great found this thread again bought the clutch packs from Savage now have info for rebuild thank you
Sorry let me clarify; does the R34 RB26DETT use low or high impedance fuel injectors?
building an RB26DETT to put in my '72 240Z looking to get bigger injectors want to know the differenca between low impedance and high impedance injectors? Any insight to my lack of knowledge on this subject would be greatly appreciated. Thank you in advance for your insight
Need a set of wheel spacers for front brake upgrade. The spacer that I need are to push the rotors back away from the hubs to mate up with the calipers. The brake set up that I want to run is the Toyota S12W calipers, 300ZX front vented rotors, Z31 hubs from Modern-Motor sports. Tried contacting Ross from MMS for the past couple weeks no response. Some one please H E L P.
Brake upgrade FAQ
Fairlady240Z replied to JMortensen's topic in Brakes, Wheels, Suspension, and Chassis
O.K. here is a question I have that I could not find in the FAQ section. I purchased the Z31 5lug hubs from Modern-Motor Sports with +40 offset, using the 300ZX vented rotors, calipers are the Toyota S12W. My question is what is the thickness of the spacer that is needed to push the rotor back far enough from the hub so that it will mate up with the caliper. Tried contacting Ross at MMS but to no avail, no response. -
Brake upgrade FAQ
O.K. Guys I have a situation that I need to have explained to me. I purchased 240sx calipers, and the 240sx brackets from MMS and also got the stainless steel brake lines. The two lines are different lengths and they also have two different fittings that tie into the brake lines (not talking about the banjo fittings). Why make the different lines one having to use a reducer. Could someone please explain this setup and reasoning. Thank you in advanced -
Bought a set of 5 lug stub axels from Modern Motor sport did not get bearing set, need to purchase. Any help with this is much appreciated
WTB - Top of door chrome/stainless trim for 280Z
Fairlady240Z replied to BitchinZ's topic in Parts Wanted
You can find a new set of the door trim @easyauctionjapan.com they are about $200-$250 + shipping you will have to create a new account and add the funds before you can bid or buy it now, takes about 2 weeks after purchase to receive items after purchase good luck, I just purchased a set myself for $235. -
check out www.easyauctionjapan.com they have plenty of parts for right hand drive Z's one is posted now ending very soon
hey Gary thanks for the Z31 cluches. I'm doing a complete restoration let me check my parts scrap pile and see if I can help you out
You might want to check www.easyauctionjapan.com you can search for s30z parts before you open and account. Here to tell you though, they will not be cheap. saw a new set old stock go for $2400.00
you can get a billet aliminum one off ebay from Techno tuning pretty reasonable and also it looks good
